POV-Ray : Newsgroups : povray.unofficial.patches : Why & has higher precedence than + or - in isosurface functions? Server Time
9 Nov 2026 20:19:22 EST (-0500)
  Why & has higher precedence than + or - in isosurface functions? (Message 1 to 41 of 41)
Subject: Why & has higher precedence than + or - in isosurface functions?
Date: 31 Jul 2000 09:03:01
Message: <39857905@news.povray.org>
Is there a reason for the operator & having higher precedence than + or -
  The equivalent operator in logic (the one that looks like an upside down 'V')
hasn't, and it would be natural to have the same precedence in isosurface
functions.
  If I write this function:
function { x+y & y+z }
at least I read it in the same way as in mathematics (I'll use '&' here, but
imagine that it's the upside down 'V'):
x+y=0 & y+z=0
  However the current isosurface implementation reads it this way:
x+(y&y)+z
Subject: Re: Why & has higher precedence than + or - in isosurface functions?
Date: 31 Jul 2000 12:37:30
Message: <3985ab4a$1@news.povray.org>
In article <39857905@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
> Is there a reason for the operator & having higher precedence than + or - in
This looks like a bug to me, it should have lower precedence.
    Thorsten
e-mail: tho### [at] trfde
Date: 31 Jul 2000 14:30:43
Message: <3985C626.46C5B6E8@videotron.ca>
is "&" supposed to be the AND logical operator??It seems so,and if it
is, then it's normal: boolean operator have higher precedence than
arithmetical ones in almost all languages(and Maths); if not, then it's
a bug...
Could somebody explain why the patch uses "^" for something else than
exponents??
HTH,
 Paul
AKA paul_virak_khuong at yahoo.com, pkhuong at deja.com, pkhuong at
crosswinds.net and pkhuong at technologist.com(list not complete)...
Date: 31 Jul 2000 14:50:47
Message: <3985ca87@news.povray.org>
In article <3985C626.46C5B6E8@videotron.ca> , pk <thi### [at] videotronca>
> exponents??
As far as I know it does not use it for anything else...
    Thorsten
Date: 31 Jul 2000 14:58:30
Message: <3985CCA9.1452D454@videotron.ca>
> > exponents??
Then, why did warp say "^"(that's an inverted V, right?) does the
opposite of &?
Paul
Date: 31 Jul 2000 15:20:05
Message: <slrn8obl55.1qn.ron.parker@fwi.com>
>> > exponents??
>opposite of &?
He was referring to the mathematical symbol that looks like an inverted V.
That symbol represents logical "and", and looks nothing like a caret.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 31 Jul 2000 15:21:10
Message: <mj1bos4rmn9url4dp0shdmegjdron19h8b@4ax.com>
Well, for me & has always meant binary 'and' or binary multiplication.
As such I find it logical for it to have a higher precedence than
addition. Your mileage may vary but that largely depends on the
programming languages you're most comfortable with :)
Peter Popov ICQ : 15002700
Date: 31 Jul 2000 15:51:58
Message: <3985d8de@news.povray.org>
In article <mj1bos4rmn9url4dp0shdmegjdron19h8b@4ax.com> , Peter Popov
No, both, binary and logical and should have lower precedence.  If it is
binary it could at most have the same precedence to make any sense at all.
If you look at various programming languages you will find that all current
ones obey the rules set by mathematics.
As for binary operations, I think a dot=and, a plus=or and a line above=not
are very common or even standard.  In this case a 'and' has higher
precedence, but this has little to do with general math and is not related.
The & sign in isosurfaces is obviously the equivalent of the inverted-V, and
thus it should have lower precedence.  As for the not inverted-V, the '|'
(or-sign), I am not sure about the current implementation, but is should
also have lower precedence.
   Thorsten
Date: 1 Aug 2000 06:24:26
Message: <3986a55a@news.povray.org>
Thorsten Froehlich <tho### [at] trfde> wrote:
: The & sign in isosurfaces is obviously the equivalent of the inverted-V, and
: thus it should have lower precedence.  As for the not inverted-V, the '|'
: (or-sign), I am not sure about the current implementation, but is should
: also have lower precedence.
  Also | should have lower precedence than &, so if we have this:
x-y | y-z & x+z
it should be interpreted in this way:
(x-y) | ((y-z) & (x+z))
  In this way it will be consistent with mathematics.
Date: 1 Aug 2000 07:45:21
Message: <3986b851$1@news.povray.org>
In article <3986a55a@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
> x-y | y-z & x+z
I agree.
