POV-Ray : Newsgroups : povray.unix : SciTE on Ubuntu 14.04 for POV-Ray editing Server Time
8 Apr 2026 11:50:34 EDT (-0400)
  SciTE on Ubuntu 14.04 for POV-Ray editing (Message 1 to 1 of 1)
Subject: SciTE on Ubuntu 14.04 for POV-Ray editing
Date: 3 Jan 2016 06:34:37
Message: <5689074d$1@news.povray.org>
Since I was not poving that much since I updated to Ubuntu 14.04, I
didn't notice an annoying problem with the default package: it flickers
a lot when redrawing the window contents as you are editing a file. The
best solution I found was to remove the default package and then install
SciTE from sources. Here is a quick how-to of the process:
+ Download the latest sources from here:
   http://www.scintilla.org/SciTEDownload.html
+ Install the GTK2 libraries:
   sudo apt-get install libgtk2.0
+ Then follow the README on the SciTE sources to compile:
   cd scintilla/gtk
   make
   cd ../..
   and then:
   cd scite/gtk
   make
   sudo make install
+ Now, the pov support is disabled by default, so:
   run SciTE as root (sudo SciTE)
   go to Options->Open Global Options file
   remove pov from imports.exclude
   save global options file
+ Also, the existing pov.properties file seems to be missing the part to
tell SciTE to see pov files as source files:
   run SciTE as root
   go to Options->Edit properties->open pov.properties
   add this line after the file.patterns.pov line:
   *source.patterns.pov=$(file.patterns.pov);
   save pov.properties file and exit
+ Now run it as your regular user and everything should work fine.
jaime
