![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
icc compilers the povray perfectly, however obtained binary can't run,
generates the following message:
Persistence of Vision(tm) Ray Tracer Version 3.6.1 (icc 9.1 @
ia64-unknown-linux-gnu)
This is an unofficial version compiled by:
RedAndr
The POV-Ray Team(tm) is not responsible for supporting this version.
POV-Ray is based on DKBTrace 2.12 by David K. Buck & Aaron A. Collins
Copyright 1991-2003 Persistence of Vision Team
Copyright 2003-2004 Persistence of Vision Raytracer Pty. Ltd.
Primary POV-Ray 3.5/3.6 Developers: (Alphabetically)
Chris Cason Thorsten Froehlich Nathan Kopp Ron Parker
Contributing Authors: (Alphabetically)
Steve Anger Eric Barish Dieter Bayer Steve A.
Bennett
David K. Buck Nicolas Calimet Aaron A. Collins Chris Dailey
Steve Demlow Andreas Dilger Alexander Enzmann Dan Farmer
Mark Gordon Christoph Hormann Mike Hough Chris Huff
Kari Kivisalo Lutz Kretzschmar Jochen Lippert Pascal
Massimino
Jim McElhiney Douglas Muir Juha Nieminen Bill Pulver
Eduard Schwan Wlodzimierz Skiba Robert Skinner Yvo
Smellenbergh
Zsolt Szalavari Scott Taylor Massimo Valentini Timothy Wegner
Drew Wells Chris Young
Other contributors are listed in the documentation.
Support libraries used by POV-Ray:
ZLib 1.2.1, Copyright 1995-1998 Jean-loup Gailly and Mark Adler
LibPNG 1.2.5, Copyright 1998-2002 Glenn Randers-Pehrson
LibJPEG 6b, Copyright 1998 Thomas G. Lane
LibTIFF 3.6.1, Copyright 1988-1997 Sam Leffler, 1991-1997 SGI
Aborted
That's it. Any ideas what it means and how I should compile the povray?
Thanks!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Compiling POV-Ray 3.6.1 on IA64 using Intel Compiler
Date: 9 May 2007 04:47:50
Message: <46418ab6$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Aborted
You might try configuring povray so as to include debug information
and run it under a debugger:
./configure COMPILED_BY=you --enable-debug
make
gdb ./unix/povray
run test.pov options
bt
and report the result.
- NC
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> gdb ./unix/povray
> bt
Thanks for advice, here the output below:
<... the same output as in previous message...>
Program received signal SIGABRT, Aborted.
0xa000000000010641 in ?? ()
(gdb) bt
#0 0xa000000000010641 in ?? ()
#1 0x2000000000635190 in raise () from /lib/tls/libc.so.6.1
#2 0x2000000000637a60 in abort () from /lib/tls/libc.so.6.1
#3 0x20000000000580e0 in (anonymous namespace)::_default_terminate_handler
from /local/programs/icc/9.1.045/lib/libcxa.so.6
#4 0x2000000000057aa0 in std::terminate () from
#5 0x2000000000059530 in Terminate??unw () from
#6 0x2000000000059c70 in __gxx_personality_v0??unw () from
#7 0x20000000000599b0 in __intel_personality_routine??unw () from
#8 0x20000000005c4140 in _Unwind_RaiseException () from /lib/libgcc_s.so.1
#9 0x20000000000594d0 in __cxa_throw??unw () from
#10 0x400000000033ca10 in _ZN12POVMS_ObjectC9ERS_ (this=0xfffffffffffffff1,
source=@0x60000fffffff8820) at povmscpp.cpp:473
#11 0x4000000000340ea0 in POVMS_Object::operator() (this=0x60000fffffff8820)
at povmscpp.h:207
#12 0x4000000000340e40 in POVMS_MessageReceiver::ReceiveHandler () at
povmscpp.cpp:1031
#13 0x2000000000637a60 in abort () from /lib/tls/libc.so.6.1
(gdb)
And for idb also the same:
Thread received signal ABRT
stopped at [0xa000000000010641]
(idb) where
#1 0x2000000000635190 in raise(...) in /lib/tls/libc.so.6.1
#2 0x2000000000637a60 in abort(...) in /lib/tls/libc.so.6.1
_ZN37_GLOBAL__N__13_exception_cpp_a3e89b6426_default_terminate_handlerEv(...)
in /local/programs/icc/9.1.045/lib/libcxa.so.6
#4 0x2000000000057aa0 in _ZSt9terminatev(...) in
#5 0x2000000000059530 in Terminate(...) in
#6 0x2000000000059c70 in __gxx_personality_v0(...) in
#7 0x20000000000599b0 in __intel_personality_routine(...) in
#8 0x20000000005c4140 in _Unwind_RaiseException(...) in /lib/libgcc_s.so.1
#9 0x20000000000594d0 in __cxa_throw(...) in
((POVMS_Object*)0x7fffffff00000000)->POVMS_Object::POVMS_Object(source=&
class POVMS_Object { ... }) "povmscpp.cpp":473
((POVMS_Object*)0x7fffffff00000000)->POVMS_Object::operator()()
"povmscpp.cpp"
#12 0x4000000000340e40 in ((POVMS_Object*)<bad
value>)->POVMS_Object::operator()() "povmscpp.cpp":1031
#13 0x2000000000637a60 in abort(...) in /lib/tls/libc.so.6.1
(idb)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 9 May 2007 15:02:47
Message: <46421ad7$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
This looks like the compiler is generating bad code. Did you try
compiling with gcc and/or without optimizations?
- NC
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> - NC
Yes, I tried all options and cases I could imagine. GCC works fine, either
with optimizations or without it. However ICC doesn't whatever option or
switches combination I used. I suppose the problem is in the libcxa intel
library. Still trying to investigate this hypothesis.
BTW, when the multithreading version of the POV-Ray will be availabe for
UNIX machines like mine?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yes! Finally I solved the problem. It was really a problem of
incompatibility between gcc and intel libraries. So, to obtain working
binaries the
LDFLAGS="-cxxlib-icc -lcxa" should be supplied for the configure.
Result is pretty good, look at gcc vs icc timings:
Total Scene Processing Times
Parse Time: 0 hours 0 minutes 0 seconds (0 seconds)
Photon Time: 0 hours 0 minutes 4 seconds (4 seconds)
Render Time: 0 hours 1 minutes 46 seconds (106 seconds)
Total Time: 0 hours 1 minutes 50 seconds (110 seconds)
Parse Time: 0 hours 0 minutes 1 seconds (1 seconds)
Render Time: 0 hours 1 minutes 13 seconds (73 seconds)
Total Time: 0 hours 1 minutes 18 seconds (78 seconds)
Almost 1.5x speedup!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 9 May 2007 16:19:43
Message: <46422cdf@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Which version of gcc? Did you compile a 32-bit or a 64-bit binary with it?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
gcc (GCC) 3.3.3 (SuSE Linux)
Only 64-bit. It wouldn't even possible to compile 32-bit binaries on
Itanium.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 9 May 2007 16:54:13
Message: <464234f5@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I think gcc4 has better support for 64-bit code.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ok, thanks. I will try it, however I am not sure it can compete with Intel
compiler anyway.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
