POV-Ray : Newsgroups : povray.unofficial.patches : bug mac megapov ? Server Time
28 Jun 2024 22:50:56 EDT (-0400)
  bug mac megapov ? (Message 1 to 7 of 7)
Subject: bug mac megapov ?
Date: 31 Mar 2005 08:04:53
Message: <kurtzlepirate-C10EEF.15045331032005@news.povray.org>
hello,
suppose you have this code :
object {
  texture { T_Brass_1C }
object {
  texture { T_Brass_2D }
object {
  texture { T_Brass_4A }
you decide to transform Brass to Gold. Going to "Edit"->"Find/Replace..."
in the dialog, you type :
  Search for : T_Brass
  Replace : T_Gold
and clic on "Replace all". then your code seems to :
object {
  texture { T_Gold _1C }
object {
  texture { T_Gold _2D }
object {
as you see, there is <space> beteewn T_Gold and the others part of the
texture name.
it seems that copy/paste and find/replace works strangely adding or not
adding <space> before or after others words.
any one can confirm this ?
regards,
klp
Subject: Re: bug mac megapov ?
Date: 31 Mar 2005 10:35:00
Message: <web.424c188030b7dba5a8399d8d0@news.povray.org>
hi,
i don't have a mac, but i assume the 4A -> 1C change is a copy-paste
error...
works ok in official povray 3.6 (windows) and Megapov 1.1 (windows),
so it probably is specific to the mac version.
are you sure there was no extra space in the replace field?
(when passing a new text into the field)
does it only happen when you replace a 7-character string with a 6-character
one?
jaap.
Date: 31 Mar 2005 10:35:54
Message: <1guau4h.1xxjgbb1u7ck32N%yvo.s@gmx.net>
kurtz le pirate <kur### [at] yahoofr> wrote:
This looks like a bug.
We will fix it for the next version.
Thanks for reporting this!
Yvo
MegaPOV at:  http://megapov.inetart.net
MacMegaPOV at:  http://users.skynet.be/smellenbergh
E-mail: yvo### [at] gmxnet
Date: 31 Mar 2005 10:40:57
Message: <kurtzlepirate-00B1BF.17405731032005@news.povray.org>
In article <web.424c188030b7dba5a8399d8d0@news.povray.org>,
 "Jaap" <jws### [at] yahoocom> wrote:
>>hi,
>>error...
>>one?
>>jaap.
  hi jaap, are looking at the subject : "bug MAC MEGAPOV" :))
  klp
Date: 31 Mar 2005 10:41:34
Message: <kurtzlepirate-31BED8.17413431032005@news.povray.org>
In article <1guau4h.1xxjgbb1u7ck32N%yvo.s@gmx.net>,
>>Yvo
  hi yvo, yes it's look like... do you use "waste" ?
  klp
Date: 31 Mar 2005 10:48:25
Message: <424c1bc9$1@news.povray.org>
>>>Yvo
If so, the corrct solution would be to disable
WEFeatureFlag(weFIntCutAndPaste, weBitClear, wasteHandle).
However, find and replace should not be implemented via cut/copy and paste
in the first place.  WESetSelection and WEInsert are more suitable for it.
	Thorsten
Date: 31 Mar 2005 11:58:59
Message: <1guaxqk.xcyjbep19y80N%yvo.s@gmx.net>
Yes, I do use WASTE. The most recent version but it has been so long
since I looked at that code that I don't even know which version it is.
I think I use WESetSelection and WEInsert but don't know for sure. Like
I said, it must be more than one year ago since I looked at that part of
the code.
But, I will fix it for 1.2 or sooner.
Yvo
