I have a question to gnome experts :
I know how to keep on top a povray window in kde with "kstart --keepabove povray
+i...."
Does anyone know what is the equivalent in a gnome environement ?
Thanks
Fabien
ve povray
> +i...."
> Thanks
> Fabien
there is no equivalent, but kstart might work too (it works for the
desktop on wich to show the window)
Right mouse click on window title will give you a menu where you can
select what you want. Unfortunately I don't know a command line solution.
My two eurocents,
Bonsai
___ __ __ _ ___ ___ _
| _ ) \ \( ) _) _ )( )
| _ \() |\ \ |\ \/ _ \| |
|___/__/_)\__)___)/ \_)_)
www.b0n541.net
> ve povray
> > +i...."
> > Thanks
> > Fabien
I guess that for this trick to work that konqueror or something alike has to be
installed somewhere in your system. Would it work on a 100 % gnome system ?
Fabien
Bonsai <bon### [at] b0n541net> wrote:
> Hi,
> My two eurocents,
> Bonsai
> www.b0n541.net
After some googling, I found devil spie, but to make it work seems tricky. Has
anyone been able to make it work ?
Fabien
>> Hi,
>> solution.
> tricky. Has anyone been able to make it work ?
Well, I often will flag a window as "Always on Top"; but if you're
developing a program, as an end-user, I'd implore you not to decide
what's most important to be in the foreground on my desktop, please.
I absolutely hate when apps decide to steal the focus from what I'm
interested in looking at.
Jim
> >> Hi,
> >> solution.
> Jim
In wxpyvon, the user can decide whether they want to keep the render window
"Always on Top" or not in the menu.
The kstart trick works in kde, but I have to find a way around for gnome.
Cheers,
Fabien
> window "Always on Top" or not in the menu.
> gnome.
Well, even without the kstart trick, the user still has the option to use
the menu to set that for a particular render...
Jim
