POV-Ray : Newsgroups : povray.unofficial.patches : trace() not working with isosurfaces? Server Time
17 Aug 2025 03:38:29 EDT (-0400)
  trace() not working with isosurfaces? (Message 1 to 10 of 13)
Subject: trace() not working with isosurfaces?
Date: 18 Jul 2000 11:30:27
Message: <39747813.ECD7B37A@itam.cas.cz>
Hello,
  I'am playing with ridgedfm heightfield and I'am trying
  to place some "trees" (cylinders, right now ;-) on it.
  But something is wrong: when I made box, sphere,
  isosurface with function { y } instead of heightfield,
  it works. When I use ridgedmf, or noise, or pigment
  in fuction it is unable to fund intersection of rays
  with hf. But is heightfield itself displays correctly.
  Any idea, what I'am doing bad?
Thanks
Disnel
Source code of testing scene:
#version unofficial MegaPov 0.5;
  location <10, 10, -10>
  angle 20
  look_at <0, 0, 0>
light_source {< 100, 100, -50> color rgb 1}
light_source {<-100, 100, -50> color rgb .5}
#default {
    pigment {color rgb 1}
    finish {ambient 0 diffuse .8}
//background {color rgb .7}
#declare H=1.0;
#declare Lac=1.5;
#declare Octs=12;
#declare Offset=0.0;
#declare T=1.0;
#declare HF_Func=function {"heteroMF",<H, Lac, Octs, Offset, T> }
#declare Landscape=
isosurface{
  function{y - HF_Func(x,0,z) + 1 }
  eval
  contained_by { box {<-2, -2, -2>, <2, 0, 2>} }
  scale <1, .4, 1>
//#declare Landscape=box {<-2, -1, -2>, <2, 0, 2>}
//#declare Landscape=sphere {<0, -10, 0>, 10}
object {Landscape}
#declare Step_x=0.3;
#declare Step_z=0.3;
#declare Max_x=2;
#declare Max_z=2;
#declare Tree=
cylinder {
  <0, 0, 0>, <0, .25, 0>, .02
    pigment {color rgb <.5, 1, .5>}
#macro PlaceTree(px, pz)
  #local Normal=<0, 0, 0>;
  #local Where=trace(Landscape, <px, 10, pz>, <0, -1, 0>, Normal);
  #if (Normal.x = 0 & Normal.y = 0 & Normal.z = 0)
    #warning "Tree not placed\n"
  #else
    object {Tree translate Where}
#local px=0;
#while (px < Max_x)
  #local pz=0;
  #while (pz < Max_z)
    PlaceTree(px, pz)
    #if (px > 0)
      PlaceTree(-px, pz)
      #if (pz > 0)
        PlaceTree(-px, -pz)
    #if (pz > 0)
      PlaceTree(px, -pz)
    #local pz=pz+Step_z;
  #local px=px+Step_x;
Subject: Re: trace() not working with isosurfaces?
Date: 18 Jul 2000 14:52:37
Message: <3974A638.DEF5AC4F@skynet.be>
The problem is due to the fact that you use the same variable
names in the macro and in the loop.  This works :
#macro PlaceTree(ax, az)
  #local Where = trace(Landscape, <ax, 10, az>, <0, -1, 0>, Normal);
  #else
Date: 19 Jul 2000 11:28:35
Message: <3975C923.726301EE@itam.cas.cz>
I don't think so. It works when I replace isosurface with
box or sphere (and I think, that px and pz are declared locally
in macro). And it does not work when I replace them with
ax or az, as you wrote.
Which version od MegaPOV are you using? I use Linux version.
>   #else
>   #end
> #end
Date: 19 Jul 2000 13:01:41
Message: <3975DEF5.F1A6AFCE@itam.cas.cz>
... and it also works with isosurface sphere....
Date: 19 Jul 2000 13:28:30
Message: <chrishuff-78F1F0.12290319072000@news.povray.org>
In article <39747813.ECD7B37A@itam.cas.cz>, Vaclav Cermak
Try increasing the accuracy of the isosurface.
Date: 19 Jul 2000 14:09:24
Message: <3975EECF.97D54001@its.bldrdoc.gov>
> >   #else
> >   #end
> > #end
Another problem is that "Normal" is a reserved word. When I changed it
to something else (such as "Norm"), it worked.
Date: 19 Jul 2000 14:15:46
Message: <slrn8nbsqa.4br.ron.parker@linux.parkerr.fwi.com>
Is not.  Reserved words don't have capital letters in them.  Try it as
posted and see if it works that way.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 19 Jul 2000 16:13:37
Message: <39760AB5.9EC409D@skynet.be>
At least, once I did that, it worked fine...
otherwise it didn't...
Win version, MegaPOV 0.5A
Date: 19 Jul 2000 17:26:56
Message: <39761D12.F7088486@its.bldrdoc.gov>
I tried it as posted, then changed the variable names in the PlaceTree
macro as suggested; neither would work (Normal was always equal to <0,0,0>).
When I changed the variable name to Norm, it did work (placed a tree at
each point). I realize that "normal" is reserved, but I can't explain why
"Norm" works and "Normal" does not.
Date: 20 Jul 2000 08:45:25
Message: <3976F465.21185F2E@itam.cas.cz>
Already tried 0.0000000001, no success.....
