POV-Ray : Newsgroups : povray.unix : Compiling POV-Ray 3.7, second attempt Server Time
13 Oct 2026 18:48:06 EDT (-0400)
  Compiling POV-Ray 3.7, second attempt (Message 1 to 26 of 26)
Subject: Compiling POV-Ray 3.7, second attempt
Date: 3 Jul 2015 19:20:19
Message: <559718b3$1@news.povray.org>
Hi(gh)!
After replacing my entire previous Linux installation by Debian 7.8
"wheezy", I once more tried to compile POV-Ray 3.7... now, all
additional packages recommended in unix/README.md were installed without
any errors. When I started the prebuild.sh script, all worked well -
except for one final error message:
config.status: error: cannot find input file: `Makefile.in'
I thought that make was not installed yet, so I did this and afterward
typed "make" (like read under "Generating configure and building the
code" in README.md) - but this also just resulted in an error message:
make: *** Keine Targets angegeben und keine »make«-Steuerdatei gefunden.
  Schluss.
(which is in English:
make: *** No targets stated and no »make« directive file found. Ending.)
How do I get rid of the config.status error?
See you in Khyberspace!
Yadgar
Subject: Re: Compiling POV-Ray 3.7, second attempt
Date: 3 Jul 2015 23:59:55
Message: <55975a3b$1@news.povray.org>
Am 04.07.2015 um 01:20 schrieb "Jörg \"Yadgar\" Bleimann":
> Hi(gh)!
Quite obviously, all worked /not/ well. You might want to double-check
the output messages - I guess they do report /some/ error or warning. At
any rate you don't seem to be reporting the exact symptoms, as
"config.status" doesn't come into play until the "./configure" step.
What version of POV-Ray 3.7 are you trying to build?
3.7.0 stable release, for instance, is known to not configure properly
with new versions of automake, causing secondary error messages similar
to the one you're reporting.
Date: 4 Jul 2015 06:50:41
Message: <5597ba81$1@news.povray.org>
Hash: SHA256
>> Hi(gh)!
>> 7.8 "wheezy", I once more tried to compile POV-Ray 3.7... now,
>> all additional packages recommended in unix/README.md were
>> installed without any errors. When I started the prebuild.sh
>> script, all worked well - except for one final error message:
> double-check the output messages - I guess they do report /some/
> error or warning. At any rate you don't seem to be reporting the
> exact symptoms, as "config.status" doesn't come into play until the
> "./configure" step.
> properly with new versions of automake, causing secondary error
> messages similar to the one you're reporting.
Well spotted. To build 3.7.0 stable, which is likely due to the
message about "Makefile.in", a workaround on modern system is:
1. in unix directory: ./prebuild.sh
2. in root directory: automake --add-missing
3. in unix directory: ./prebuild.sh
then continue as usual.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2
iJwEAQEIAAYFAlWXuoAACgkQhKAm8mTpkW3VCwP/SNTKj7MUPnJCg7nf22MUW8dv
Q2Gqdh5eXCgFTWJ36HbpfnJVxMCnN80dwv7e7rCIpwMtlHiNYsFAvuqUbbx6NPfF
QtqeJIKsyAQvbWrbdSHJKJ3K65F0AYFCche9XGN1+fLloONXHJyTX7bMypv2Ztkm
x/ojaMbJvJsdSXTu2P4=
=MQ2E
-----END PGP SIGNATURE-----
Date: 4 Jul 2015 18:14:26
Message: <55985ac2@news.povray.org>
Hi(gh)!
O.k., here is the output of prebuild.sh:
root@debian:/media/Raytracing/povray-3.7-stable/unix# ./prebuild.sh
Detected autoconf 2.69
Detected automake 1.11.6
Create ../AUTHORS
Create ../ChangeLog
Create ../configure.ac
Create ../COPYING
Create ../NEWS
Create ../README
Create ../VERSION
Create ../povray.1
Create ../povray.conf
Create ../scripts/
Create ../ini/
Create ../include/
Create ../scenes/
Create ../INSTALL
Create ../icons/file_inc_classic_16.png
Create ../icons/file_inc_crystal_16.png
Create ../icons/file_inc_slick_64.png
Create ../icons/file_inc_slick_32.png
Create ../icons/file_pov_classic_64.png
Create ../icons/file_inc_crystal_64.png
Create ../icons/file_inc_classic_48.png
Create ../icons/file_pov_classic_16.png
Create ../icons/file_inc_slick_16.png
Create ../icons/file_pov_crystal_64.png
Create ../icons/povray_16.png
Create ../icons/file_inc_classic_32.png
Create ../icons/povray_48.png
Create ../icons/file_inc_classic_64.png
Create ../icons/file_pov_classic_48.png
Create ../icons/file_pov_slick_48.png
Create ../icons/file_pov_crystal_16.png
Create ../icons/povray_32.png
Create ../icons/file_pov_slick_32.png
Create ../icons/file_inc_slick_48.png
Create ../icons/file_pov_crystal_32.png
Create ../icons/file_inc_crystal_48.png
Create ../icons/file_pov_slick_64.png
Create ../icons/file_inc_crystal_32.png
Create ../icons/file_pov_crystal_48.png
Create ../icons/file_pov_slick_16.png
Create ../icons/povray_64.png
Create ../icons/file_pov_classic_32.png
Create ../doc/html
Create ./Makefile.am
Create ../kde_install.sh
Create ../povray.ini.in
Create ../Makefile.am
Create ../bootstrap
Create ../source/Makefile.am
Create ../vfe/Makefile.am
Run ../bootstrap
+ rm -f config.log config.status
+ aclocal -I .
