POV-Ray : Newsgroups : povray.unix : Debugging and line numbers Server Time
13 Sep 2025 00:05:06 EDT (-0400)
  Debugging and line numbers (Message 1 to 10 of 26)
Subject: Debugging and line numbers
Date: 2 Feb 2009 11:55:00
Message: <web.4987253e77e9544e28aa539a0@news.povray.org>
So now I got very frequent segfaults in my development version of POV-Ray -
frequent enough to be reproducible even with the non-optimized debug version
within a few seconds. Time to track them down with valgrind and gdb.
Hum... so now I know in which *function* it crashes - but what do I have to do
in order to get the *line number*??
Digging through assembler code and trying to match it with the C++ source code
is a bit cumbersome, so I guess there *must* be an easier way... even Linux
jockeys can't be *that* masochistic :)
I knew I wouldn't like debugging under Linux :S
Subject: Re: Debugging and line numbers
Date: 2 Feb 2009 13:13:31
Message: <498737cb@news.povray.org>
ay -
rsion
e to do
ce code
inux
To debug, you should run povray with gdb. Then you'll be able to add
breakpoint and/or view the stack-trace on a segfault
another way is to integrate povray sources in a project under KDevelop
and then run in debug mode .. it will show you the "wrong" code
good luck
Date: 2 Feb 2009 13:21:56
Message: <498739c4$1@news.povray.org>
> POV-Ray - frequent enough to be reproducible even with the non-optimized
> debug version within a few seconds. Time to track them down with
> valgrind and gdb.
> to do in order to get the *line number*??
> source code is a bit cumbersome, so I guess there *must* be an easier
> way... even Linux jockeys can't be *that* masochistic :)
I'd second Thierry's suggestion - make sure you also compile with
symbolic information enabled (-g as I recall).
Another approach would be to run the program under strace.  gdb will give
you the ability to look at the call stack, though, where strace will just
give you a starting point.
Jim
Date: 2 Feb 2009 13:40:00
Message: <web.49873d84c31877f33ed8bee0@news.povray.org>
I can get a stack trace from the coredump - but it doesn't show line numbers.
I can also get interesting information from valgrind - but it doesn't give me
line numbers either.
.... and I'm not really eager to set up some KDevelop project:
- Getting an existing project to compile in yet another IDE typically sucks.
- Getting it to compile in an IDE you don't know sucks even more.
- Getting it to compile in an IDE you haven't even installed (ever) sucks like
crazy.
- Getting it to compile in an IDE that, by its name, seems to require a GUI
(KDE) you haven't even installed (ever) promises to be really sucking like
hell.
If I had my way, I'd prefer that sneaky piece of software to crash on my Windows
machine as well, where I have a nice, familiar IDE at hand and a project already
set up for it :S
Date: 2 Feb 2009 14:16:37
Message: <49874695$1@news.povray.org>
mbers.
ive me
If you compile your code using -g (or -dgdb if you plan to use gdb and
get some more specific results) you will have row numbers :
man gcc :
        -g*level*
       Request debugging information and also use level to specify how
       much information.  The default level is 2.
       Level 0 produces no debug information at all.  Thus, -g0 negates
       -g.
       Level 1 produces minimal information, enough for making backtraces
       includes descriptions of functions and external variables, but no
       information about local variables and no line numbers.
       Level 3 includes extra information, such as all the macro
       definitions present in the program.  Some debuggers support macro
       expansion when you use -g3.
ucks.
ks like
> crazy.
 GUI
ike
> hell.
y Windows
t already
> set up for it :S
Date: 2 Feb 2009 15:20:00
Message: <web.4987554bc31877f33ed8bee0@news.povray.org>
I guess I'll need to figure out which of these are set by the ./configure
options available for POV-Ray, and how the Intel compiler deals with them...
Thanks for the info.
Date: 2 Feb 2009 16:38:10
Message: <498767c2$1@news.povray.org>
re
em...
try a ./configure --enable-debug=full, it should be OK
Date: 5 Feb 2009 13:19:55
Message: <498b2dcb$1@news.povray.org>
clipka escreveu:
http://sourceware.org/gdb/current/onlinedocs/gdb_9.html#SEC57
In particular:
"When your program stops, GDB spontaneously prints the line where it
stopped. Likewise, when you select a stack frame (see section Selecting
a Frame), GDB prints the line where execution in that frame has stopped.
You can print other portions of source files by explicit command."
Some commands:
next
step
list linenumber
list functionname
etc
Not really that bad if you RTFM. ;)
I might too that both vim and emacs support fluid integrated interfaces
to the whole dev stack:  make, gcc and gdb.  Of course, it would need
you to learn a bit of these very different tools, something not
happening when you seem reluctant to try even KDevelop and it's VS-like
workflow...
Date: 5 Feb 2009 13:22:07
Message: <498b2e4f$1@news.povray.org>
nemesis escreveu:
errata:
> I might add too
Date: 6 Feb 2009 12:15:00
Message: <web.498c6f91c31877f3bdc576310@news.povray.org>
You know how F those M's are to R if all you want to do is just to figure out
where a program crashed on a Linux system, when otherwise you basically do all
development under windows? ;)
I mean, it's not like they have any "quick start" sections (or I'm R'ing T wrong
FM's...)
