POV-Ray : Newsgroups : povray.unix : Compilation on IRIX Server Time
28 Oct 2024 16:22:06 EDT (-0400)
  Compilation on IRIX (Message 1 to 4 of 4)
Subject: Compilation on IRIX
Date: 7 Feb 2005 13:25:01
Message: <web.4207b208d8de0fea4924e90f0@news.povray.org>
Hi everyone, I'm trying to compile PovRAY 3.6.1 on IRIX 6.5.25 using gcc3.3
This is where it fails:
Making all in tiff/libtiff
gmake[3]: Entering directory `/d2/povray-3.6.1/libraries/tiff/libtiff'
gmake[3]: *** No rule to make target `all'.  Stop.
Any ideas? I've tried tried to disable tiff support, but --without-tiff
doesn't work.
          Thanks in advance, vtech
Subject: Re: Compilation on IRIX
Date: 7 Feb 2005 13:39:50
Message: <4207b5f6@news.povray.org>
> doesn't work.
You cannot disable any library included with POV-Ray, they are all mandatory
to build a working version off POV-Ray.
What you can do, however, other than fixing the libtiff configure/makefiles
is to look for  distributions of libtiff with the appropriate version (not
an older version!) for Irix.  Then install those and configure/make POV-Ray
again, it will detect the version you installed and use that.
	Thorsten
Date: 7 Feb 2005 14:45:00
Message: <web.4207c41d97e687a44924e90f0@news.povray.org>
Thank you, I'll try it. V.
Date: 24 Feb 2005 21:30:39
Message: <421e8dcf$1@news.povray.org>
The current Irix tarball is
http://freeware.sgi.com/Dist/fw_tiff-v3.5.7.tardist
Hope that helps.
If you get it to work I'd like to know
DLM
"vtech" <nomail@nomail> wrote in message
news:web.4207c41d97e687a44924e90f0@news.povray.org...
>> mandatory
>> configure/makefiles
>> (not
>> POV-Ray
