POV-Ray : Newsgroups : povray.unix : povray 3.5 beta 34 make error Server Time
28 Oct 2024 08:26:33 EDT (-0400)
  povray 3.5 beta 34 make error (Message 1 to 6 of 6)
Subject: povray 3.5 beta 34 make error
Date: 27 Feb 2010 09:10:00
Message: <web.4b8927285023ba9831b681150@news.povray.org>
I'm trying to compile the povray beta in a archlinux 64 bits installation, but
the compilation fails after a lot of warnings (from png.cpp)
here's a little part:
(declared at /usr/include/png.h:640)
/usr/include/png.h:1082)
make[3]: *** [png.o] Error 1
make[3]: Leaving directory `/home/ineluki/povray-3.7.0.beta.34/source/base'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/ineluki/povray-3.7.0.beta.34/source'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/ineluki/povray-3.7.0.beta.34'
make: *** [all] Error 2
The libpng version (if it has anything to do with that) is 1.4.0-2
Subject: Re: povray 3.5 beta 34 make error
Date: 1 Mar 2010 23:20:11
Message: <20100302012010.602aa200.john@johncoppens.com>
On Sat, 27 Feb 2010 09:07:36 EST
> installation, but the compilation fails after a lot of warnings (from
> png.cpp)
Those are just warnings. There must be a real Error message higher up in
the output. Look for that message to detect where the problem is.
John
Date: 1 Mar 2010 23:21:32
Message: <20100302012131.eb429904.john@johncoppens.com>
> png.cpp)
You can redirect the output of the compilation to a file adding
make 2> logfile.txt
and then look for the message.
John
Date: 2 Mar 2010 06:45:00
Message: <web.4b8cf962e9b66284c0a46e4c0@news.povray.org>
Ok thank you,
Found it:
and the same but on the line 462
Date: 2 Mar 2010 07:06:57
Message: <4b8cff61$1@news.povray.org>
libpng changed some interfaces in 1.4 forward, so you need to use a pre-1.4
version of libpng or change the source code accordingly.
	Thorsten
Date: 7 Mar 2010 11:30:00
Message: <web.4b93d414e9b66284c0a46e4c0@news.povray.org>
>  Thorsten
Ok, thanks! :)
