![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Just had the problem a few times now... When rendering a large image
(3200 x 2400) with PP enabled (tested with soft_glow and focal_blur),
Megapov (Windows) crashes at the beginning of the post-process phase.
There is no problem on small images. Before it crashes, the following
message is repeated on screen :
unknow error 17
attempt to free null pointer (file: c:\pov\mypov\source\povray.c line
1941)
The following scene causes it for example :
#version unofficial Megapov 0.5;
global_settings{post_process{focal_blur{2,2,5,1}}}
camera{ location -x*10 direction z right 4/3*x look_at 0}
light_source{ 100*x color 1 }
sphere { 0.0, 1 texture {pigment{color 0.5} }}
command line +w3200 +h2400 +f -d
Configuration : Megapov 0.5 on WinNT (126 Mb RAM, PIII 733 MHz)
G.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Well, further investigation reveals that setting the swap file size to 450
Mb (instead of 140...) fixes the problem. Just an insufficient memory
problem after all.
G.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Megapov crashes when post-processing large images
Date: 15 Sep 2000 02:49:35
Message: <39c1c67f@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Gilles Tran <tra### [at] inapg inra fr> wrote:
: Well, further investigation reveals that setting the swap file size to 450
: Mb (instead of 140...) fixes the problem. Just an insufficient memory
: problem after all.
It shouldn't crash the program though (ie. trying to free a null pointer
is always a bug).
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> problem after all.
> G.
There's still a problem. Even after the swap file increase, the post process
starts OK, processes some of the image and then... crashes NT, a good old blue
screen of death. Wild guess : this must be one of these things called "memory
leak".
G.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> leak".
> G.
I just tested a large scene with post process myself because i'm also using NT,
did not finish it, because after 20 minutes of PP, it had finished mere 7%. It
did not crash until then, but the swapfile got 540 Mb large.
In fact NT should not crash because of an application memory leak (it maybe does
though :-) but in any case, megapov's memory use during post processing seems
not very efficient.
Christoph Hormann <chr### [at] gmx de>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> though :-) but in any case, megapov's memory use during post processing seems not
> very efficient.
Possibly I should raise the swap even higher. The strange thing is that I rendered
at least one scene with PP on Megapov 0.3 with a large image size before and didn't
have this problem (but this was a different computer and I don't remember the swap
file setup).
G.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
