POV-Ray : Newsgroups : povray.unix : Invoking povray on Linux using Java's Runtime.exec Server Time
31 Oct 2024 05:59:48 EDT (-0400)
  Invoking povray on Linux using Java's Runtime.exec (Message 1 to 5 of 5)
Subject: Invoking povray on Linux using Java's Runtime.exec
Date: 23 Nov 2002 16:55:08
Message: <web.3ddff8cb18780cfafe4e4f170@news.povray.org>
Hi All,
I'm trying to invoke povray using Java's Runtime.exec, but it isn't working.
Runtime.exec prematurely exits with dumping "core" file.
I'm using 2.4.2-2 kernel( probably RedHat 6.2).
any suggestion??
thank you.
here is my code
package edu.sfu.ensc.rendering.nodeserver.execution.runner;
 * Title:
 * Description:
 * Copyright:    Copyright (c) 2001
 * Company:
 * @author
 * @version 1.0
import java.io.*;
public abstract class RuntimeExecutor {
  public static boolean exec(String strCommandLine)  throws Exception{
      boolean bSuccess=true;
      Process jcProc=null;
      byte[] jcErrBuf=new byte[512];
      byte[] jcOutBuf=new byte[1024];
      try {
          System.out.println(strCommandLine);
          jcProc=Runtime.getRuntime().exec(strCommandLine);
          BufferedInputStream jcStdErr=new
BufferedInputStream(jcProc.getErrorStream());
          BufferedInputStream jcStdOut=new
BufferedInputStream(jcProc.getInputStream());
          BufferedOutputStream jcStdErrCapture=null;
          BufferedOutputStream jcStdOutCapture=null;
          int nRead=0;
          nRead=jcStdErr.read(jcErrBuf);
          if(nRead>-1)  {
              while( nRead!= -1)  {
                  System.out.println("***********error "+new
String(jcErrBuf));
                  nRead = jcStdErr.read(jcErrBuf);
              bSuccess=false;
          nRead=jcStdOut.read(jcOutBuf);
          if(nRead>-1)  {
                  System.out.println("***********out "+new
String(jcErrBuf));
                  nRead = jcStdOut.read(jcOutBuf);
              bSuccess=true;
          jcProc.waitFor();
      } catch(Exception e)  {
          throw e;
      return bSuccess;
  public static void main(String[] args)  {
      try {
          RuntimeExecutor.exec("/povray/povray  -d -v +ki1.0 +kff25 +sf21
+ef25 /RenderNode/io/dyu.p3333.POVRAY.2_.pov");
      } catch (Exception e) {
          e.printStackTrace();
Subject: Re: Invoking povray on Linux using Java's Runtime.exec
Date: 23 Nov 2002 20:20:04
Message: <web.3de02837d5d7fad2fe4e4f170@news.povray.org>
Hi All, it's me again.
This is amazing!!
After many hours of frustration,
I even coded a C program that calls "system" method or "execl" method to
invoke
povray. This program is called by Java. It didn't work.
Again, I coded a bash script to invoke povray, but it didn't work either
when
Java called the bash script.
(I used Java's Runtime.exec method)
So, in summary
Java -> povray (FAIL)
Java -> C Program -> povray (FAIL)
Java -> Bash script -> povray (FAIL)
But the strange thing is that when I call the C program or Bash script
directly
on command prompt, it works. It only fails when I call them through Java.
The only thing that I can try is Java's JNI mechanism. But, I really don't
want to do this. I would rather use different rendering engine!!
david wrote:
>Hi All,
>any suggestion??
>thank you.
>here is my code
> * Title:
> * Description:
> * Company:
> * @author
> * @version 1.0
>import java.io.*;
>      try {
>          int nRead=0;
>          if(nRead>-1)  {
>String(jcErrBuf));
>              bSuccess=false;
>          if(nRead>-1)  {
>String(jcErrBuf));
>              bSuccess=true;
>          jcProc.waitFor();
>          throw e;
>      return bSuccess;
>      try {
Date: 24 Nov 2002 05:18:22
Message: <3de0a76e$1@news.povray.org>
In article <web.3de02837d5d7fad2fe4e4f170@news.povray.org> , "david"
Please do not multi-post in our groups. I removed your post in p.programming
as your problem is Unix specific.
As far as you problem is concerned, did you perhaps forgot to specify "-d"
on the command-line for POV-Ray?  Others seem to have had similar problems
with scripts and remote execution and the like (what rights does a program
started through Java have?) and reading through the messages of the last few
month in this group may yield useful hints.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 26 Nov 2002 00:10:06
Message: <web.3de30161d5d7fad2fe4e4f170@news.povray.org>
Hi
Thanks for the help.
However, it is still not working.
Every executable involved belong to root user and I do use -d option.
I looked through many messages posted here, but didn't find anything
that directly relates me. Nevertheless, I tried whatever I could find
from the past indirectly related postings, and I still couldn't figure...
frustrated..
Thorsten Froehlich wrote:
>In article <web.3de02837d5d7fad2fe4e4f170[at]news.povray.org> , "david"
>    Thorsten
>Thorsten Froehlich
Date: 27 Nov 2002 12:12:10
Message: <3de4fcea$1@news.povray.org>
I compiled PovRay on Solaris WITH OUT X support and I use Java
Runtime.getRuntime().exec() to invoke it with out any problems. My java code
also runs on Windows and has no problem except that you need to add the
/EXIT as one of the cmdline args (so it exits when it is done).
Process process = Runtime.getRuntime().exec(POVRAY + " " +
options.substring(4)); //remove the data keyword
I am writing (currently functional) a distributed renderer using  Java,
Povray and some C++ (to recombine the output) and I will be testing on some
Linux nodes (currently all the nodes are Sparc/Solaris) in the next 1-2
weeks. So I will let you know if my Java code holds up or fails.
-James
"david" <dav### [at] hotmailcom> wrote in message
news:web.3ddff8cb18780cfafe4e4f170@news.povray.org...
> Hi All,
working.
> any suggestion??
> thank you.
> here is my code
>  * Title:
>  * Description:
>  * Company:
>  * @author
>  * @version 1.0
> import java.io.*;
>       try {
>           int nRead=0;
>           if(nRead>-1)  {
> String(jcErrBuf));
>               bSuccess=false;
>           if(nRead>-1)  {
> String(jcErrBuf));
>               bSuccess=true;
>           jcProc.waitFor();
>           throw e;
>       return bSuccess;
>       try {
