POV-Ray : Newsgroups : povray.unofficial.patches : Re: preview of deform patch (53 kbu) : Re: preview of deform patch (53 kbu) Server Time
10 Oct 2026 14:01:43 EDT (-0400)
Date: 12 Dec 2000 08:37:35
Message: <3A362A1E.AE7BA4CE@enst.fr>
Wlodzimierz ABX Skiba wrote:
> deform begining and end of normal and calculate returned direction ?
> this is wrong method
> sure, at first I thought of it but this not works with deformations
> why ?
> look on top surface of deformed box from begining of this thread
> this is flat before and after deformation
> and normal is parallel to axis of deformation
> but imagine normal before deformation
> normal's end_point twist just like other points and after deformation
> normal is not parallel to axis of deformation
> and smaller normal not help, direction is direction
> explain more ?
	You're right, it probably cannot be done in a completely generic way
and would need to be done for each deformation. Mmm... maybe not as easy
as I first thought, let's see:
Let <nx, ny, nz> be the normal of the object before the deformation;
Let f be the transformation and fx, fy, fz its components;
Then the normal of the transformed point is:
<nx * dfx/dx + ny * dfy/dx + nz * dfz/dx,
 nx * dfx/dy + ny * dfy/dy + nz * dfz/dy,
 nx * dfx/dz + ny * dfy/dz + nz * dfz/dz>;
	Therefore, all that's needed is to be able to compute the various
df*/d*. In the case of the twist transform along the y axis:
fx = cos(k*y)*x - sin(k*y)*z
fy = y
fz = sin(k*y)*x + cos(k*y)*z
	And the transformed normal becomes:
<nx*cos(k*y) + nz*sin(k*y),
 nx*(-k*sin(k*y)*x-k*cos(k*y)*z) + ny + nz*(k*cos(k*y)*x-k*sin(k*y)*z),
 nx*(-sin(k*y)) + nz*cos(k*y)>
	Notice that for the flat faces, nx=0, ny=1 (or -1), nz=0 and the
transformed normal is correct.
	Hope this helps,
		Jérôme
********************************* Jérôme M. BERGER
* Abandon the search for truth, * mailto:ber### [at] inamecom
* Settle for a good fantasy.    * http://www.enst.fr/~jberger
