POV-Ray : Newsgroups : povray.unix : IRIX 6.5 povray3.50c Server Time
29 Sep 2024 00:16:50 EDT (-0400)
  IRIX 6.5 povray3.50c (Message 1 to 8 of 8)
Subject: IRIX 6.5 povray3.50c
Date: 30 Jan 2003 09:30:07
Message: <web.3e3935dac6c37b31dce8a3800@news.povray.org>
 I am trying to compile povray 3.5c on a SGI Octane Irix6.5 without success.
After ./configure ; make the compilation stops with the error message:
c++ atmosph.cpp
cc1plus: Invalid option `align-double'
cc1plus: Invalid option `inline-all-stringops'
I have gcc version 3.0.4 installed. Later I tried it on another SGI with
native compilers also without success.
It seems that configure, won't recognize the machine type atomatically as it
always assumes -DCOMPILER_VER=\".Linux.gcc\. So far I found no way to coax
it into accepting other compiler switches. It does not react fully to
environment variables like CFLAGS but it accepts CC when I try to compile it
with a native compiler.
I had similar problems on Compaq(HP) Alpha workstations with Tru64 Unix
5.1a.
Again it appears that configure definitly expects linux i646 for which it
works.
Can someone help ?
L.
Subject: Re: IRIX 6.5 povray3.50c
Date: 30 Jan 2003 11:46:37
Message: <3e3956ed$1@news.povray.org>
In article <web.3e3935dac6c37b31dce8a3800@news.povray.org> , "Lothar"
<les### [at] helixnihgov> wrote:
> Can someone help ?
Removing the two options should be sufficient.  -DCOMPILER_VER is just a
declare of COMPILER_VER and not relevant for the compiler.
    Thorsten
Date: 30 Jan 2003 13:25:03
Message: <web.3e396da957e82f2edce8a3800@news.povray.org>
Thorsten Froehlich wrote:
>In article <web.3e3935dac6c37b31dce8a3800[at]news.povray.org> , "Lothar"
>> Can someone help ?
No. You need to do more.
I know. I just wanted to point out that somehow configure does not know
which machine it is running on.
There are a number of problem like inappropriate type casts etc. which I
mostly ignore but in unix.cpp I get this:
unix.cpp:658: cannot convert `void (*)(int)' to `void (*)()' for argument`2'
to `void (* signal(int, void (*)()))()'
and more of this kind.
Any ideas ?
L.
Date: 30 Jan 2003 14:33:44
Message: <3e397e18$1@news.povray.org>
In article <web.3e396da957e82f2edce8a3800@news.povray.org> , "Lothar"
For me on Mac OS X it works with gcc 3.1 if I remove those, and specify the
correct architecture, of course.
    Thorsten
e-mail: tho### [at] trfde
Date: 30 Jan 2003 14:42:33
Message: <3e398029$1@news.povray.org>
> Any ideas ?
Well, here the problem is that you are running on the worst and most
outdated Unix implementation around.  Either IRIX does not support an
argument here or the headers its supplies are broken (both is likely).
IRIX does not seem to like that the signal handler takes an argument, but
that is how ANSI defined the signal function.  If there isn't a way to get
IRIX to behave as standardized, I am afraid you will have to change the
source code.
    Thorsten
Date: 3 Feb 2003 12:06:24
Message: <3e3ea190$1@news.povray.org>
Has anyone a running Povray 3.5 for IRIX 6.5 so far? I was trying to
compile povray3.50c on an Indigo2 10K but had no success.
Claus.
Date: 3 Feb 2003 14:51:44
Message: <3E3EC850.1060905@free.fr>
Lothar, Claus, and anyone interested  :o)
	I've finally managed to compile POV-Ray 3.5c on IRIX 6.5
with gcc-3.2.1 and a statically linked libpng (all other libs
are normally shared). I DIDN'T TEST IT AT ALL. Available here:
http://pov4grasp.free.fr/download/povray.gz
PS1: IRIX is a f***ing environment for compiling anything. I spent
      several days for nothing trying to compile the successive
      versions of gcc (starting at gcc-3.0) when they appeared online,
      until I got this gcc-3.2.1 working with a single mod in the
      source makefile. POV-Ray was almost as difficult to get here.
      (only gcc-2.8.1, from 1998, was already installed, and could
      not work properly).
PS2: I'm currently working on a rewrite of the ./configure script
      that won't be targetted towards Linux, but with compilation
      flags detected on-the-fly. It's moslty ready, however it still
      fails on IRIX. Not surprising though... Damnit.
Date: 6 May 2003 17:10:05
Message: <web.3eb8236757e82f2e513c36560@news.povray.org>
Thanks a lot Nicolas for providing the bins. Unfortunately I have
difficulties to unpack your gz. Using gunzip I'll receive the message: Not
in gz format. Any recommendation? Have Irix 6.5 with no Overlays. Tried on
an Indigo II and Octane.
>      not work properly).
