POV-Ray : Newsgroups : povray.unix : Re: what GUI's for Povray can you recommend Server Time
28 Jun 2024 21:28:19 EDT (-0400)
  Re: what GUI's for Povray can you recommend (Message 1 to 1 of 1)
Subject: Re: what GUI's for Povray can you recommend
Date: 26 Oct 2004 22:35:00
Message: <web.417f086788d08c95160cebe80@news.povray.org>
Thanks for the info.
Like I said in my reply to Mark, I'm having a hard time getting the jre
running. I don't think it was part of FC2, when I went to the directroy
after I stalled it, it seemed to install nicely. I donot know if FC2 had
the java allready or not?
> Maybe you too need to download the J2RE (Java 2 Runtime Environment) from
> the Sun Microsystems website - its about 12 MB if I remember right. What
> you then need to do is to install it, and then run Jpatch. I don't have
> Jpatch, but I have another Java program called Arbaro that is used with
> PovRay. After installing the JRE, I run Arbaro like this from the shell:
> java -server -Xms256m -Xmx512m -esa -jar arbaro_gui.jar
> You'll probably need to run jpatch.jar or whatever.
I tried you your idea also. Nothing happened. I do have jpatch and arbaro
installed in a directory on my /home/user/ I must be missing a somthing in
directing Java to the program?
Thank you for your help :)
Thoamsso
