POV-Ray : Newsgroups : povray.unofficial.patches : Problems with motion blur... Server Time
7 Apr 2026 12:12:39 EDT (-0400)
  Problems with motion blur... (Message 1 to 6 of 6)
Subject: Problems with motion blur...
Date: 22 Oct 2000 01:38:55
Message: <39f27d6f@news.povray.org>
I have a spline. I want to move an object along that spline, and have it
motion-blur as it moves. It seems that I can only feed the spline "clock",
or else the blur doesn't show up. I want to control it with another value,
that doesn't increase constantly like clock, say with autoclck.mcr, but it
doesn't blur! What can I do?
Subject: Re: Problems with motion blur...
Date: 22 Oct 2000 08:01:32
Message: <39f2d71c@news.povray.org>
"Tony[B]" <ben### [at] panamac-comnet> wrote in message
news:39f27d6f@news.povray.org...
Try putting it all within the motion_blur {} statement.  Seems you can't access
external variables, so that should do okay.  Not sure about whether everything
will need to be in there or just the final #declare, been a while since I was
trying it myself.
Date: 22 Oct 2000 08:06:08
Message: <chrishuff-80D881.07085822102000@news.povray.org>
In article <39f27d6f@news.povray.org>, "Tony[B]"
As long as the value you give to the spline is calculated using the
"clock" value within the motion_blur block, it should work. I don't know
how the AutoClock macros are doing things, but I don't see how they
wouldn't work.
For example: this will work:
motion_blur {
    #declare Val = sqr(sin(clock));
    object {MyObject translate MySpline(Val)}
But this will not blur with movement along the spline:
motion_blur {
Christopher James Huff
Date: 22 Oct 2000 14:26:26
Message: <39f33152@news.povray.org>
> motion_blur {
Why? Can't this be fixed?
Date: 22 Oct 2000 19:20:09
Message: <chrishuff-C1A9D1.18230022102000@news.povray.org>
In article <39f33152@news.povray.org>, "Tony[B]"
> Why?
Because motion_blur works by parsing the block multiple times, changing
the clock variable slightly each time. If a variable is declared outside
that block, it is parsed once and the result fed into the block. Since
this value doesn't rely on the blurred clock, all the copies of whatever
is affected by the blur are exactly the same.
Probably...but only by parsing the entire scene file multiple times. And
this would probably eliminate the possibility of having separate
motion_blur blocks with different quality levels, would make parsing
much slower, would require rewriting a large portion of the existing
motion blur code, would be more difficult to implement, and finally,
isn't really something that *should* be "fixed". The way it is is(don't
you just *love* English?) far more flexible, it gives you much more
control of what actually goes on. If you want something animated but not
blurred, no problem: just save the clock value in a variable outside the
motion_blur block.
Sorry, but it isn't a bug, just a misunderstanding on your part.
Date: 22 Oct 2000 21:47:29
Message: <39f398b1@news.povray.org>
Oh... :( OK