configure.ac:302: warning: AC_LANG_CONFTEST: no AC_LANG_SOURCE call
detected in body
../../lib/autoconf/lang.m4:193: AC_LANG_CONFTEST is expanded from...
../../lib/autoconf/general.m4:2590: _AC_COMPILE_IFELSE is expanded from...
../../lib/autoconf/general.m4:2606: AC_COMPILE_IFELSE is expanded from...
../../lib/m4sugar/m4sh.m4:639: AS_IF is expanded from...
../../lib/autoconf/general.m4:2031: AC_CACHE_VAL is expanded from...
../../lib/autoconf/general.m4:2052: AC_CACHE_CHECK is expanded from...
unix/config/ax_boost_thread.m4:32: AX_BOOST_THREAD is expanded from...
configure.ac:302: the top level
+ autoheader --warnings=all
detected in body
+ automake --warnings=all
detected in body
+ autoconf --warnings=all
configure.ac:295: warning: The macro `AC_LANG_SAVE' is obsolete.
configure.ac:295: You should run autoupdate.
../../lib/autoconf/lang.m4:125: AC_LANG_SAVE is expanded from...
unix/config/acx_pthread.m4:78: ACX_PTHREAD is expanded from...
configure.ac:295: the top level
configure.ac:295: warning: The macro `AC_LANG_C' is obsolete.
../../lib/autoconf/c.m4:72: AC_LANG_C is expanded from...
configure.ac:295: warning: The macro `AC_TRY_LINK' is obsolete.
../../lib/autoconf/general.m4:2687: AC_TRY_LINK is expanded from...
configure.ac:295: warning: The macro `AC_LANG_RESTORE' is obsolete.
../../lib/autoconf/lang.m4:134: AC_LANG_RESTORE is expanded from...
detected in body
+ cat ./configure
+ sed -e s,configure.gnu  --help=recursive,& --srcdir=$ac_srcdir,g -e
s,\(cd \)\($ac_\)\(pop\)*\(dir\),\1"\2\3\4",g -e
s,$am_aux_dir/missing,\\"$am_aux_dir\\"/missing,g
+ mv -f ./configure.tmp ./configure
+ chmod +x ./configure
+ rm -f -r ./autom4te.cache
3.7.0 stable, as documented here:
https://github.com/POV-Ray/povray/tree/3.7-stable
Yadgar
Date: 4 Jul 2015 18:17:23
Message: <55985b73$1@news.povray.org>
Hi(gh)!
Does not work with me... I got:
automake: `configure.ac' or `configure.in' is required
Perhaps my system is not modern enough...
Yadgar
Date: 4 Jul 2015 20:30:46
Message: <55987ab6@news.povray.org>
Am 05.07.2015 um 00:14 schrieb "Jörg \"Yadgar\" Bleimann":
> detected in body
That's pretty unusual AFAIK, and might be related to the problems.
Date: 7 Jul 2015 13:07:19
Message: <559c0747$1@news.povray.org>
Hi(gh)!
>> detected in body
And now? I have no clue about all that... will I ever be able to compile
POV-Ray 3.7 on my own?
Yadgar
Date: 7 Jul 2015 21:41:22
Message: <559c7fc2$1@news.povray.org>
Am 07.07.2015 um 19:07 schrieb "Jörg \"Yadgar\" Bleimann":
> Hi(gh)!
>>> detected in body
Don't know - my Linux expertise ends here. I'm a Windows jockey after
all, and I have no Debian installation at my disposal to dig deeper into
the issue.
Date: 8 Jul 2015 02:09:30
Message: <559cbe9a$1@news.povray.org>
Le 05/07/2015 00:17, "Jörg \"Yadgar\" Bleimann" a écrit :
> Hi(gh)!
you ran it as a sequence, right ?
And when stating "root" directory, I meant the root of the source tree
of povray ( so, it's the "." of "./unix", not the "/" )
Date: 8 Jul 2015 06:54:55
Message: <559d017f$1@news.povray.org>
Hi(gh)!
