POV-Ray : Newsgroups : povray.unix : benchmark Beta-32, Intel i7 920, 2.66 Ghz, 8 cores, x86_64 ubuntu 9.04 Server Time
27 Jul 2024 14:36:36 EDT (-0400)
  benchmark Beta-32, Intel i7 920, 2.66 Ghz, 8 cores, x86_64 ubuntu 9.04 (Message 1 to 1 of 1)
Subject: benchmark Beta-32, Intel i7 920, 2.66 Ghz, 8 cores, x86_64 ubuntu 9.04
Date: 31 May 2009 07:15:00
Message: <web.4a226577e12360181a402b30@news.povray.org>
time povray -benchmark
povray: this pre-release version of POV-Ray for Unix expires in 0 day(s) and 11
hour(s)
POV-Ray 3.7.0.beta.32 (g++ 4.3.3 @ x86_64-unknown-linux-gnu)
Entering the standard POV-Ray 3.7 benchmark version 2.01.
Running standard POV-Ray benchmark version 2.01
Persistence of Vision(tm) Ray Tracer Version 3.7.0.beta.32 (g++ 4.3.3 @
This is an unofficial beta-test version compiled by:
 me
Support libraries used by POV-Ray:
  ZLib 1.2.3.3, Copyright 1995-1998 Jean-loup Gailly and Mark Adler
  LibPNG 1.2.27, Copyright 1998-2002 Glenn Randers-Pehrson
  LibJPEG 62, Copyright 1998 Thomas G. Lane
  LibTIFF 3.8.2, Copyright 1988-1997 Sam Leffler, 1991-1997 SGI
  Boost 1.37, http://www.boost.org/
Parser Options
  Input file: /tmp/pov5057.pov (compatible to version 3.50)
  Remove bounds........On
  Split unions.........Off
  Library paths:
    /usr/local/share/povray-3.7/include
==== [Parsing...] ==========================================================
 Building mesh2:
   - vertex_vectors
   - normal_vectors
   - uv_vectors
   - face_indices
Parse Warning: gamma_correction not specified or inferred so is turned off for
 compatibility with this pre POV-Ray 3.7 scene. See the documentation for more
 details.
Parser Statistics
Finite Objects:           40
Infinite Objects:          2
Light Sources:             2
Total:                    44
Parser Time
  Parse Time:       0 hours  0 minutes  0 seconds (0.648 seconds)
              using 1 thread(s) with 0.647 CPU-seconds total
  Bounding Time:    0 hours  0 minutes  0 seconds (0.000 seconds)
              using 1 thread(s) with 0.000 CPU-seconds total
Render Options
  Quality:  9
  Bounding boxes.......On   Bounding threshold: 3
  Antialiasing.........On  (Method 1, Threshold 0.300, Depth 3, Jitter 0.30)
==== [Rendering...] ========================================================
Rendered 262144 of 262144 pixels (100%)
Render Statistics
Image Resolution 512 x 512
Pixels:           294912   Samples:          661365   Smpls/Pxl: 2.24
Rays:            1568267   Saved:              5046   Max Level: 12/12
Ray->Shape Intersection          Tests       Succeeded  Percentage
Box                           12558929        12558684    100.00
Cone/Cylinder                 25127964         9645688     38.39
CSG Intersection              18633660         7304846     39.20
CSG Merge                       398311           49287     12.37
Fractal                        1136966          177408     15.60
Height Field                   1622965          174752     10.77
Height Field Box               1622965         1244421     76.68
Height Field Triangle          6035741          180097      2.98
Height Field Block            10319941         3108964     30.13
Height Field Cell             41767205         3313029      7.93
Isosurface                    21734747          787684      3.62
Isosurface Container          21735247        21735234    100.00
Isosurface Cache                192124           12619      6.57
Mesh                           1161047          108655      9.36
Plane                         20555445         1217639      5.92
Sphere                         3476388         2197305     63.21
Superellipsoid                  344906           81130     23.52
Torus                          3023083          719720     23.81
Torus Bound                    3023083          827697     27.38
True Type Font                   35348           12634     35.74
Clipping Object                2818749         1331937     47.25
Bounding Box                 388552806       157279779     40.48
Isosurface roots:          21719591
Function VM calls:        298619438
Crackle Cache Queries:          657509
Crackle Cache Hits:             652914 ( 99 percent)
Roots tested:                827697   eliminated:               552809
Shadow Ray Tests:          21972478   Succeeded:               7572012
Shadow Cache Hits:          2980211
Reflected Rays:              242117   Total Internal:               13
Refracted Rays:              161119
Transmitted Rays:            203995
Render Time:
  Photon Time:      0 hours  0 minutes  0 seconds (0.296 seconds)
              using 11 thread(s) with 0.367 CPU-seconds total
  Radiosity Time:   No radiosity
  Trace Time:       0 hours  1 minutes  4 seconds (64.907 seconds)
              using 8 thread(s) with 503.081 CPU-seconds total
POV-Ray finished
real 1m6.865s
user 8m23.919s
sys 0m0.272s
rg@lnx1:~/povray-3.7.0.beta.32$
