POV-Ray : Newsgroups : povray.unix : Problems compiling 3.7.0.beta.38 on Fedora13 x86_64 Server Time
28 Oct 2024 08:27:49 EDT (-0400)
  Problems compiling 3.7.0.beta.38 on Fedora13 x86_64 (Message 1 to 7 of 7)
Subject: Problems compiling 3.7.0.beta.38 on Fedora13 x86_64
Date: 17 Aug 2010 08:30:00
Message: <web.4c6a7f6393917fda50048fb30@news.povray.org>
Hello,
I'm having some difficulties with building povray-3.7.0.beta.38 with Fedora 13
64-bit.
These are my POV-Ray specific configure options:
../configure COMPILED_BY="Chris3D <inf### [at] flare3dde>" --with-libpng=/usr/lib64
--with-zlib=/usr/lib64 --with-libjpeg=/usr/lib64 --with-libtiff=/usr/lib64
--with-openexr=/usr/lib64 --with-libsdl=/usr/lib64 --with-libmkl=/usr/lib64
When running make check I get an errormessage after a few minutes.
I can not figure out why I get this error. It doesn't seem to be a dependency
problem.
Here are the last few lines from the build process:
make[2]: Entering directory `/home/chris/src/povray-3.7.0.beta.38/unix'
.../source/backend/libbackend.a(boundingtask.o): In function
`pov::BSPProgress::operator()(unsigned int) const':
boundingtask.cpp:(.text._ZNK3pov11BSPProgressclEj[pov::BSPProgress::operator()(unsigned
int) const]+0xd1): undefined reference to `boost::this_thread::yield()'
.../source/backend/libbackend.a(tokenize.o): In function
`pov::Parser::Get_Token()':
tokenize.cpp:(.text+0x4f09): undefined reference to
.../source/backend/libbackend.a(radiositytask.o): In function
`pov::RadiosityTask::Run()':
radiositytask.cpp:(.text+0xd55): undefined reference to
`pov::RadiosityTask::CooperateFunction::operator()()':
radiositytask.cpp:(.text._ZN3pov13RadiosityTask17CooperateFunctionclEv[pov::RadiosityTask::CooperateFunction::operator(
)()]+0x21):
.../source/backend/libbackend.a(tracetask.o): In function
`pov::TraceTask::SupersampleOnePixel(double, double, pov_base::Colour&)':
tracetask.cpp:(.text+0x14b1): undefined reference to
.../source/backend/libbackend.a(tracetask.o):tracetask.cpp:(.text+0x1cb1): more
undefined references to `boost::this_thread::yield()' follow
make[2]: *** [povray] Fehler 1
make[2]: Leaving directory `/home/chris/src/povray-3.7.0.beta.38/unix'
make[1]: *** [all-recursive] Fehler 1
make[1]: Leaving directory `/home/chris/src/povray-3.7.0.beta.38'
make: *** [all] Fehler 2
Itried with my own boost build (boost 1.43):
../bootstrap.sh --prefix=/home/chris/Programme/boost
--libdir=/home/chris/Programme/boost/lib
../bjam install
Then I configured PovRay like this:
--with-boost=/home/chris/Programme/boost/
--with-boost-lib=/home/chris/Programme/boost/lib/
That gives me:
configure: error: cannot link with the boost thread library
I tried with:
--with-boost-thread=/home/chris/Programme/boost/lib/libboost_thread.so
But:
configure: error: Could not link against
boost_thread-/home/chris/Programme/boost/lib/libboost_thread.so !
Maybe you can help me. Thank you in advance.
Chris
Latest work with PovRay: http://flare3d.de/?page_id=30
Subject: Re: Problems compiling 3.7.0.beta.38 on Fedora13 x86_64
Date: 17 Aug 2010 09:05:09
Message: <4c6a8905$1@news.povray.org>
Le 17/08/2010 14:24, chris3d a écrit :
> Hello,
> 64-bit.
I wonder why you need to push /usr/lib64 to compile natively.
(but how could I know, I use a 64bit ubuntu... with only COMPILED_BY &
--disable-io-restrictions (personal taste), nothing more)
What is your "native" boost library package ? (version ?)
Ah ah! We are on something...
> ../bjam install
> That gives me:
> I tried with:
> But:
the switch for boost in configure are more than tricky.
For instance, --with-boost-thread=XXX would use the file named
libboost_thread-XXX (from default location of lib!)
