POV-Ray : Newsgroups : povray.unix : Red Hat linux enterprise Server Time
1 Sep 2024 13:23:01 EDT (-0400)
  Red Hat linux enterprise (Message 1 to 2 of 2)
Subject: Red Hat linux enterprise
Date: 23 Jun 2005 11:40:01
Message: <web.42bad6b9728aa4b5e4079d340@news.povray.org>
I tried installing pov-ray on red hat linux enterprise using the
instructions provided on the website and I got the following error
POV-Ray 3.6 installation
This machine does not seem to be a Linux PC.
This version of POV-Ray only runs on x86 Linux machines.
You can obtain a version appropriate for your architecture
on http://www.povray.org/
Any help would be really appreciated
thanks,
S
Subject: Re: Red Hat linux enterprise
Date: 23 Jun 2005 12:55:02
Message: <d9epas$hqi$1@chho.imagico.de>
That message is incomplete - it should be:
If you want to force an installation you can use
   install -no-arch-check
And in fact this says everything you need to know.  If your machine is
an x86 PC and you get this message it most likely is an AMD64 - in that
case you can use the binary version but it would be recommended to build
from source since this will result in a much faster version.
Last updated 03 May. 2005 _____./\/^>_*_<^\/\.______
