POV-Ray : Newsgroups : povray.unofficial.patches : An updated povr tarball for Unix/Linux. b0bcf6c0 : Re: An updated povr tarball for Unix/Linux. b0bcf6c0 Server Time
25 Mar 2026 03:19:53 EDT (-0400)
Date: 28 Apr 2021 15:20:00
Message: <web.6089b512c0bd773c79819d986cde94f1@news.povray.org>
hi,
William F Pokorny <ano### [at] anonymousorg> wrote:
> On 4/28/21 12:27 PM, jr wrote:
> > "jr" <cre### [at] gmailcom> wrote:
> Thanks for trying. The --enable-silent-rules is probably not needed
> unless you've somehow overridden the tarball shipped default (...one can
> do it by various methods (the reason the enable and disable are always
> both available as configure options), but it is not common).
> Of course my compiles with your configure
> With the jitter.h issue could you try changing the two calls to rand()
> to std::rand() (a) and then at the top of jitter.h just after the
> comment about c++ variants of c includes add an include of cstdlib so it
> looks like:
> // C++ variants of C standard header files
> #include <cstdlib>
> Then try the make (the compiles) again?
> (a) - What those always should have been I think and the first thing I
> see which might be wrong. I see on searching a few more bare rand()
> calls sitting in the code too which might also cause you trouble
> compiling if this the issue (some in pattern.cpp). Hmm, wonder why those
> not an issue before for you if so...
tomorrow night.  factoid - when the alpha.10064268 was published, missing
'std::' prefixes were a problem.  cheers.
regards, jr.
