POV-Ray : Newsgroups : povray.unofficial.patches : See-through function :( Server Time
1 Apr 2026 11:26:08 EDT (-0400)
  See-through function :( (Message 1 to 5 of 5)
Subject: See-through function :(
Date: 13 Mar 2001 12:48:23
Message: <3aae5d67@news.povray.org>
Why do I see the background through it? How do I fix it?
#version unofficial megapov 0.7;
camera {up y*3/5 right x location <2,8,-21> look_at <0,9,5>}
light_source {vnormalize(<3,2,-1>)*100 rgb 1}
light_source {<0,25,25>/2 rgb <1,1,0.9>/4 shadowless}
sky_sphere {pigment {planar rotate -z*35 rotate x*10 color_map {[0.25 rgb
x][1 rgb 1]}}}
#declare Par = function {"paraboloid", <1>}
#declare Obj =
isosurface
 function {(Par(x,y,z) & -Par(x*1.25,y-0.2,z*1.25))}
 sign -1 method 2 max_gradient 2.648
 contained_by {box {<-1,0,-1>,<1,1,1>}}
difference
 object {Obj}
 plane {-x,0}
 scale 10 rotate y*10 translate <-3.25,3.35,20>
 pigment {rgb 1} finish {ambient 0 diffuse 1}
Subject: Re: See-through function :(
Date: 13 Mar 2001 15:40:52
Message: <3aae85d4@news.povray.org>
Odd behaviour verified on mp 0.6. Looks like a bug. Here's a workaround
(only tested on 0.6).
Make the contained_by limited to x=0, not x=1. Then render the object w/o
the difference, as it's no longer required. So, your code should read:
 #declare Obj =
 isosurface {
  contained_by {box {<-1,0,-1>,<0,1,1>}}
object {Obj
Date: 13 Mar 2001 16:00:47
Message: <3AAE8A7E.FC45DD62@gmx.de>
No, just add
max_trace 3
or higher in the isosurface definition.
Date: 13 Mar 2001 21:23:36
Message: <3aaed628@news.povray.org>
> max_trace 3
Cool. That worked. Thanks. I'd never needed it before. :)
Date: 14 Mar 2001 05:09:22
Message: <3aaf4352$1@news.povray.org>
news:3AAE8A7E.FC45DD62@gmx.de...
> No, just add
> max_trace 3
Doh! I tried all the other obvious params, except that one...
