![](/i/fill.gif) |
time povray -benchmark
povray: this pre-release version of POV-Ray for Unix expires in 0 day(s) and 11
hour(s)
POV-Ray 3.7.0.beta.32 (g++ 4.3.3 @ x86_64-unknown-linux-gnu)
Entering the standard POV-Ray 3.7 benchmark version 2.01.
Running standard POV-Ray benchmark version 2.01
Persistence of Vision(tm) Ray Tracer Version 3.7.0.beta.32 (g++ 4.3.3 @
This is an unofficial beta-test version compiled by:
me
Support libraries used by POV-Ray:
ZLib 1.2.3.3, Copyright 1995-1998 Jean-loup Gailly and Mark Adler
LibPNG 1.2.27, Copyright 1998-2002 Glenn Randers-Pehrson
LibJPEG 62, Copyright 1998 Thomas G. Lane
LibTIFF 3.8.2, Copyright 1988-1997 Sam Leffler, 1991-1997 SGI
Boost 1.37, http://www.boost.org/
Parser Options
Input file: /tmp/pov5057.pov (compatible to version 3.50)
Remove bounds........On
Split unions.........Off
Library paths:
/usr/local/share/povray-3.7/include
==== [Parsing...] ==========================================================
Building mesh2:
- vertex_vectors
- normal_vectors
- uv_vectors
- face_indices
Parse Warning: gamma_correction not specified or inferred so is turned off for
compatibility with this pre POV-Ray 3.7 scene. See the documentation for more
details.
Parser Statistics
Finite Objects: 40
Infinite Objects: 2
Light Sources: 2
Total: 44
Parser Time
Parse Time: 0 hours 0 minutes 0 seconds (0.648 seconds)
using 1 thread(s) with 0.647 CPU-seconds total
Bounding Time: 0 hours 0 minutes 0 seconds (0.000 seconds)
using 1 thread(s) with 0.000 CPU-seconds total
Render Options
Quality: 9
Bounding boxes.......On Bounding threshold: 3
Antialiasing.........On (Method 1, Threshold 0.300, Depth 3, Jitter 0.30)
==== [Rendering...] ========================================================
Rendered 262144 of 262144 pixels (100%)
Render Statistics
Image Resolution 512 x 512
Pixels: 294912 Samples: 661365 Smpls/Pxl: 2.24
Rays: 1568267 Saved: 5046 Max Level: 12/12
Ray->Shape Intersection Tests Succeeded Percentage
Box 12558929 12558684 100.00
Cone/Cylinder 25127964 9645688 38.39
CSG Intersection 18633660 7304846 39.20
CSG Merge 398311 49287 12.37
Fractal 1136966 177408 15.60
Height Field 1622965 174752 10.77
Height Field Box 1622965 1244421 76.68
Height Field Triangle 6035741 180097 2.98
Height Field Block 10319941 3108964 30.13
Height Field Cell 41767205 3313029 7.93
Isosurface 21734747 787684 3.62
Isosurface Container 21735247 21735234 100.00
Isosurface Cache 192124 12619 6.57
Mesh 1161047 108655 9.36
Plane 20555445 1217639 5.92
Sphere 3476388 2197305 63.21
Superellipsoid 344906 81130 23.52
Torus 3023083 719720 23.81
Torus Bound 3023083 827697 27.38
True Type Font 35348 12634 35.74
Clipping Object 2818749 1331937 47.25
Bounding Box 388552806 157279779 40.48
Isosurface roots: 21719591
Function VM calls: 298619438
Crackle Cache Queries: 657509
Crackle Cache Hits: 652914 ( 99 percent)
Roots tested: 827697 eliminated: 552809
Shadow Ray Tests: 21972478 Succeeded: 7572012
Shadow Cache Hits: 2980211
Reflected Rays: 242117 Total Internal: 13
Refracted Rays: 161119
Transmitted Rays: 203995
Render Time:
Photon Time: 0 hours 0 minutes 0 seconds (0.296 seconds)
using 11 thread(s) with 0.367 CPU-seconds total
Radiosity Time: No radiosity
Trace Time: 0 hours 1 minutes 4 seconds (64.907 seconds)
using 8 thread(s) with 503.081 CPU-seconds total
POV-Ray finished
real 1m6.865s
user 8m23.919s
sys 0m0.272s
rg@lnx1:~/povray-3.7.0.beta.32$
![](/i/fill.gif) |
