POV-Ray : Newsgroups : povray.unofficial.patches : Continue_Trace = +C Server Time
6 Apr 2026 22:08:09 EDT (-0400)
  Continue_Trace = +C (Message 1 to 4 of 4)
Subject: Continue_Trace = +C
Date: 29 Mar 2003 12:58:36
Message: <3e85decc$1@news.povray.org>
I lost power last night 7 days into a rendering job (MegaPov 7). The image
is intact up to the point the PC stopped so I added the
Continue_Trace = +C
line to the povray.ini file I am using but immediately upon restarting the
job, the Message window announced it was rendering line 0 - 4800, i.e.,
starting over. I did make a backup of the work so far, but why doesn;t the
Continue command do the job?
Thanks,
D.
dhm### [at] attbicom
http://www.dennismiller.neu.edu
Subject: Re: Continue_Trace = +C
Date: 29 Mar 2003 13:10:11
Message: <3e85e183@news.povray.org>
Hi!
> Continue_Trace = +C
I think, this should be
"Continue_Trace = on"
or
"+c" ( short version for the above)
Strange, that it did work this way - there should be a boolean value behind
the '=', and "+C" isn't a value... (ok, a string, but...)
If this doesn't help, I don't know the answer.
Kalle
Date: 29 Mar 2003 13:48:14
Message: <3e85ea6e$1@news.povray.org>
Okay, thanks. I tried Continue_Trace = on" and two things happened:
It did not erase the existing TGA file, which is good, but the Message
Window says Rendering Line 0 of 0
so I am not really sure what is happening!
Best,
D.
"KalleK" <kal### [at] gmxde> wrote in message news:3e85e183@news.povray.org...
> Hi!
> > Continue_Trace = +C
> or
behind
> Kalle
Date: 30 Mar 2003 16:14:13
Message: <3e875e24@news.povray.org>
Dennis Miller <dhm### [at] attbicom> wrote:
> the Message
  It's working ok. Just wait a moment until povray calculates the extra
line for antialiasing. Then that line should show the correct number
of lines left (it will say "line 1 of x" where x is the number of lines
still to be rendered).
