POV-Ray : Newsgroups : povray.unix : KDE install error? Server Time
26 Jun 2024 03:00:30 EDT (-0400)
  KDE install error? (Message 1 to 4 of 4)
Subject: KDE install error?
Date: 12 May 2005 22:45:01
Message: <web.428414a2272e216bfe8460780@news.povray.org>
I see:
installing KDE integration for user 'greg'...
  copying POV-Ray icons...
  generating POV-Ray file types...
  installing main POV-Ray 3.6 submenu...
  installing ini file link...
  installing configuration file link...
  installing documentation link...
  installing sample scene render links...
  modifying povray.conf...
  checking conf file /home/greg/.povray/3.6/povray. conf
cp: cannot stat `/usr/local/etc/povray.conf': No su ch file or directory
Error: could not modify povray.conf
Finished installing KDE panel entries
whereas the directory structure is
/usr/local/etc/povray/3.6/povray.conf
Is the KDE installer looking for the file to change in the wrong
subdirectory?
Subject: Re: KDE install error?
Date: 13 May 2005 03:15:01
Message: <d61jul$2a0$1@chho.imagico.de>
> subdirectory?
No, this can only happen if there is no io-restrictions configuration
file found at all which is only the case if you started the KDE install
without previously installing POV-Ray.  It should of course also check
this before but it is difficult to check every possible misuse of the
script. ;-)
Last updated 03 May. 2005 _____./\/^>_*_<^\/\.______
Date: 13 May 2005 12:10:01
Message: <web.4284d14dc0543dc840d56c170@news.povray.org>
No, I installed povray exactly as per the instructions online.
Date: 13 May 2005 12:30:02
Message: <d62kd9$b48$1@chho.imagico.de>
I was about to say this can't be but there is indeed a small error in
the script that causes a malfunction here.
Do an 'install user' before 'install kde' and you should be fine.
