POV-Ray : Newsgroups : povray.unofficial.patches : Compiling UberPOV on Linux : Re: Compiling UberPOV on Linux Server Time
30 Mar 2026 19:28:41 EDT (-0400)
Date: 30 May 2019 05:51:41
Message: <5cefa7ad@news.povray.org>
On 5/30/19 4:58 AM, Bill Pragnell wrote:
> Aha, thanks for that. Those changes are not extensive, I'll just duplicate the
> fix in my local repo. Probably 'easier' than mucking about with boost, from
> where I'm sitting :)
> What's the best way to get those changes into UberPOV permanently? Is it
> possible to do some git magic to cherry pick those commits, or could I just
> apply the fix on an UberPOV branch and push it myself?
> Bill
> (maybe I should start signing off as Bill P just to confuse everyone :D)
Christoph is the only one who can update UberPOV and he's not worked
there in a long time.
There is a git cherry picking technique. I used exactly once years ago -
meaning I don't remember how to do it! Search for 'git cherry pick'.
The complication in grabbing things out of the main POV-Ray master
branch and moving it to UberPOV is the code is in some places
significantly different. I think this a reason why UberPOV didn't take
hold as a general test bed for things. I moved one branch to UberPOV
(never merged) and it collided with UberPOV changes. It meant a lot of
work which I only ever really made sure compiled - I didn't test the
features again as part of UberPOV. Also found myself with two branches
of the same feature. One off POV-Ray master and another off UberPOV. Too
much work.
If you want to run UberPOV specifically I'd recommend creating a branch
and just letting it sit there. If it's your only UberPOV branch, compile
and run that branch. If you end up with >1 let the branches, pull each
all into an 'UberBillP' branch off the UberPOV master branch and compile.
The last is what I've been doing. Several times a year I build a version
with the features I want off the current POV-Ray master. Down side is
it's getting to be a lot of branches to rebase/merge when the master
branch changes. I'm not a git expert. Perhaps there are better ways.
Bill P.
