![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Try this:
$Z = <2, 0>;
#debug concat(str(creal(Z),10,10), " ", str(cimag(Z),10,10), "\n")
$Z2 = cmult(Z, Z);
#debug concat(str(creal(Z2),10,10), " ", str(cimag(Z2),10,10), "\n")
$Z2 = cpow(Z, 2);
The expected result is that the second and third line should be identical
(or at least almost identical), since 'Z*Z' is the same thing as 'Z^2'.
However, the cpow() function seems to work extremely buggy. At least
in this Solaris 7 that code outputs the following:
2.0000000000 0.0000000000
4.0000000000 0.0000000000
0.7338278990 3.9321109616
The second line (ie. the result of cmult(Z,Z)) is ok, but the third
line (result of cpow(Z,2)) seems to be completely wrong.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Warp <war### [at] tag povray org> wrote in message news:39229572@news.povray.org...
> Try this:
> $Z = <2, 0>;
> $Z2 = cmult(Z, Z);
> $Z2 = cpow(Z, 2);
identical
The cpow function needs both arguments to be 'complex';
To do Z^2 with cpow, you need to do cpow(Z,<2,0>)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
david sharp <dsh### [at] interport net> wrote:
: The cpow function needs both arguments to be 'complex';
: To do Z^2 with cpow, you need to do cpow(Z,<2,0>)
Ah, ok.
I said this by mail already, but let me say it again here:
It would be more intuitive if cpow() would accept either a float or
a complex.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Warp <war### [at] tag povray org> wrote in message news:3922afc2@news.povray.org...
> Ah, ok.
> a complex.
That would be helpful, but implementation is complicated
by the way POV-Ray promotes a float (say 2.0) to a VECTOR
(becomes <2.0,2.0,2.0> ) when it is expecting a vector. So
cpow(Z,2) becomes cpow(Z,<2,2>) rather than the desired
cpow(Z,<2,0>). The simplest way to implement float exponents
would be to have a new function (eg crpow(Z,X) )
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