Typical usage would be --with-boost-thread=mt.so.1.40.0
(in fact, typical would be to NOT use it!)
Also, from my bogus memory, I seems to recall that shared libraries must
be trusted to get linked, which usually means that if you install away
from usual place, the linking system must be updated: ld.so.conf should
get extended and ldconfig called to flush that (and that's a work for
root, beware, you can screw your system)
If you only install in usual places (already trusted directory), then
only ldconfig need to be called.
Real software engineers work from 9 to 5, because that is<br/>
the way the job is described in the formal spec.  Working<br/>
late would feel like using an undocumented external procedure.
Date: 17 Aug 2010 10:10:01
Message: <web.4c6a96fea6e978d650048fb30@news.povray.org>
thank you for thist fast answer.
I had to specify those paths. Otherwise I get an incopatible lib error when
compiling. Fedora uses /usr/lib and /usr/lib64
I have my self-compiled boost1.43 and the installed boost1.41 from the repo.
The devel package is installed as well.
Thank you for this information.
With: "--with-libboost_thread=mt.so.1.43.0" configure doesn't return errors but
I get the error when building.
I tried not to use it and build PovRay with installed boost1.41 from the
repository.
My configuration:
--with-boost-lib=/usr/lib64/
 ./configure runs fine with these settings but I have the same issue when
building.
I called ldconfig as root. No success at all when building PovRay.
__
Date: 17 Aug 2010 11:53:57
Message: <4c6ab095@news.povray.org>
Le 17/08/2010 16:08, chris3d nous fit lire :
> Hi,
It's the devel package you will be using when compiling & linking povray.
I did also on my time...
> repository.
> My configuration:
> building.
Oh yes... what does libboost_thread.so link to ? (in /usr/lib64/)
"grep BOOST_ Makefile" give me:
BOOST_CPPFLAGS = -pthread -I/usr/include
BOOST_LDFLAGS = -L/usr/lib
BOOST_THREAD_LIB = -lboost_thread-mt
Now the sad note is that configure seems to have hard-coded ".../lib"
for BOOST_LDFLAGS (and ".../include" for BOOST_CPPFLAGS)
So, if at least you can install the dev-boost in a good looking tree
(foo/lib & foo/include) you might get some easy way with a basic
--with-boost=foo
Side note info: http://blog.julipedia.org/2008/06/lib64-problems.html
Date: 17 Aug 2010 14:45:00
Message: <web.4c6ad7b0a6e978d650048fb30@news.povray.org>
> --with-boost=foo
I removed the boost1.41 and boost1.41-devel packages to ensure PovRay will use
my own boostbuild.
I build boost with --prefix=/home/chris/Programme/boost
That gives me:
/home/chris/Programme/boost/include
I tried different Boost Versions (1.37, 1.43, 1.44) but I didn't get PovRay
configured.
This is the ./configure output for boost with
--with-boost=/home/chris/Programme/boost:
checking for boostlib >= 1.37... yes
checking whether the Boost::Thread library is available... yes
checking for exit in -lboost_thread-gcc44-mt-1_37... yes
checking whether the boost thread library is usable... no
configure: error: in `/home/chris/src/povray-3.7.0.beta.38':
I can't understand why there is a linking problem with the boost thread library.
I read that other people had this problem but I didn't find any solution.
__
Date: 17 Aug 2010 15:25:00
Message: <web.4c6ae1dca6e978d650048fb30@news.povray.org>
> configured.
> __
Finally I solved the problem by creating the file /etc/ld.so.conf.d/boost.conf
with the content:
and then call ldconfig.
Thank you very much for helping.
Chris
__
Date: 27 Aug 2010 17:15:00
Message: <web.4c782aada6e978d6e9b811610@news.povray.org>
Thanks for this thread, as it helped me to figure out how to build povray with
standard boost library in fedora13 x86_64!
I ended up taking the spec from fedora12:
http://packages.atrpms.net/dist/f12/povray/
And changing LDFLAGS during the build process to work around hardcoded /usr/lib
entries:
%build
aclocal
automake -a -c
CXXFLAGS="-Wno-multichar"
%configure COMPILED_BY="Alec Istomin"  --with-boost-lib=/usr/lib64
--with-boost-thread=boost_thread-mt
export LDFLAGS="${LDFLAGS} -L/usr/lib64"
make
