POV-Ray : Newsgroups : povray.unix : Linux and Windows Server Time
22 Dec 2024 04:32:02 EST (-0500)
  Linux and Windows (Message 1 to 8 of 8)
Subject: Linux and Windows
Date: 27 Nov 2006 07:30:00
Message: <web.456ad981cb772752792d8faa0@news.povray.org>
Will a windows pov file render on Linux?
Are the files interchangable?
Subject: Re: Linux and Windows
Date: 27 Nov 2006 09:15:00
Message: <web.456af280946835c3976a8750@news.povray.org>
of course!  The SDL is like the C language and the include files are like
cross-platform libraries and povray itself like a good cross-platform C
compiler. :)
Date: 27 Nov 2006 09:53:49
Message: <456afbfd$1@news.povray.org>
nemesis scripsit::
> compiler. :)
Well, as long as you take care of any font files used in the scene.
If you used a text object with a font file not available on the
rendering machine, it won't render.
(ttf files are fine on Windows & Linux, just have to locate them
correctly... and the big Arial.ttf with all the unicode stuff is
only available with latest ms-office...)
But, I agree, once the resources (of include and font files) have
been found, no problem!
Eifersucht ist die Leidenschaft, die mit Eifer sucht, was Leiden
schafft.
Eco: -8.75 Soc: -6.72
http://www.politicalcompass.org/
Date: 27 Nov 2006 10:39:33
Message: <456b06b5@news.povray.org>
  Can you think of any reason why it would not?
Date: 27 Nov 2006 13:10:01
Message: <web.456b2923946835c792d8faa0@news.povray.org>
No
I was just making sure.I use Chief Architect in Windows because
it exports to a pov file.I want to use a seperate machine to render
to. Is Linux 64bit a good system to render on?
Thanks Alan Mathews
Date: 27 Nov 2006 14:07:56
Message: <456b378b@news.povray.org>
Alan Mathews spake:
Yes - I usually design in Windows (using moray + Windows pov) and render in
Linux on the same machine. You just need to make sure you change the paths
around (all \ becomes /) and make sure the relative paths still match up
(so that the scene has all its components available).
This is relatively easy to do... for example, to access .ttf files in both
systems, the windows partition is mounted in linux, then
C:\windows\fonts\arial.ttf
becomes
/mnt/win/windows/fonts/arial.ttf
and so forth and so on.
Stefan Viljoen
Polar Design Solutions
Date: 27 Nov 2006 15:20:04
Message: <ekfh3v$qc1$1@chho.imagico.de>
> becomes
Note the former is not supported.  The backslash has a special meaning
in strings - see the docs for details).  Always using a forward slash
will work universally.
In general it is a good idea not to use absolute path names in scene
files but use library_path settings instead.
http://www.imagico.de/ (Last updated 15 Oct. 2006)
Date: 15 Dec 2006 15:42:27
Message: <458308b3$1@news.povray.org>
"Alan Mathews" <ama### [at] charternet> wrote in message
news:web.456b2923946835c792d8faa0@news.povray.org...
> >                                                           - Warp
> No
> Thanks Alan Mathews
works well for me. just make sure you are using a 64bit build of povray to
utilize all the processor's capabilities.
