POV-Ray : Newsgroups : povray.unix : RC7 compilation issues on ubuntu 12.10 Server Time
27 Jul 2024 14:35:45 EDT (-0400)
  RC7 compilation issues on ubuntu 12.10 (Message 1 to 10 of 12)
Subject: RC7 compilation issues on ubuntu 12.10
Date: 26 Feb 2013 16:30:00
Message: <web.512d2815d1ce46c22d84ff750@news.povray.org>
I recently installed ubuntu 12.10 alongside windows with wubi. After download of
Pov-Ray sources, ./configure says:
configure: error: in `/home/bruno/Documents/povray-3.7.0.RC7':
configure: error: C++ compiler cannot create executables
and config.log ends abruptly by:
#define HAVE_INTTYPES_H 1
#define HAVE_STDINT_H 1
#define HAVE_UNISTD_H 1
#define HAVE_STDLIB_H 1
configure: exit 1
Before investigating further, did anybody encounter the same issue, and/or does
have a quick answer ?
Thanks in advance.
Subject: Re: RC7 compilation issues on ubuntu 12.10
Date: 26 Feb 2013 17:46:00
Message: <512d3b28@news.povray.org>
> download of Pov-Ray sources, ./configure says:
> configure: exit 1
> does have a quick answer ?
> Thanks in advance.
You have to install "make" or "cmake"
Ger
Date: 26 Feb 2013 18:50:00
Message: <web.512d49cecef781282d84ff750@news.povray.org>
> > configure: exit 1
> > Thanks in advance.
> Ger
They are not installed by default? Surprising. Thanks for the tip.
Bruno
Date: 26 Feb 2013 18:55:00
Message: <web.512d4acfcef781282d84ff750@news.povray.org>
> > configure: exit 1
> > Thanks in advance.
> Ger
I installed cmake (make was available by default). Same behaviour. I appears
that my installation of ubuntu is probably corrupted. I'll try to get
confirmation for that. If so, I'll reinstall it all. :(
Bruno.
Date: 26 Feb 2013 22:30:20
Message: <512d7dcc@news.povray.org>
Am 27.02.2013 00:52, schrieb Bruno Cabasson:
Isn't it great how Linux wins big time over Windows in that it won't get
irrevocably fucked up over time as Windows would?
:-P
Date: 27 Feb 2013 04:09:18
Message: <512dcd3e$1@news.povray.org>
> configure: exit 1
> Thanks in advance.
You have of course installed g++, right ?
(C compiler is probably install by default, but IIRC not the C++ one)
In fact, you should have installed (with all dependencies):
    g++
    libboost-all-dev
    libpng12-dev
    libjpeg62-dev
    libtiff4-dev
    libopenexr-dev
    libsdl1.2-dev
(the "version" might vary, this was for 11.10, but I hope you get the idea)
Just because nobody complains does not mean all parachutes are perfect.
Date: 27 Feb 2013 07:36:26
Message: <512dfdca$1@news.povray.org>
>> appears
   Yes, except for Ubuntu... they copied this "feature" from MS. :)
   I think I'm going back to Fedora ASAP...
Jaime
Date: 27 Feb 2013 17:13:27
Message: <512e8507$1@news.povray.org>
> :-P
Been using Linux since 1998, never had that problem.  Looked like it was
a guess on Bruno's part.
Chances are there's just something missing in the build environment, or a
permissions error (usually configure tries to build a simple executable
and if it can't create one, it bombs out with that message).
Jim
Date: 27 Feb 2013 18:20:00
Message: <web.512e938bcef781282d84ff750@news.povray.org>
> > configure: exit 1
> > Thanks in advance.
>     g++
>     libboost-all-dev
>     libpng12-dev
>     libjpeg62-dev
>     libtiff4-dev
>     libopenexr-dev
>     libsdl1.2-dev
../configure finds gcc and does not complain until much further in the process.
gcc is not enough?
Date: 27 Feb 2013 18:26:43
Message: <512e9633$1@news.povray.org>
On Wed, 27 Feb 2013 18:15:23 -0500, Bruno Cabasson wrote:
> gcc is not enough?
Depends on what you're trying to build.
You probably need cpp as well, that may not be installed (not a Debian
guy myself, so I don't know precisely what packages are needed).
There often is a log file created by configure, if there is, have a look
to see what the specific error is that's generated. :)
Jim
