![](/i/fill.gif) |
I'm trying to figure out how use anti-aliasing with povray on linux and I
can't find any documentation on this. I don't know if this is standard, but
I use a shell to render images. So command line:
povray file_name.pov +W1280 +H960
To use anti_aliasing how would I modify this command, and specify a
threshold and all that?
Thanks,
Sebastian
![](/i/fill.gif) |
![](/i/fill.gif) |
On Fri, 14 Sep 2007 10:41:20 -0400, Sebastian wrote:
man povray gives (among other things)
Tracing options:
MBn or Bounding=bool Bounding_Threshold=integer
Use automatic bounding slabs if more than n objects are
in the
scene.
Qn or Quality=integer
Render at quality n. Qualities range from 0 for rough
images
and 9 for complete ray-tracing and textures, and 10 and
11 add
radiosity.
A0.n or Antialias=bool Antialias_Threshold=integer
Do antialiasing on the pixels until the difference between
adja‐
cent pixels is less that 0.n, or the maximum recursion
depth is
reached.
AMn or Sampling_Method=integer
Specify the method of antialiasing used, non-adaptive (n
= 1),
or adaptive antialiasing (n = 2).
Jn.n or Jitter=bool Jitter_Amount=float
Specify maximum radius, in pixels, that antialiased
samples
should be jittered from their true centers.
Rn or Antialias_Depth=integer
Set the maximum recursion depth for antialiased pixel sub-
sam‐
pling.
UA or Output_Alpha=bool
Use alpha channel for transparency mask.
UL or Light_Buffer=bool
Use light buffer to speed up rendering.
UV or Vista_Buffer=bool
Use vista buffer to speed up rendering.
HTH.
Jim
![](/i/fill.gif) |
