POV-Ray : Newsgroups : povray.unix : Command switch for batch (no result window) Server Time
27 Jul 2024 14:28:16 EDT (-0400)
  Command switch for batch (no result window) (Message 1 to 2 of 2)
Subject: Command switch for batch (no result window)
Date: 4 Nov 2009 23:20:00
Message: <web.4af251ffcd4f2446acdf45960@news.povray.org>
Is there an command-line option or an environment variable to set to prevent the
render window from popping up?  I'd like to povray in batch if possible.
I thought this would be obvious, but after an hour of searching, I've found
nothing.  Thanks for any help!
-Tom
Subject: Re: Command switch for batch (no result window)
Date: 5 Nov 2009 00:08:11
Message: <4af25dbb$1@news.povray.org>
-D should do the job.
