POV-Ray : Newsgroups : povray.unix : 3.50c released (see caveats) Server Time
28 Jul 2024 06:25:36 EDT (-0400)
  3.50c released (see caveats) (Message 1 to 10 of 34)
Subject: 3.50c released (see caveats)
Date: 21 Oct 2002 22:30:36
Message: <pan.2002.10.22.02.37.29.222387@povray.org>
I've uploaded 3.50c.  The binary is pretty good (fixed various performance
issues, now building with gcc 3.2), and I/O restrictions are enabled in
the binary but disabled in a usefully commented default
/usr/local/etc/povray.conf that is installed.  Note that the install
script won't clobber a pre-existing povray.conf, so you might want to
clear yours out of the way if you have one.  This version includes a
number of other bugfixes that caused build problems on Solaris and
BSD-derived Unices.
Minor caveat: The binary is built with Pentium optimizations.  It should
run fine (and that much faster) on Pentium or newer hardware.  If you're
running on less than a Pentium, you may need to recompile, and you may
want to consider a different hobby than ray-tracing. ;-)  If you have
sufficiently newer hardware and a sufficiently good compiler, you may want
to recompile for your specific arch, but that's up to you.
Major caveat: I realized after I'd finished uploading that the default
compiler flags also assume Pentium and are probably fairly gcc-specific. I
need to implement some decent configure options in that regard. Non-x86,
non-gcc users will need to edit src/Makefile for now.  Consider yourselves
warned.  I should have a fix up soon. The 3.50d binary probably won't be
different, unless there are other problems.
I did some research and found that I should distribute the object files I
got from the build if I want to distribute binaries which are statically
linked against LGPL libraries.  There's now a povobj.tar.gz file in the
ftp directory in case anyone wants them, along with a file containing the
link line I used.
-Mark Gordon
Subject: Re: 3.50c released (see caveats)
Date: 22 Oct 2002 04:22:24
Message: <3DB50ABF.28EBF3CD@gmx.de>
> BSD-derived Unices.
Nice, but i miss the list of changes from the first release to 3.50c (in
3.1 this was in 'revision.doc').  The 'ChangeLog' file's latest entry is
from 8 July 2002.
Date: 22 Oct 2002 13:48:00
Message: <3DB58F50.8060508@free.fr>
	Here is an autoconf macro that you can use for this purpose
(put it in acinclude.m4):
# POV_TRY_CFLAGS(CFLAGS, [ACTION-IF-WORKS], [ACTION-IF-FAILS])
# Check whether compiler supports a given set of cflags, cache result,
# and update CFLAGS.
AC_DEFUN([POV_TRY_CFLAGS],
   # Create a unique cache-id name.
   pov_try_cflags_var=pov_cv_try_cflags`echo "$1" | sed 's/[[^a-zA-Z0-9]]/_/g'`
   # Cannot use AC_CACHE_CHECK() due to the nature of the cache-id variable.
   AC_MSG_CHECKING([whether $CC accepts $1])
   AC_CACHE_VAL(
     [$pov_try_cflags_var],
       # AC_TRY_COMPILE() is not appropriate any longer since autoconf-2.5x.
       # Compile and inspect standard error for given flags.
       echo 'int main(void){ return 0; }' > conftest.c
       if test -z "`$CC -c $1 conftest.c 2>&1 | grep '\$1'`"; then
         eval "$pov_try_cflags_var=yes"
       else
         eval "$pov_try_cflags_var=no"
       fi
       rm -f conftest.c conftest.o
   eval "pov_try_cflags_value=\$$pov_try_cflags_var"
   AC_MSG_RESULT([$pov_try_cflags_value])
   # Update CFLAGS when flags are working, and run provided actions.
   if test x"$pov_try_cflags_value" = x"yes"; then
     CFLAGS="$CFLAGS $1"
     ifelse([$2],[],[:],[$2])
   else
     ifelse([$3],[],[:],[$3])
   fi
	In the configure.ac (or configure.in) file you just call it,
for instance:
TRIP_TRY_CFLAGS([-O2], [], [TRIP_TRY_CFLAGS([-O])])
	will try first flag -O2 and, if not recognized, try -O and then
simply nothing. CFLAGS is updated accordingly and the result is cached.
	This macro normally works okay with gcc on Linux and gcc/cc on
SGI (didn't tested anything else). Hope I didn't put any typo while
copying/editing the macro from my own packages devels.
	- N.C.
Date: 22 Oct 2002 15:15:48
Message: <3DB5A3E3.6060603@free.fr>
	Sorry this is obviously:
POV_TRY_CFLAGS([-O2], [], [POV_TRY_CFLAGS([-O])])
	By the way this macro is for usage with autoconf-2.5x.
I didn't tested it with the old autoconf-2.13 which might give
problem with the quotations used in the sed call of the macro
for instance. All arguments must be properly quoted with brackets,
otherwise the macro will fail.
	- N.C.
PS: some other examples:
POV_TRY_CFLAGS([-ansi], [], [POV_TRY_CFLAGS([-Aa])])
POV_TRY_CFLAGS([-Wall], [], [POV_TRY_CFLAGS([-fullwarn])])
Date: 23 Oct 2002 07:56:35
Message: <3db68e73$1@news.povray.org>
Thanks Gordon, great.
The spec file is not yet included. Is there any serious reason
for this, like 'doesn't work properly'? Or just lack of time ;-/  ?
-Hans-
> BSD-derived Unices.
> link line I used.
> -Mark Gordon
Date: 23 Oct 2002 07:58:21
Message: <3db68edd$1@news.povray.org>
Thanks *Mark* of course! Sorry for that :)
Date: 23 Oct 2002 07:59:28
Message: <pan.2002.10.23.12.06.25.995467@povray.org>
I hadn't heard back before I made the last package.  It will be in 3.50d.
-Mark Gordon
Date: 23 Oct 2002 10:31:22
Message: <3db6b2ba$1@news.povray.org>
In article <pan### [at] povrayorg> , "Mark Gordon"
BTW, is the Unix source the same as the Linux source?  I am wondering
because the source archive in the Unix dir has a different date...
    Thorsten
e-mail: tho### [at] trfde
Date: 23 Oct 2002 11:22:33
Message: <pan.2002.10.23.15.23.13.182919@integrated-dynamics.com>
> -Mark Gordon
I went ahead and built a Pentium-III optimized version as an RPM
using GCC 3.2 on Red Hat 8.0.  I used Dan's spec file as the starting
point.  There's a source RPM as well.
See:  http://www.integrated-dynamics.com/gar for information.
Feedback and suggestions welcome, as well.
Gordon.
"Far and away the best prize that life has to offer
  is the chance to work hard at work worth doing."
       -- Theodore Roosevelt
Date: 23 Oct 2002 19:08:48
Message: <pan.2002.10.23.23.08.48.671157@povray.org>
>     Thorsten
The source tarball in the Unix directory is a symlink to the source
tarball in the Linux directory.  I believe the date reflects when the
symlink was created.
-Mark Gordon
