POV-Ray : Newsgroups : povray.unofficial.patches : Major bug in MegaPOV Plus? Server Time
13 Aug 2026 14:56:07 EDT (-0400)
  Major bug in MegaPOV Plus? (Message 81 to 81 of 81)
Subject: Re: Major bug in MegaPOV Plus?
Date: 15 Sep 2000 18:01:30
Message: <slrn8s55ht.h9g.hjp-usenet@teal.h.hjp.at>
On 15 Sep 2000 02:46:13 -0400, Warp wrote:
>Peter J. Holzer <hjp### [at] sikituwsracat> wrote:
>: No, only function *declarations* inside other functions are permitted,
>: but not function *definitions*.
>  I meant what you are saying, ie. declaration. I know that you can't put
>  the body of the function inside another function.
>  I really don't know the difference between the words "declaration" and
>  "definition".
In C, a declaration tells the compiler what a "thing" (an object[1] or a
function) looks like, while a definition creates it. Every definition
is also a declaration, but not vice versa.
>  Usually when I have to refer to the body of the function I use
>the word "implementation". It may be wrong, though.
No it isn't wrong. It just isn't the word used when one talks about the
C programming language. Modula-2 for example has "definition modules"
and "implementation modules". Obviously when someone talks about a
"definition" in a modula program, he means something else than someone
talking about a "definition" in a C program.
Unfortunately, often a single word is used for different concepts, and
different words are used for the same concepts. What is meant has to be
guessed from context.
	hp
[1] Just as another example: An "object" in C is just a place to store
values (either a variable or a malloced area). It has nothing to do with
object-oriented programming.
   _  | Peter J. Holzer    | access ist als datenbankserver fraglos noch
|_|_) | Sysadmin WSR       | ungeeigneter als beispielsweise EDIT.COM,
| |   | hjp### [at] wsracat      | und das primaer aufgrund der erzeugung
__/   | http://www.hjp.at/ | falscher erwartungshaltungen. frank paulsen
