POV-Ray : Newsgroups : povray.unix : KDE menu Server Time
22 Dec 2024 19:42:41 EST (-0500)
  KDE menu (Message 1 to 3 of 3)
Subject: KDE menu
Date: 22 Nov 2004 17:30:00
Message: <web.41a26832638401ec2d725e970@news.povray.org>
I just installed povray-3.6 on Fedora Core 2 and everything works fine
except that  when i installed it none of the links it put in my kde menu
had icons. I tried removing it with kmenueditor then reinstalling povray
but now it wont put anything in my menu at all:(  I guess its not that big
a deal but if anyone could stear me towards the solution to this problem
that would be great.
Thanks.
Subject: Re: KDE menu
Date: 22 Nov 2004 20:35:01
Message: <web.41a2936d71907651fb21162f0@news.povray.org>
"zounds!" <nomail@nomail> wrote:
> Hi,
> Thanks.
to set up the KDE-Entries, you must run the install-script with the
KDE-parameter:
../install kde
If it fails, run
../install kde 2&>error2.txt
../install kde 1&>error1.txt
Then please post the content of error1.txt and error2.txt
Concerning the icons:
the Icons might be incompatible with your theme or KDE-Version.
The installer tries to copy them to
/home/user/.kde/share/icons
You can change/add Icons in kmenuedit, if there are not set up correctly.
Greets, Mark
Greets, Mark
Date: 22 Nov 2004 21:10:00
Message: <web.41a29ac871907651fb21162f0@news.povray.org>
This Mail-system corrupts the mails a little bit, it sets too many dots
It should be like this (without the ">"):
> KDE-parameter:
> ./install kde
> If it fails, run