Date: 1 Aug 2000 15:54:04
Message: <h24eosk8rdph7u255d2ckk55gckclf374v@4ax.com>
>x-y | y-z & x+z
Call me stupid but I've never interpreted it this way. Instead, I'd
have read it thus:
x - ( (y?1:0) | (y?1:0) ) & (x?1:0)) + z
I don't know why, it's just that when I see logic operators I think
it's reasonable for them to expect boolean operands (promoted to
boolean if needed). And with that in mind, I expect multiplication to
have a higher precedence than addition, regardless of context.
Date: 1 Aug 2000 17:32:55
Message: <3987425C.687C7484@videotron.ca>
uh... I always thought + meant AND...
So, what's the opposite of AND? NAND? i don't think so....
Date: 1 Aug 2000 17:35:30
Message: <398742F7.4946312B@videotron.ca>
.... i meant to say:"i always thought * (well, dot with valign=center)
meant AND...
Date: 1 Aug 2000 17:52:15
Message: <slrn8oeib9.1u9.ron.parker@fwi.com>
>meant AND...
Well, the non-inverted V-like symbol that looks like the and symbol means
or.  I'm not sure why you're asking what the opposite is, though.
I suspect that the choice of symbology depends on what sort of logic class
you took.  I encountered the ^/V symbology in my pure mathematics classes,
and the dot/plus symbology in my CS classes.
Date: 1 Aug 2000 18:57:39
Message: <39875639.A2E7C7A2@videotron.ca>
Ok, thanx!
Well, I was asking bc the original poster said something about the
opposite of "V upside down" 8)
And I haven't taken any logic class for the moment, only read some CS
books(CPU design, programming, etc)... It's coming this year, in
maths(I'm just going in 10th grade), so **** I'm gonna be a bit lost if
i don't remember that 8)
Thanks again!
Date: 2 Aug 2000 05:09:57
Message: <3987e565@news.povray.org>
pk <thi### [at] videotronca> wrote:
:> uh... I always thought + meant AND...
: .... i meant to say:"i always thought * (well, dot with valign=center)
: meant AND...
  Nope, they don't mean the same thing.
  The function { x * y } is certainly not the same as function { x & y }
(you can render them if you want to see the difference).
  What you are saying in the first function is that a point <x,y,z> is inside
the shape if and only if x*y < 0.
  The the second case you are saying that a point <x,y,z> is inside the shape
if and only if x < 0 and y < 0.
  For example <-1,2,0> is inside the function { x * y } but it's not inside
the function { x & y }.
  The inverted V-looking operator (and I don't have any reason to believe
that & in isosurface functions is anything else) is a basic operator in
set theory. The same goes for | (which is the V-looking operator in set
theory and denotes union).
:> So, what's the opposite of AND? NAND? i don't think so....
  Basic set theory (I use & and | here because of the lack of the proper
characters):
  The inverse of A&B is -(A&B) ie. (-A)|(-B).
  Here '-' means "not" (ie. "not in the set"). That is, a point is not in
A&B if and only if it's either not in A or not in B (that is, it's not in
both at the same time).
Date: 2 Aug 2000 05:13:18
Message: <3987e62d@news.povray.org>
Peter Popov <pet### [at] usanet> wrote:
: I don't know why, it's just that when I see logic operators I think
: it's reasonable for them to expect boolean operands (promoted to
: boolean if needed). And with that in mind, I expect multiplication to
: have a higher precedence than addition, regardless of context.
  & and | are not boolean operators. The are set theory operators.
  When you write: function { x & y }
you are actually saying:
  x<0 AND y<0
not something like:
  (x LOGICAL_AND y) < 0
which makes little sense.
  What is (0.5 LOGICAL_AND -2.8)?
Date: 2 Aug 2000 10:14:06
Message: <39882D08.E5E6F36A@videotron.ca>
> : meant AND...
Yeah, well, as Mr Parker pointed out, logic operators in CS and Logic
Maths aren't the same 8(
In CS, if i remember right, "+" is OR, "*"(well, a dot that's in the
vertical middle of the line) mean AND, and a "-" that's above the line
means not...
I wasn't saying * meant something else than multiply in computer
languages(except maybe APL 8), but that before, in all the litterature
i've read, AND was written the same as you'd write * in algebra...
Can't they make out a standard?!?!?!??!
Oh, well,
 Paul
Date: 2 Aug 2000 10:24:36
Message: <39882F7E.6A2B29FE@videotron.ca>
>   x<0 AND y<0
> not something like:
You've never made any programmation before, have you?
