POV-Ray : Newsgroups : povray.unix : Make Install Fails Server Time
26 Feb 2026 01:01:08 EST (-0500)
  Make Install Fails (Message 1 to 4 of 4)
Subject: Make Install Fails
Date: 22 Mar 2011 14:40:01
Message: <web.4d88ecddf2ad36fdda1abfc20@news.povray.org>
Hi folks,
First of all fantastic bit of software you have here ...
Trying to install povray-3.7.0.RC3 on OS Ubuntu 64-bit 10.04
I followed the INSTALL text file and had a look around but I cannot seem to find
a solution to my problem...
I tried the following:
1.  I unzipped the source in /home/jpebe/dphil/apps/povray-3.7.0.RC3
2.  I configured using:
../configure COMPILED_BY="JP <...@inhibox.com>"
--with-boost=/usr/local/boost_1_46_1
--prefix=/home/jpebe/dphil/apps/povray-3.7.0.RC3/
3.  make check install  #without sudo since I have write permissions in the
prefix dir
4. This annoyingly fails with this error message:
Creating data directories...
Copying data files...
Creating documentation directories...
Copying documentation files...
Creating user directories...
chown: changing ownership of `/home/jpebe/.povray': Operation not permitted
chown: changing ownership of `/home/jpebe/.povray/3.7': Operation not permitted
make[2]: *** [install-data-local] Error 1
make[2]: Leaving directory `/mnt/jpebe/dphil/apps/povray-3.7.0.RC3'
make[1]: *** [install-am] Error 2
make[1]: Leaving directory `/mnt/jpebe/dphil/apps/povray-3.7.0.RC3'
make: *** [install-recursive] Error 1
Mind you -  I am logged in as user "jpebe", and the install part is the problem.
5. I did the chuck norris thing here and fired a "sudo make install" and the
installation than goes through...
BUT this is what I get:
~$ povray
povray: This is a RELEASE CANDIDATE version of POV-Ray. General distribution is
discouraged.
Segmentation fault
~$ /home/jpebe/dphil/apps/povray-3.7.0.RC3/bin/povray
discouraged.
No input file provided
Can anyone explain why is this? And can we have better error messages than
"Segmentation Fault" ?
Many thanks, awaiting eagerly anything which will get me a working povray
installation,
JP
Subject: Re: Make Install Fails
Date: 22 Mar 2011 14:50:04
Message: <4d88ef5c$1@news.povray.org>
> permitted chown: changing ownership of `/home/jpebe/.povray/3.7':
> Operation not permitted make[2]: *** [install-data-local] Error 1
You don't have permission to write to the destination directory.
make install is usually done as root, unless you're installing to a local
directory.  Check the ownership and rights to the indicated directory.
> ~$ povray
> distribution is discouraged.
> Segmentation fault
> ~$ /home/jpebe/dphil/apps/povray-3.7.0.RC3/bin/povray povray: This is a
> discouraged.
> than "Segmentation Fault" ?
You got one:  No input file provided.
Try launching with a valid command line and see how it works.  It
*shouldn't* segfault (BTW, that is passed by the OS, not by the program,
so there's not a lot the POV-Ray team can do to change that message since
it's generated by the OS).
You can get more info about the cause of the segfault and file a bug by
running it under gdb.
Jim
Date: 23 Mar 2011 06:05:01
Message: <web.4d89c5bc15d72a5eda1abfc20@news.povray.org>
I run the process as user "jpebe" and that is my home directory.
But somehow this directory (in ~/) is created under another user:
drwxrwxrwx  3 thomas thomas     4096 2011-03-22 18:15 .povray
?!  I cannot understand why this is happening..  even so everyone has
permissions to write to this directory...
> > ~$ povray
> > Segmentation fault
> > discouraged.
> Jim
How do you run povray using gdb ?
Date: 23 Mar 2011 06:37:13
Message: <4d89cd59$1@news.povray.org>
>>> ~$ povray
>>> Segmentation fault
>>> discouraged.
>> Jim
have to compile that in (gdb) ... using --enable-debug configure option,
and as the other jim noted you should provide some kind of command line
parameter ... try povray -version at the bare minimum just to test that
your build worked proper. here's a an article that can help get you
going with gdb:
http://www.ibm.com/developerworks/library/l-gdb/
to summarize first do:
gdb povray
then when you get the (gdb) prompt do:
run ~somepathname/to-a/scene-or-ini-file/test.pov
it should be in a directory that you have write capability
