POV-Ray : Newsgroups : povray.unix : gcc 3.0 results/comparison. Server Time
24 Dec 2024 21:24:18 EST (-0500)
  gcc 3.0 results/comparison. (Message 1 to 7 of 7)
Subject: gcc 3.0 results/comparison.
Date: 20 Jun 2001 21:08:55
Message: <slrn9j2hkm.9hc.steve@zero-pps.localdomain>
The results are in after a successfull GCC 3.0 install.
No other apps running, but run in X.
X-povray is the standard binary download from povray.org
and therefor not compiled by myself.
Xmegapov was compiled by myself with gcc 2.95, xmegapy07_gc3 and
xpovray_gc3 were compiled by myself with gcc 3.0, no makefiles
were tampered with, these are all straight out of the box.
xmegapov -i skyvase.pov -w640 -h480 +a0.1
Time For Parse:    0 hours  0 minutes   1.0 seconds (1 seconds)
Time For Trace:    0 hours  4 minutes  28.0 seconds (268 seconds)
    Total Time:    0 hours  4 minutes  29.0 seconds (269 seconds)
xmegapov07_gc3 -i skyvase.pov -w640 -h480 +a0.1
Time For Trace:    0 hours  4 minutes   9.0 seconds (249 seconds)
    Total Time:    0 hours  4 minutes   9.0 seconds (249 seconds)
x-povray -i skyvase.pov -w640 -h480 +a0.1
Time For Trace:    0 hours  3 minutes  57.0 seconds (237 seconds)
    Total Time:    0 hours  3 minutes  57.0 seconds (237 seconds)
xpovray_gc3 -i skyvase.pov -w640 -h480 +a0.1
Time For Trace:    0 hours  3 minutes  47.0 seconds (227 seconds)
    Total Time:    0 hours  3 minutes  47.0 seconds (227 seconds)
  1:52am  up 139 days,  2:43,  2 users,  load average: 0.13, 0.42, 0.52
Subject: Re: gcc 3.0 results/comparison.
Date: 21 Jun 2001 14:20:49
Message: <3B323B65.4030809@iol.it>
Reading the 3.0 announce info from LinuxToday I saw that the executables
should be 5/10% faster than 2.95. The above mentioned results seem to
completely confirm this info.
Bye!!1
Date: 23 Jun 2001 00:04:24
Message: <3b341548@news.povray.org>
Is GCC compiled with GCC? How would a GCC 3.0 compiled with 2.95 compare to
one compiled with 3.0? (If that makes any sense at all...)
Date: 23 Jun 2001 03:25:39
Message: <pug8jts7jf918gi3sgngqqnq4ott8sqveu@4ax.com>
On Fri, 22 Jun 2001 23:00:35 -0600, "Tony[B]" <ben### [at] catholicorg>
Of course it makes sense. This is how gcc compiles itself from source.
First it compiles with whatever compiler you have, then it compiles
with itself, and then it compiles with itself again. Then, if the last
two copies match, it installs itself. This is called bootstrapping
IIRC.
Peter Popov ICQ : 15002700
Date: 23 Jun 2001 09:29:17
Message: <slrn9j94co.g09.steve@zero-pps.localdomain>
>IIRC.
Yes thats what it seems to do, it takes two hours to build.
  1:54pm  up 141 days, 14:45,  2 users,  load average: 1.00, 1.06, 1.04
Date: 24 Jun 2001 22:59:04
Message: <3b36a8f8@news.povray.org>
Yech... :P
Date: 25 Jun 2001 17:06:36
Message: <slrn9je6e8.sun.steve@zero-pps.localdomain>
>Yech... :P
That's two hours to build GCC, not POV.
 12:00pm  up 143 days, 12:51,  2 users,  load average: 1.12, 1.05, 1.03
