POV-Ray : Newsgroups : povray.unix : WINE and POV 3.5 for Windows Server Time
28 Jul 2024 08:31:12 EDT (-0400)
  WINE and POV 3.5 for Windows (Message 1 to 8 of 8)
Subject: WINE and POV 3.5 for Windows
Date: 19 Jul 2002 00:56:57
Message: <pan.2002.07.19.04.56.24.175951.206@gte.net>
Has anyone managed to use WINE to run the Windows version of POV-Ray 3.5
under Linux?  I've tried, but it appears to freeze while showing the
splashscreen.
Mark
Subject: Re: WINE and POV 3.5 for Windows
Date: 21 Jul 2002 06:25:47
Message: <3D3A8CD0.10406@web.de>
> splashscreen.
This is surely a nice experiment, but why?
Sebastian H.
Date: 22 Jul 2002 02:22:38
Message: <pan.2002.07.22.06.21.58.321506.196@gte.net>
On Sun, 21 Jul 2002 06:28:32 -0400, Sebastian H. quoth:
>> 3.5 under Linux?  I've tried, but it appears to freeze while showing
>> the splashscreen.
For the sake of doing it.
Mark
Date: 23 Jul 2002 01:04:07
Message: <pan.2002.07.23.05.01.34.882779.196@gte.net>
On Mon, 22 Jul 2002 02:22:04 -0400, Mark Wagner quoth:
>>> the splashscreen.
Additionally, a quick run of Skyvase using the Linux and Windows versions
indicates that the relatively unoptimized Linux version takes about three
times as long as the optimized Windows version does to render Skyvase.
Mark
Date: 23 Jul 2002 06:19:15
Message: <3d3d2da3@news.povray.org>
> versions indicates that the relatively unoptimized Linux version
> takes about three times as long as the optimized Windows version does
> to render Skyvase.
Now imagine that kind of optomisation accross your entire system, and you
wonder why people say Linux chuggs
PGP Public Key
Version: 6.0.377 / Virus Database: 211 - Release Date: 15/07/2002
Date: 23 Jul 2002 07:30:15
Message: <3d3d3e47@news.povray.org>
> splashscreen.
  I just tried it out... it runs if you use /NR. But you must also disable
the editor as it causes "segmentation fault". Then use "Select file and
render" (Alt+S). The problem is that it's even slower than the Linux
version...
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 23 Jul 2002 10:17:45
Message: <3D3D662E.4020506@web.de>
I don't know very much about optimization but why aren't there optimized
Linux versions?
Date: 23 Jul 2002 12:46:23
Message: <3D3D8878.50302@netscape.net>
I'm looking forward to compiling the 3.5 source code once it's
available. In prior versions, 3.1 and MegaPov 0.7, I had much faster
render times in Linux using my own optimized compiliation than in the
pre-compiled Windows version.
It'll be interesting to see how they'll compare in 3.5 since I get the
impression some good optimization went into the pre-compiled Windows
binary. I'll post results once I have them ;)
-Roz