In most programming languages, they assign a value to TRUE, and another
to FALSE(in the case above, FALSE=0, and TRUE=NOT(FALSE) )
In other languages, fe, C(for which i dont't really remember the
standard), it's something like TRUE = -1 (binary 11111111) and FALSE
would be 0(binary 00000000)...
And, for your trivia, it depends: most languages will do logical
operations bit by bit, but i suppose that others have a Boolean
type(Java, fe i think), and will undercast it before doing the
LOGICAL_AND
And, yes, doing Logical operations bit by bit can be useful, and anyway,
you can just add a comparison operator before doing the boolean
operation...
HTH,
 Paul
Date: 2 Aug 2000 10:32:43
Message: <u6cgossjcgm7mm5344obi02n837nqjrm82@4ax.com>
!FALSE :))
Date: 2 Aug 2000 11:02:18
Message: <398837f9@news.povray.org>
It doesn't matter how do you draw the symbol. The meaning should be clear
by now? & is the set theory intersection and | is union, right?
Date: 2 Aug 2000 11:12:16
Message: <39883a4f@news.povray.org>
: You've never made any programmation before, have you?
  I have been programming for about 10 years.
: In most programming languages, they assign a value to TRUE, and another
: to FALSE(in the case above, FALSE=0, and TRUE=NOT(FALSE) )
: In other languages, fe, C(for which i dont't really remember the
: standard), it's something like TRUE = -1 (binary 11111111) and FALSE
: would be 0(binary 00000000)...
  Nope. In C a true value is 1 (for example the result of the sentence a==b
is 1 if a is equal to b, else 0). When testing a conditional, any value
other than 0 is considered true, and 0 is considered false.
  In this context (0.5 AND -2.8) would be true because none of them is 0.
This, however, has no mathematical meaning whatsoever. It hasn't any meaning
in isosurface functions either (what would a 'true' or 'false' value mean
in a function, may I ask?).
: And, for your trivia, it depends: most languages will do logical
: operations bit by bit, but i suppose that others have a Boolean
: type(Java, fe i think), and will undercast it before doing the
: LOGICAL_AND
  The point is that the & operator in isosurface functions is not even close
to the logical AND-operator of programming languages.
: And, yes, doing Logical operations bit by bit can be useful, and anyway,
: you can just add a comparison operator before doing the boolean
: operation...
  Firstly, there's no bitwise AND-operator anywhere in the povray language,
and secondly, the &-operator in isosurface functions is neither a logical
nor a bitwise AND-operator.
  It would make no sense in having a logical operator in a function anyways.
Which function is 'true' or 'false'? How do you draw the function { true } ?
  (No, I'm not talking about the povray keyword 'true' here.)
Date: 2 Aug 2000 11:51:38
Message: <39884355.DCB5F320@buckosoft.com>
Your definition is wrong, but your example is correct. :)
False is 0.  True is not false.
1 is a true value, as is 2, as is -1.
I have seen #define TRUE 1
I have also seen #define TRUE ~FALSE
dik
Date: 2 Aug 2000 11:56:38
Message: <39884510.338B87F5@videotron.ca>
Whoa! sorry! 8)
Well, I said i wasn't sure... -1 and 0 must be for Basic, then...
TRUE and FALSE having been declared before as constants, TRUE and FLASE
will have values...
What do you mean? Isosurfaces are booleans for me: at location <x, y,
z>, there's a point(true, or 1), or there isn't any(false or 0)... So,
you have a function that draw a plane, and another one that draws a
sphere...
You AND them... the result? a circle... You & them... the result? a
circle...
In theory, it might not be the same, but let's ask the person who did
the patch about it...
Anyway, it's getting pretty hot in this thread...
I'm sorry if i offended you by assuming you had no programming
background... it just sounded like you only saw it from the
mathematician pt of view...
Paul
Date: 2 Aug 2000 12:42:16
Message: <slrn8ogkht.8in.ron.parker@fwi.com>
I prefer #define TRUE (1==1) and #define FALSE (1==0)
Date: 2 Aug 2000 12:53:12
Message: <slrn8ogl6d.8in.ron.parker@fwi.com>
>sphere...
More specifically, a point is either inside or outside the isosurface.
>circle...
Well, in the code, the function that performs that operation is called
"and," but it doesn't use a logical operator to do what it does (it uses
min or max)  Personally, I always think of intersection/union as and/or
anyway, preferring to use CS methods to decompose complex CSG operations.
