POV-Ray : Newsgroups : povray.unix : PovRay compile Server Time
26 Mar 2026 23:04:22 EDT (-0400)
  PovRay compile (Message 1 to 6 of 6)
Subject: PovRay compile
Date: 1 May 2004 10:41:10
Message: <Xns94DCA97D52895raf256com@203.29.75.35>
how can I (for testing purposes mainly) compile Povray "stand alone" that
is, as a user (not root), in local directory (not some /bin/) etc?
TO have it working just i.e. small C++ program, I just write
  g++ a.cpp -o a.run
and then I use program by
  ./run
and thats all. How to do same for povray?
http://www.raf256.com/3d/
Computer Graphics
Subject: Re: PovRay compile
Date: 1 May 2004 11:41:37
Message: <4093c531@news.povray.org>
In article <Xns94DCA97D52895raf256com@203.29.75.35>, "Rafal 'Raf256' Maj"
>   g++ a.cpp -o a.run
>   ./run
Well, a good hint should be that if you don't know, you are probably not up
to it!  In particular because hardly any package you can get as source is
not compiled with the usual "./configure" script and "make" command
sequence.  And this is no different for POV-Ray...
    Thorsten
e-mail: tho### [at] trfde
Date: 1 May 2004 13:52:20
Message: <Xns94DCC9E66EEDDraf256com@203.29.75.35>
tho### [at] trfde news:4093c531@news.povray.org
> source is not compiled with the usual "./configure" script and "make"
> command sequence.  And this is no different for POV-Ray...
I run ./configure and ./make and modyfie src/optout.h
meke finished without errors (meany warnings btw., wouldnt it be a good
idea to add   (int)x  syntax to prevent meany  double to int cast
warnings?)
But where is resulting executable file?  I build as a user, not root.
I know I can do make install ofcourse, but I want to just create povray
executable for one user, not install it as global program in entire
system.
And next question - what should I do to recompile after changing sources,
make will automaticly recompile only need files right?
Computer Graphics
Date: 2 May 2004 08:03:15
Message: <4094e383$1@news.povray.org>
news:Xns94DCC9E66EEDDraf256com@203.29.75.35...
> warnings?)
The povray executable is on the src directory.
> system.
Yes.
ZeSly
http://perso.wanadoo.fr/zesly/
Date: 14 May 2004 22:27:54
Message: <40a5802a@news.povray.org>
Rafal 'Raf256' Maj wrote:
> Hi,
>   g++ a.cpp -o a.run
>   ./run
./configure --prefix=/home/your_dir/some/path/here
make
make install
if that doesn't work I'm not sure what to tell you
Date: 15 May 2004 12:10:00
Message: <40a640d8$2@news.povray.org>
>   g++ a.cpp -o a.run
>   ./run
	Simply run './configure && make' but NOT 'make install'.
The povray binary is then found under the src/ directory.
	- NC
