POV-Ray : Newsgroups : povray.unix : Installation Problems Server Time
27 Jul 2024 14:19:02 EDT (-0400)
  Installation Problems (Message 1 to 4 of 4)
Subject: Installation Problems
Date: 1 Jun 2010 17:35:01
Message: <web.4c057c00f27d60cb9b6a4420@news.povray.org>
I am using Linux Mint 9 and have installed povray through synaptic package
manager.  The problem I am having is that I can't find the program launcher
anywhere.  If I "povray" in terminal I just get a bunch of info concerning the
program.  Can anyone help me with getting the the GUI for the program?
Subject: Re: Installation Problems
Date: 1 Jun 2010 18:19:24
Message: <4c05876c@news.povray.org>
There is no unix/linux gui for povray ... a text editor (gedit or the
like) is used to create the scene description file and it is submitted
to the povray program via command line options/arguments. If the version
of povray that you have installed was built with the proper libraries
you can get a display of the render as it's taking place.
In my case, I use gedit to create the scene file, and have a bash script
that runs the render job, I also use  ini files to help keep track of
the options that I want povray to use:
My bash script has:
povray Work Options[RadiositySave] Options[NoDisplay] +w640 +h480
and I just run that from the command line.
the 1st arg (Work) looks in Work.ini for some general options, I also
have Options.ini were the RadiositySave, and NoDisplay options (among
others are defined) ... the +w640 and +h480 is self explanitory if
you've read the docs :-)
Jim
Date: 2 Jun 2010 01:02:30
Message: <4c05e5e6@news.povray.org>
  See also:
http://wiki.povray.org/content/Knowledgebase:Miscellaneous#Topic_10
Date: 2 Jun 2010 07:57:52
Message: <4c064740@news.povray.org>
$ man gvim