They're pretty interchangeable at this level, but it's not a mistake
you'd want to make in a higher-level math or CS course.
Date: 2 Aug 2000 14:32:53
Message: <39886955@news.povray.org>
In article <39884355.DCB5F320@buckosoft.com> , Dick Balaska
In C++ he would be nearly right :-)   Except that there is no definition of
the internal representation of the type "bool" which is left to the
compiler/platform (i.e. some RISC platforms like PowerPC have several
condition-code registers and instructions to work with them).
Only conversions from and to "bool" are defined in C++, and in case of the
conversion of bool to anything, true will be "1".
     Thorsten
Date: 2 Aug 2000 18:09:25
Message: <1s6hos89l9r0i1bigu46lb40e6bat72dlv@4ax.com>
Why am I thinking that this issue has not been standardised yet?
Because I am wrong again? :)
Ah, so *that* is the point I've been missing all this time!
Can I have a sign?
Date: 2 Aug 2000 18:15:22
Message: <39889BC2.288D3B69@pacbell.net>
> Can I have a sign?
Ron Popov, please give Peter Parker a sign.
Date: 2 Aug 2000 18:54:24
Message: <slrn8ohabq.8q3.ron.parker@fwi.com>
He has one.  It has that cool spider on it.
Date: 3 Aug 2000 20:22:50
Message: <398A0D84.245410EE@mailbag.com>
And then there are the Unix shells...
$ true
$ echo $?
0
$ false
$ echo $?
1
Just to keep everyone confused. ;-)
-Mark Gordon
Date: 3 Aug 2000 20:28:37
Message: <398A0C7A.AFB04A96@pacbell.net>
> $ true
> $ echo $?
> 0
> $ false
> $ echo $?
> 1
They teach you that at Siggraph 2000 ?
Date: 4 Aug 2000 05:51:21
Message: <398a9219@news.povray.org>
: Why am I thinking that this issue has not been standardised yet?
  What do you mean?
  It is clearly stated in the C and C++ standards.
  If you mean that there's no common standard for all programming languages,
that's only good. If in a specific programming language it's a lot more
natural to state that 'false' is -1 (for example for speed reasons), then
there's no reason to force it to be anything else.
Date: 4 Aug 2000 05:59:05
Message: <398a93e8@news.povray.org>
Dick Balaska <dic### [at] buckosoftcom> wrote:
: I have also seen #define TRUE ~FALSE
  This is horrible. It doesn't work!
  Suppose we have:
#define FALSE 0
#define TRUE ~FALSE
  Then TRUE will be -1 (ie. all bits set).
  Now suppose we want to add a "boolean" type:
typedef int BOOL;
  This will NOT work as it should:
int x=2, y=2;
BOOL b;
b = (x==y);
if(b == TRUE)
  puts("Equal");
else
  puts("Different");
  This will print "Different" although x and y are equal.
Date: 4 Aug 2000 06:05:03
Message: <398a954f@news.povray.org>
: What do you mean? Isosurfaces are booleans for me: at location <x, y,
: z>, there's a point(true, or 1), or there isn't any(false or 0)... So,
: you have a function that draw a plane, and another one that draws a
: sphere...
: You AND them... the result? a circle... You & them... the result? a
: circle...
  Well, here you are thinking about the set theory union. This has little to
do with the logical and-operator.
  And besides, the logical and-operator in programming languages has lower
precedence than + and - anyways. So in either way you want to think about it,
the current implementation is wrong.
Date: 4 Aug 2000 06:25:44
Message: <398A9A4E.24B1018A@aetec.ee>
>   Suppose we have:
> #define FALSE 0
> #define TRUE ~FALSE
> typedef int BOOL;
> int x=2, y=2;
> BOOL b;
> b = (x==y);
> if(b == TRUE)
>   puts("Equal");
> else
>   puts("Different");
It is generally not good idea to compare against #define-d TRUE anyhow.
Better is to use != FALSE (although it is not very readable with its
double negative. Fortunately with C++ bool type this shouldn't be issue
any more.
Date: 6 Aug 2000 02:14:37
Message: <398D0212.8F73338E@buckosoft.com>
>   Suppose we have:
> #define FALSE 0
> #define TRUE ~FALSE
> typedef int BOOL;
> int x=2, y=2;
> BOOL b;
> b = (x==y);
> if(b == TRUE)
>   puts("Equal");
> else
>   puts("Different");
You are a young pup.
And you are correct that this doesn't work on 2000 C compilers
because the (user) definition of TRUE doesn't match the system
definition.
