Hi all,
I need send scene description to the povray (v. 3.6) via stdin. I read man
pages and there is "+I-", I use this but I get only error, not rendering.
My command:
cat scene.pov | povray +I-
Povray output:
Redirecting Options
All Streams to console..........On
Debug Stream to console.........On
Fatal Stream to console.........On
Render Stream to console........On
Statistics Stream to console....On
Warning Stream to console.......On
Parsing Options
Input file: stdin (compatible to version 3.61)
Remove bounds........On
Split unions.........Off
Library paths:
/usr/local/share/povray-3.6
/usr/local/share/povray-3.6/ini
/usr/local/share/povray-3.6/include
Output Options
Image resolution 320 by 240 (rows 1 to 240, columns 1 to 320).
Output file: /Documents/POVRAY/stdin.png, 24 bpp PNG
Graphic display......On (gamma: 2.2)
Mosaic preview.......Off
CPU usage histogram..Off
Continued trace......Off
Tracing Options
Quality: 9
Bounding boxes.......On Bounding threshold: 3
Light Buffer.........On
Vista Buffer.........On Draw Vista Buffer....Off
Antialiasing.........Off
Clock value: 0.000 (Animation off)
0:00:00 Parsing
File: stdin Line: 1
File Context (5 lines):
Parse Error: Expected 'object or directive', undeclared identifier 'Pty'
found
instead
When I use command "povray scene.pov" rendering is OK.
Can you help me? Thanks
Peterson wrote:
> Hi all,
> My command:
I wanted to suggest to use a fifo this way.
mkfifo myfifo
cat scene.pov > myfifo &
povray +Imyfifo
but it does not work.
Sorry.
Sebastian
Peterson wrote:
> Hi all,
The man pages are outdated in this point (and have been for a long time).
Scene files are required to be searchable to be parsed. Therefore you
can neither use named nor unnamed pipes for them.
http://www.imagico.de/ (Last updated 22 Oct. 2005)
Christoph Hormann <chr### [at] gmxde> wrote:
> Peterson wrote:
> > Hi all,
Is there any hope that this restriction will be removed in the not
too distant future? We're planning to put together a pipeline for
generating 3D images using a cgi script, and if possible, I would like
to avoid the messy issue of generating temporary files and cleaning them
up in a way that works robustly in a multiprocess environment (i.e. if
more than one cgi processes execute concurrently).
Is there any explanation on why the file has to be searchable? Normally,
one is much better off using only one's own data structures once having
acquired them by parsing...
Best regards, Jan
> too distant future?
Most likely not.
For example: think about POV-Ray macros.
- NC
> too distant future?
No. To be more precise: not with the current scene description language.
http://www.imagico.de/ (Last updated 14 Mar. 2006)
> > too distant future?
> Most likely not.
How do macros necessitate searchable files?
Random access to files can generally be replaced with random access
to the structures obtained by parsing, which are in memory (RAM)
anyway.
Best regards, Jan
The short answer: Macros can be self-modifying by writing to files.
Of course, it is far more complex than this.
Thorsten
Ok -- that answer is spot on, modifications to macros in files are
clearly not compatible with the idea of using the data structures
parsed from the file (possibly before modification).
However, would it not be possible to evolve the parser such that it
fseeks only if that is really needed, so that a straightforward scene
that doesn't involve anything fancy such as modifying files etc. can
be parsed from a non-seekable stream?
You're making me curious.
Best regards, Jan
