POV-Ray : Newsgroups : povray.unix : compile errors on fedora 24 Server Time
19 Mar 2026 00:06:27 EDT (-0400)
  compile errors on fedora 24 (Message 1 to 5 of 5)
Subject: compile errors on fedora 24
Date: 30 Jun 2016 23:30:01
Message: <web.5775e2cf8b4af27e66d820d0@news.povray.org>
i was able to get it to compile on fedora 23 but i get the following error on
fedora 24:
g++ -DHAVE_CONFIG_H -I. -I..  -I../unix/povconfig -I.. -I../unix -I../vfe
-I../vfe/unix -I/usr/include/SDL -D_GNU_SOURCE=1 -D_REENTRANT -pthread
-I/usr/include/OpenEXR -I/usr/include/libdrm  -pthread -I/usr/lib64/include
-I/usr/include  -pipe -Wno-multichar -Wno-write-strings -fno-enforce-eh-specs
-Wno-non-template-friend -s -O3 -ffast-math -march=native -Wno-multichar
-pthread -MT frontend/renderfrontend.o -MD -MP -MF $depbase.Tpo -c -o
frontend/renderfrontend.o frontend/renderfrontend.cpp &&\
mv -f $depbase.Tpo $depbase.Po
pov_frontend::RenderFrontendBase::NewBackup(POVMS_Object&,
         if(vd.imageBackup->write(&hdr, sizeof(hdr)) == false)
pov_frontend::RenderFrontendBase::ContinueBackup(POVMS_Object&,
pov_frontend::ViewData&, pov_frontend::RenderFrontendBase::ViewId, int&,
             if (inbuffer->read (&hdr, sizeof (hdr)) == false)
Makefile:1155: recipe for target 'frontend/renderfrontend.o' failed
make[2]: *** [frontend/renderfrontend.o] Error 1
make[2]: Leaving directory '/data2/archives/programs/povray-master/source'
Makefile:662: recipe for target 'all-recursive' failed
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory '/data2/archives/programs/povray-master'
Makefile:455: recipe for target 'all' failed
make: *** [all] Error 2
can anyone offer any assistance ?
Thank you
Subject: Re: compile errors on fedora 24
Date: 1 Jul 2016 02:28:10
Message: <57760d7a$1@news.povray.org>
> fedora 24:
> Thank you
Which version of code ? (stable or master branch ?)
What is the version of g++ on fedora 24 ?
Can you try another compiler ? (like clang)
(I only have an ubuntu here)
Date: 1 Jul 2016 19:15:01
Message: <web.5776f8f612783cf9e66d820d0@news.povray.org>
master 3.7.1-alpha.8656843
GCC 6.11
clang is available for fedora 24
what options do i set  to use it instead of gcc?
Date: 2 Jul 2016 02:03:43
Message: <5777593f@news.povray.org>
> GCC 6.11
Oh, interesting change, the default mode is gnu++14 instead of gnu++98
It seems IOBase is now missing something like
  operator bool()const{...}
but deeper analysis might be needed.
Or instead of ( X.write() == false ), it could be rewritten ( !(X.write()) == true )
or even ( !(X.write()) ) as == true is implicit
I guess that previously the operator const void*() was used by previous standard to
get an evaluation of the test
On the ./configure command line, add CXX=clang++ CC=clang
Date: 2 Jul 2016 12:25:01
Message: <web.5777e9ec12783cf9e66d820d0@news.povray.org>
Before trying clang i tried this:
.../configure COMPILED_BY="RSM"  --with-boost=/usr/lib64
--disable-io-restrictions
--with-boost-thread=boost_thread LIBS=-Lboost_system CXXFLAGS="-Wno-multichar
-std=gnu++98" LDFLAGS="-L/usr/lib64"
and make check worked
Thank you for your help Le_Forgeron
