![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I'm trying to compile the Unix beta sources under Tiger and I've installed the
boost libraries, the configure is detecting them, but I keep getting a
configuration error "Could not link against boost_thread"
I'm not what you would call conversant with Terminal, so if anyone could help me
with this problem, I'd be grateful.
A.D.B
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> A.D.B
Anthony,
I too am having the same issue (although not with OSX) and am looking for a
resolve for this.
I run a Phenom X4 9600 Black Edition (AMD Quad 2.3GHz Unlocked CPU) under Fedora
8 x64 (2.6.24.3-12.fc8) with all the current libraries and updates.
Povray 3.6.1 is installed (and is currently fully functional - although it only
uses a single core per session).
I know this doesn't help you in any way, but at least you can rest assured that
you are not alone with this issue :)
If anyone does know of a solution, I too would be very grateful.
Tanx!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Please mail me the config.log file that configure has generated.
- NC
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> - NC
Was this problem solved? I'm having the same issue here... I can send the
config.log if desired.
John
PS: and the last linux beta binary won't run because of the "Timed out waiting
for worker thread startup" problem.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> John
Mmm. I'm suspecting the problem is due to the fact the 'boost' libraries are
only installed as static (non-shared) versions. Could this be the problem?
John
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> John
Just for the record - and then I'm off to bed, it's 3 AM here:
I installed the shared versions of the boost libraries and still cannot compile
the povray source:
checking for exit in -lboost_thread-mt... no
checking for exit in -lboost_thread-boost_thread-mt... no
configure: error: Could not link against boost_thread-boost_thread-mt !
And, important, but I forgot to mention this: I have this problem on Linux
not MacOS.
John
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> not MacOS.
> John
Ok. Solved! The Boost package installed the libraries under another name:
libboost_thread-gcc42-mt.so
so povray couldn't find it. I suspect on MacOS something similar must happen.
so I symlinked:
ln -s libboost_thread-gcc42-mt-1_36.so.1.36.0 libboost_thread-mt.so
and config went well. Now I'm having issues with the compilation...
John
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yes, you need a pre-1.35 boost.
Thorsten, POV-Team
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Sat, 16 Aug 2008 09:37:30 +0200
Hello Thorsten,
Is that really necessary - I mean is there another reason besides the
compilation problems?
BTW, the symlink I proposed wasn't the correct solution for compiling.
This only solved the configuring. To also compile correctly, it is just
necessary to do:
./configure COMPILED_BY="your name <email>" \
--with-boost-thread=boost_thread-gcc42-mt
This still leaves a runtime timing problem which can be solved by editing
vfesession.cpp as proposed by a mail on the pov-lists.
John
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: compiling unix betas under OS X 10.4
Date: 16 Aug 2008 15:56:52
Message: <48a73104@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Hello Thorsten,
Yes, the boost thread interface changed in 1.35 for certain reasons. You
absolutely positivity cannot use it.
Thorsten
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
