POV-Ray : Newsgroups : povray.unofficial.patches : MegaPov 0.5 Server Time
6 Jul 2026 05:16:19 EDT (-0400)
  MegaPov 0.5 (Message 41 to 43 of 43)
Subject: Re: MegaPov 0.5
Date: 18 May 2000 00:02:36
Message: <39236b5c@news.povray.org>
Glen Berry <7no### [at] ezwvcom> wrote...
> On Mon, 15 May 2000 12:21:48 -0400, "Nathan Kopp" <Nat### [at] Koppcom>
> wrote:
> >fixed Noise (this affects wrinkles, bozo, bumps, dents, turbulence, and
> >noise3d)
> Does this refer to the "plateau" effect? That would be good news.
It does, but watch out, because it can cause scenes, especially ones using
media with patterned density, to act differently than they used to.
-Nathan
Date: 19 May 2000 19:55:44
Message: <3925d480@news.povray.org>
My best regards for 0.5!
I found that next three lines  2345, 2346 and 2347
are unnecessary in file parse.c
In case that I miss the numbers:
 In function --Parse_Disc-- and enclosed in --#else-- and --#endif--
/* Calculate info needed for ray-disc intersections */
   VDot(Object->d, Object->center, Object->normal);
   Object->d = -Object->d;
And why:
in --Compute_Disc-- we have --Transform_Disc--
--Transform_Disc-- recalculate d.
Little feature request:
 disc{ <1,2,3>,<4,5,6>  } to be same as disc{ <1,2,3>,<4,5,6>, 1  }
Default radius is 1.0
I was try to made it, but...
      dmi### [at] xoommailcom
http://members.xoom.com/dmilos/
Nathan Kopp <Nat### [at] Koppcom> wrote in message
news:392024a9$1@news.povray.org...
> The Windows version of MegaPov 0.5 is finally ready for download!  The Mac
> version should be ready later today also, and hopefully other OSs will
> follow soon.
> You can get it here:
> http://nathan.kopp.com/patched.htm
> -Nathan Kopp
> May 15, 2000 - WinMegaPov 0.5 - 23 bug fixes, 5 new features, 6
> enhancements, 5 speed optimizations, 1 removal
> added new filters by Chris Huff for post processing: add, clip_colors,
> color_matrix, convolution_matrix, exponent, find_edges, invert, multiply,
> normal, patterned_blur, posterize, stars.
> added Chris Huff's inverse_transform patch
> added Chris Huff's parse-transform patch
> added pigment pattern (no more need for reset_children)
> added cross-section texturing (cutaway_texture)
> enhanced focal_blur post process to allow anti-aliasing
> enhanced motion blur to include support forlights
> enhanced error for post_process if no output file is used
> enhanced autostop
> enhanced pass_through
> enhanced post-processing to write to a separate file
> optimized macro speed
> optimized constant scattering media for speed
> optimized for speed with memory allocation caches
> optimized speed for planes, discs
> optimized speed for area_light
> removed #create (related to persistent scene objects - use 'label'
instead)
> fixed bug with photons on a texture_map
> fixed media method 3 brightness bug
> fixed a bug in orient area_lights
> fixed cylinder cameras (up and right vectors work again)
> fixed some photon gathering issues
> fixed continued render with post_process
> fixed smooth height field double illumination 'bug'
> fixed pict+post_process (Macintosh) bug
> fixed media transformation bug
> fixed memory leak in eval_pat
> fixed radiosity crash
> fixed macro bug
> fixed PNG+post_process bug
> fixed problem using #fread with a file containing garbage
> noise3d)
> fixed some speed problems
> fixed #version precision errors problems
> fixed macro speed problem (for unused macros)
> fixed %s error line bug
> fixed the cabs2,creal, and cimg bugs
> fixed DOS macro problems (read files as binary)
> fixed potential crash problem
> fixed bug with global ini options for image width and height
Date: 20 May 2000 13:16:27
Message: <sMYmOdRCOWm45Ppj8mNd8JrsNvKJ@4ax.com>
On Sat, 20 May 2000 02:00:29 +0200, "Dejan D. M. Milosavljevic"
Are you sure you wouldn't prefer a default radius of 0.5? That would
provide a "unit disc", with a *diameter* of 1. That seems more useful
to me.
Later,
Glen Berry
