... and it also works with isosurface sphere....
In article <39747813.ECD7B37A@itam.cas.cz>, Vaclav Cermak
<dis### [at] itam cas cz> wrote:
> I'am playing with ridgedfm heightfield and I'am trying
> to place some "trees" (cylinders, right now ;-) on it.
> But something is wrong: when I made box, sphere,
> isosurface with function { y } instead of heightfield,
> it works. When I use ridgedmf, or noise, or pigment
> in fuction it is unable to fund intersection of rays
> with hf. But is heightfield itself displays correctly.
Try increasing the accuracy of the isosurface.
Christopher James Huff - Personal e-mail: chr### [at] mac com
TAG(Technical Assistance Group) e-mail: chr### [at] tag povray org
Disnel wrote:
> I don't think so. It works when I replace isosurface with
> box or sphere (and I think, that px and pz are declared locally
> in macro). And it does not work when I replace them with
> ax or az, as you wrote.
> Which version od MegaPOV are you using? I use Linux version.
> Fabien Mosen wrote:
> > The problem is due to the fact that you use the same variable
> > names in the macro and in the loop. This works :
> > #macro PlaceTree(ax, az)
> > #local Normal=<0, 0, 0>;
> > #local Where = trace(Landscape, <ax, 10, az>, <0, -1, 0>, Normal);
> > #if (Normal.x = 0 & Normal.y = 0 & Normal.z = 0)
> > #warning "Tree not placed\n"
> > #else
> > object {Tree translate Where}
> > #end
> > #end
Another problem is that "Normal" is a reserved word. When I changed it
to something else (such as "Norm"), it worked.
Is not. Reserved words don't have capital letters in them. Try it as
posted and see if it works that way.
Ron Parker http://www2.fwi.com/~parkerr/traces.html
My opinions. Mine. Not anyone else's.
At least, once I did that, it worked fine...
otherwise it didn't...
Win version, MegaPOV 0.5A
I tried it as posted, then changed the variable names in the PlaceTree
macro as suggested; neither would work (Normal was always equal to <0,0,0>).
When I changed the variable name to Norm, it did work (placed a tree at
each point). I realize that "normal" is reserved, but I can't explain why
"Norm" works and "Normal" does not.
Already tried 0.0000000001, no success.....
For me, neither Normal nor Norm works :(((....
Disnel <dis### [at] itam cas cz> wrote:
:> Try increasing the accuracy of the isosurface.
: Already tried 0.0000000001, no success.....
Accuracy is not always the answer. Sometimes you have to play with
the max_gradient.
> the max_gradient.
Tried max_gradient 100000000, no success. It suspiciously
fast parse the file, the render is unfinishable.
When I try method 1, it places some "trees" but at wrong
places (I think) and isosurface itself has many holes