But suppose you are working on a 6502 :) or a PDP-11, which can
deal with a -1 much easier than a 1; then it makes sense.
The PDP-11 is big-endian, so when you truncate a 1, you get 0
like down casting from int to word to char.  The -1 always stayed
consistent across casts.
dik
Date: 6 Aug 2000 10:47:36
Message: <398d7a88@news.povray.org>
: But suppose you are working on a 6502 :) or a PDP-11, which can
: deal with a -1 much easier than a 1; then it makes sense.
: The PDP-11 is big-endian, so when you truncate a 1, you get 0
: like down casting from int to word to char.  The -1 always stayed
: consistent across casts.
  This can't work this way. If it did, then if you make this:
char c = 1;
the variable 'c' will have the value 0.
  '1' is of type int.
Date: 6 Aug 2000 14:41:17
Message: <398db14d@news.povray.org>
In article <398d7a88@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
> char c = 1;
>   '1' is of type int.
Sorry, but you are misunderstanding the concepts here:  You have to view the
problem on a lower level than the C programming language.  You have to look
at the hardware:  In case of a memory based CPU architecture, an access to a
int casted to a char will have certain side effects that are usually
"hidden" by a compiler, however, especially in the early days of C it was
common to use the knowledge about the CPU the code would run on to increase
speed.
Even today you can use this trick of CPU dependency, i.e. when you want to
determine the endianess on the fly - simply cast an pointer to an int to a
char and look at the result on different architectures.  After all, C
explicitly allows low level programming; this makes it such an popular
language for implementing operating systems and embedded applications.
A good textbook explaining such issues is "Computer Organization and Design:
The Hardware/Software Interface" (ISBN 1558604286).  It uses the original
(32 bit) MIPS architecture as example for the assembler code (and there is a
software emulator of a simple MIPS system available - even one that runs on
Solaris).  It also explains how high-level language constructs are actually
implemented on the assembly level.  This is in particular useful if you want
to write efficient C/C++ code.
The only negative point is the US$80 price tag.  Anyway, it is available
even in a lot of European university libraries.  Alternatively, there will
surely be a lot of similar, but older books (usually covering the 68000 CPU
architecture) available in next to any library.
    Thorsten
Date: 6 Aug 2000 20:39:41
Message: <398E0511.E784637@buckosoft.com>
It works.  It wasn't pretty.
On x86, if you lay out 0x01020304 in memory, it becomes
04 03 02 01  which is what you are used to.
if you read this as a (32 bit) int then you get back your 0x01020304.
Reading it as a char you get 0x04.
So using TRUE=1 flows naturally with this scheme.
01 00 00 00  is 1 whether read as 8 or 32 bits.
But on a big endian machine, i=0x01020304 is laid out
01 02 03 04.  So if you read (char)i you get 01.
So if (int)i = TRUE=1 or 00 00 00 01, then reading (char)i gives you 0.
So (int)i = TRUE = -1 or FF FF FF FF, gives you non-zero in any size.
Like i said, these were the old days.  Now i believe on Sparcs and 680x0
there is an implied offset, such that (char)i is read as *((char)i)+3).
Hmm, that seems even weirder; what would ((char)i)+1) give you.
Beats me.  So i took a jaunt through my old K&R and there is no mention
anywhere of TRUE, FALSE, BOOL or boolean.  It does mention that UNIX
is 16000 lines of C :) and that the assignment
int i 1; /* is legal but deprecated */
Also, the equivilant of += and -= , which is =+ and =- is now frowned upon
for obvious reasons. x =-1;
Old book.
dik
Date: 7 Aug 2000 06:06:04
Message: <398e8a0c@news.povray.org>
: Sorry, but you are misunderstanding the concepts here:  You have to view the
: problem on a lower level than the C programming language.  You have to look
: at the hardware:  In case of a memory based CPU architecture, an access to a
: int casted to a char will have certain side effects that are usually
: "hidden" by a compiler, however, especially in the early days of C it was
: common to use the knowledge about the CPU the code would run on to increase
: speed.
  I think that a C compiler making this kind of thing (ie. when '1' is casted
to a char, the value '0' results) breaks the ANSI C standard, and thus the
compiler is not an ANSI C one.
  Of course you can use low-level tricks to, for example, get the endianess
of the system, but you can't do many of these tricks without breaking the
standard (usually the standard says about these things that they are undefined
and the compiler can do whatever it wants about them).
  But as you said, specially in embedded systems this kind of freedom makes
C a very versatile language. Not many other languages allow you to, for
example, write directly to a memory location some value.
