POV-Ray : Newsgroups : povray.unix : Re: INI File Error Povray3.02.SunOS under Solaris 8 Server Time
22 Dec 2024 19:14:41 EST (-0500)
  Re: INI File Error Povray3.02.SunOS under Solaris 8 (Message 1 to 2 of 2)
Subject: Re: INI File Error Povray3.02.SunOS under Solaris 8
Date: 4 Oct 2004 03:40:00
Message: <web.4160fc9a9179ac1b60c0f8c20@news.povray.org>
Nicolas Calimet <pov### [at] freefr> wrote:
> >   Is there some specific reason why you want to use a version that old?
Thanks for your reply
This was the only version in the ftp archive for
which a binary download is available for SunOS
Where are the most upto date binaries obtained from
or is it necessary to build from source
atmosphere{} ahha ;-)
>  I'd say  atmosphere{}  :-)
>  No idea what this error can be though...
>  - NC
Date: 4 Oct 2004 08:54:18
Message: <416147fa@news.povray.org>
  Is there a reason you don't want to compile the newest version?
  If you have gcc installed, it should be very easy.
