POV-Ray : Newsgroups : povray.unix : Sharing the X display Server Time
21 Mar 2026 14:03:05 EDT (-0400)
  Sharing the X display (Message 1 to 5 of 5)
Subject: Sharing the X display
Date: 26 Aug 2001 17:42:07
Message: <okqhotoqk2a5lk2iltliljvjkrldiasn9o@4ax.com>
I have two machines running Linux. One of them is running X and the
other is not (it has it installed but I don't want to run it since I'm
testing a program I'm writing which is using svgalib). How do I go
about making a X application from one machine use the screen on the
other machine? I've set DISPLAY, of course, but it complains about
permissions. How do I set those?
The machine running X has Slackware Linux 8.0, XFree86 4.0.3 and KDE
2.1, if that's of any help.
Another issue I have is with ssh. I have sshd running on both machines
but I can only log on in one of them, the other is refusing the
connection (this is kinda annoying since I want to use CVS over ssh.)
What could be wrong?
Peter Popov ICQ : 15002700
Subject: Re: Sharing the X display
Date: 26 Aug 2001 18:05:26
Message: <3b8972a5@news.povray.org>
Peter Popov <pet### [at] vipbg> wrote:
: I've set DISPLAY, of course, but it complains about
: permissions. How do I set those?
man xhost
Date: 26 Aug 2001 18:50:12
Message: <a6viot4q0upjlt2bg65if1qd9dhv4pl23c@4ax.com>
>man xhost
Thanks, this should do the trick.
*rebooting...*
Date: 26 Aug 2001 18:53:56
Message: <2125650.nlVU6TSbVV@3-e.net>
I use SSH ( secure shell) on our LAN.
I just set the SSH config on the remote system to allow X forwarding,
Then it is as simple as
ssh machinename (plus any options you want )
Once you are logged on to a shell on the remote system, running a program
that uses X will cause it to run it's GUI on your LOCAL X Server.
It just pops up as if it were local.
Dead easy and ssh will compress the data stream for you if you want.
> Personal e-mail : pet### [at] vipbg
> TAG      e-mail : pet### [at] tagpovrayorg
Date: 26 Aug 2001 19:49:17
Message: <0j2jot41l59kgu3fdjdp9nu09vsgvhepna@4ax.com>
On Mon, 27 Aug 2001 08:53:35 +1000, Daniel Matthews
This has been set up. The problem is that ssh itself refuses the
connection in one direction (from bozo: to home:). In the other
direction (from home: to bozo:) everything works ok.
Oh, and Warp's two words worked like magic, so I only need to fix that
ssh now.
