POV-Ray : Newsgroups : povray.unix : Ideal Linux distribution Server Time
8 Apr 2026 11:50:33 EDT (-0400)
  Ideal Linux distribution (Message 1 to 10 of 15)
Subject: Ideal Linux distribution
Date: 2 Jan 2016 12:30:21
Message: <5688092d@news.povray.org>
Hi folks,
can someone recommend a Linux distribution satisfying the following
requirements:
- 64 bit
- long-term support
- headless operation
- FAST remote GUI access from a Windows desktop
or provide me with some advice on how to set up a system based on some
LTS distro in this manner?
The intention is to have a Linux box tucked away in the corner to run
POV-Ray build and/or performance tests on it, or the occasional
time-consuming render, while sticking to my Windows machine for daily use.
I've been using openSUSE for a while now in this role (and Debian before
that), but I'm dissatisfied with both the lifespan of the major releases
as well as the performance of the user interface (KDE, if I'm not
mistaken) when accessed remotely via Xming.
Subject: Re: Ideal Linux distribution
Date: 2 Jan 2016 13:03:50
Message: <56881106$1@news.povray.org>
Hash: SHA256
Le 02/01/2016 18:30, clipka a écrit :
> Hi folks,
> following requirements:
> - 64 bit - long-term support - headless operation - FAST remote GUI
> some LTS distro in this manner?
> run POV-Ray build and/or performance tests on it, or the
> occasional time-consuming render, while sticking to my Windows
> before that), but I'm dissatisfied with both the lifespan of the
> major releases as well as the performance of the user interface
> (KDE, if I'm not mistaken) when accessed remotely via Xming.
Xfce is a lighter window manager, but the fastest is a SSH/telnet
connection without X11 at all. As long as you do not want to display
pictures...
Actually, from my experiment at work, even a light manager still
consumes about 10 MBytes/seconds (it was running a virtual box over a
remote (LAN) connection), so it is not a good idea to run a full
session on the headless; better have the windows desktop also manages
the X11 windows, and limits the traffic.
Back to your question, you can install Ubuntu 14.04.1 LTS
(installation need a head, then you can activate ssh server and forget
the head until you need really it... such as broken network). Your
next update would be 16.04 (in late April/June 2016) but you can wait
until 2019 to move away from it.
Only drawback I would foresee, the compiler of 14.04 is gcc 4.8.
And you need to know the CLI to display pictures (my favorite are eog
and display).
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2
iJwEAQEIAAYFAlaIEQYACgkQhKAm8mTpkW0UOwQAt9hEvVj2iuC9mY0GsEd6YR8T
NGvTep1lmEdH8e5HHikWBsLcojDdB2/9W0nSKZ7grjAsvp00G7MxRcwBf4PT35YH
T8Hh2nvgtDFdOiTQXMTqD+f7pyHgMW+tGZuQbOWVEwa5fCDKdSJQrofJ88eBC+/c
hlV1jUlZZ54CT7l9gdI=
=kF2f
-----END PGP SIGNATURE-----
Date: 2 Jan 2016 13:40:11
Message: <web.5688197b410686627a3e03fe0@news.povray.org>
The idle time in use and control Linux - Mandriva, is Mageia now
Doesn't demand reinstallation at a release of the new version, itself it is
automatically updated. gcc-4.9, icewm - the smallest desktop.
At me it is the only system therefore I use KDE.
I don't feel sorry for memory.
Service is most important for me.
Date: 2 Jan 2016 14:35:35
Message: <56882687$1@news.povray.org>
I second your suggestions... and if he already has Xming, running ssh
with x11 forwarding should be easy and work like a charm to just edit
files, render and display the results. I used to do that from my windows
laptop when my monitor died, until I got a new one.
jaime
Date: 2 Jan 2016 14:39:14
Message: <56882762$1@news.povray.org>
Am 02.01.2016 um 19:03 schrieb Le_Forgeron:
> pictures...
Testing the preview display on Linux should be possible; also I'd like
to have the possibility to edit files directly on the Linux box, but I'm
pretty unfamiliar with both vi and emacs keyboard controls, and more of
a mouse jockey anyway, so that rules out SSH/telnet.
Ubuntu is indeed on my list of candidates, for that very reason. I don't
like its default user interface though, and I guess it's not optimized
for remote operation either, so I'd probably want to install some
alternative interface.
And that would be a problem because...??
> and display).
Not sure what you're saying here.
Date: 2 Jan 2016 14:41:48
Message: <568827fc$1@news.povray.org>
Am 02.01.2016 um 20:35 schrieb Jaime Vives Piqueres:
I might come back to you for some practical advice, if you don't mind.
Date: 2 Jan 2016 14:50:12
Message: <568829f4$1@news.povray.org>
   I will be glad to give back something to you, of course.
jaime
Date: 2 Jan 2016 14:59:37
Message: <56882c29$1@news.povray.org>
   No, using X11 forwarding you can just use SciTE: works fine with the
mouse, manages BIG files amazingly, and it even has a POV-Ray addon for
syntax highlighting.
   Again, not a problem if you just use ssh with x11... if you want to
manage files, just call nautilus from the command line.
jaime
Date: 6 Jan 2016 00:16:24
Message: <MPG.30f66d202e0988b989695@news.povray.org>
In article <5688092d@news.povray.org>, ano### [at] anonymousorg says...
> Hi folks,
> requirements:
> - 64 bit
> - long-term support
I use Ubuntu. I install the server edition so I get a text console.  If
you install the Workstation, then you get a gui console. It might be no
big deal but that's what I prefer.  The server edition doesn't come with
X proper, so I run `sudo apt-get install xclock` and it pulls in all of
X.
If you're really counting megabits then learn ye vnc
(vncserver/vncviewer).
I use/support 6000 boxes.  (Is it really a lan when you use all of 10/8
?) Most of the time I use ssh, but when I need to run our store's app, I
use vnc, which gives me a remote desktop that is fast.
X is a pig is a pig is a pig. Wait, let me say that again. X-is-a-pig-
is-a-p
uh! autowrap, I'll need to redraw. But first I have to unload my buffer.
ig-is-a-pig.
X-is-a-pig-(don't move your mouse!)is-pig-is-a-pig.
Date: 9 Jan 2016 18:55:29
Message: <56919df1@news.povray.org>
MWAHAHAHAHA!!!
I now officially have THE X-FACTOR!
I'm one of the X-MEN!
I am INVINCIBLE!
(grabs something long and pointy and rushes off...)
*BANZAI!!*
Download 'untitled.jpg' (92 KB)
Preview of image 'untitled.jpg'
