POV-Ray : Newsgroups : povray.unofficial.patches : Any way to use a height field to position objects? Server Time
7 Apr 2026 10:31:06 EDT (-0400)
  Any way to use a height field to position objects? (Message 1 to 3 of 3)
Subject: Any way to use a height field to position objects?
Date: 8 Dec 2000 14:05:57
Message: <3a313115@news.povray.org>
I am wondering of there is a way to use a height field to position objects.
For example, I would like to place glows slighty above an undulating hf.
Here is a
visual representation:
     O
___|____   O                                          O
___________
              |__|___      O         __________|________|
                          |___|_____|
The circles are where the glows would appear.  I would like to do something
like use the hf height to modify the glow height.  Maybe <somex,
hf+0.25,somez>
Is this possible?
Subject: Re: Any way to use a height field to position objects?
Date: 8 Dec 2000 14:14:16
Message: <3A313308.40AA5531@gmx.de>
With megapov you can use 'trace()' or 'hf_height_at()', the second one
will no more be supported in Povray 3.5 btw.
Date: 8 Dec 2000 15:06:59
Message: <chrishuff-8F3864.15074808122000@news.povray.org>
It is possible in MegaPOV, but in the official version you would have to
use an external program to get the data.
In MegaPOV: Use the trace() function, (assuming your height field is in
the xz plane), use -y as the direction, and use a point well above the
height field as the ray starting point. You may want to check the normal
to see if the height field was really hit, the normal will be < 0, 0, 0>
if no intersection was found.
It would also be possible to use the hf_height_at() function, but that
would be a bad idea, because it isn't as versatile and will not be
supported in the future.
Christopher James Huff
