Alain CULOS wrote:
> <snip>
> Thanks to both replies, I'll do my best at recompiling (some weeks
> down the road given my current speed there).
> I think C dlls with cygwin are OK, whereas C++ might cause problems
> due to name mangling being different. But in any case it would be
> a good exercise should I wish to generate my own functions for the
> iso surface patch.
> I'll let you know how I get on (be patient though).
I recently compiled the superpatch with djgpp, which has no
support or easy work around (so far as i can tell) for dll's.
What i did for the ridged multifractal was just cut and paste
the code from fractal.c into isofuncs.c. What is amazing
is that it actually works. of course, it not a "library"
function now, but a) that saves typing in the library
particulars, and b) its not like it made povray much bigger.
As a matter of fact, i did the same thing with all those
i_*.c files except the the 3d density file, which i haven't
gotten around to figuring out.
Can you send me copies of the binaries and the modified
files so I can put them online?