O.k., second try...
Now it generally worked, but with automake, I got one warning:
detected in body
Yadgar
Date: 8 Jul 2015 13:46:21
Message: <559d61ed$1@news.povray.org>
Hash: SHA256
Le 08/07/2015 12:55, "Jörg \"Yadgar\" Bleimann" a écrit :
> Hi(gh)!
>> you ran it as a sequence, right ? And when stating "root"
>> directory, I meant the root of the source tree of povray ( so,
> O.k., second try...
> call detected in body
Well, it's only a warning, a perfect world would have no warning, but
who live in a perfect world ?
You said "it generally worked" :
 did you succeed to build povray ?
> Yadgar
Version: GnuPG v2
iJwEAQEIAAYFAlWdYe0ACgkQhKAm8mTpkW1ufgP+KLXsA0DdGHRornRe8Bu37wy4
2YHpW11w6cwpU141l0eyKTf0kPDup6+IugEWXDqM975p8Vc36eDs65NzYY/rKQIv
mRmX1sJexuNZI8sUh7DAIUxkXwO5GCdZxfv0K5ABBJGTZm26YVn8T4K9VSShVu+K
Y6SQ9KLN1bPBi7ouJKw=
=rxBg
Date: 14 Jul 2015 02:38:02
Message: <55a4ae4a$1@news.povray.org>
On 07/07/2015 01:07 PM, "Jörg \"Yadgar\" Bleimann" wrote:
> Hi(gh)!
>>> detected in body
still having problems ... or have you given up?
Date: 14 Jul 2015 02:45:41
Message: <55a4b015$1@news.povray.org>
On 07/04/2015 06:14 PM, "Jörg \"Yadgar\" Bleimann" wrote:
> Hi(gh)!
> Create ../AUTHORS
> Create ../ChangeLog
> Create ../COPYING
> Create ../NEWS
> Create ../README
> Create ../VERSION
> Create ../povray.1
> Create ../scripts/
> Create ../ini/
> Create ../include/
> Create ../scenes/
> Create ../INSTALL
> Create ../doc/html
> Create ../bootstrap
> Run ../bootstrap
> + aclocal -I .
> detected in body
> detected in body
> detected in body
> detected in body
> + cat ./configure
> Yadgar
your prebuild.sh output looks fine ... these WARNINGS appear in my build
process and have never stopped me from successfully compiling. I'd be
more interested in what you output from configure looks like at this point
Date: 26 Jul 2015 08:22:02
Message: <55b4d0ea@news.povray.org>
Hi(gh)!
O. k., once again:
./prebuild.sh :
// begin messages
Create ../AUTHORS
Create ../ChangeLog
Create ../COPYING
Create ../NEWS
Create ../README
Create ../VERSION
Create ../povray.1
Create ../scripts/
Create ../ini/
Create ../include/
Create ../scenes/
Create ../INSTALL
Create ../doc/html
Create ../bootstrap
Run ../bootstrap
+ aclocal -I .
detected in body
detected in body
detected in body
detected in body
+ cat ./configure
// end messages
./configure COMPILED_BY="Jörg 'Yadgar' Bleimann <yaz### [at] gmxde>" :
// begin messages
Configure POV-Ray version 3.7.0
This is an unofficial version compiled by:
The POV-Ray Team(tm) is not responsible for supporting this version.
Environment
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking whether $C_INCLUDE_PATH contains the "." path... no
checking whether $CPLUS_INCLUDE_PATH contains the "." path... no
Programs
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for stdlib.h... (cached) yes
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking whether the g++ compiler works... yes
checking how to run the C++ preprocessor... g++ -E
checking for C++ compiler vendor... gnu
checking for g++ version... 4.7
checking for ranlib... ranlib
Libraries
checking whether to link with cygwin DLL... no
checking whether to enable static linking... no
checking for the pthreads library -lpthreads... no
checking whether pthreads work without any flags... no
checking whether pthreads work with -Kthread... no
checking whether pthreads work with -kthread... no
checking for the pthreads library -llthread... no
checking whether pthreads work with -pthread... yes
checking for joinable pthread attribute... PTHREAD_CREATE_JOINABLE
checking if more special flags are required for pthreads... no
checking for boostlib >= 1.37... yes
checking whether the Boost::Thread library is available... yes
checking whether the boost thread library is usable... yes
checking for sin in -lmkl... no
checking for sin in -lm... yes
checking for clock_gettime in -lrt... yes
checking whether to use the ZLIB library... yes
checking for library containing zlibVersion... -lz
checking zlib.h usability... yes
checking zlib.h presence... yes
checking for zlib.h... yes
checking for libz version >= 1.2.1... 1.2.7, ok
checking whether to use the PNG library... yes
checking for library containing png_get_libpng_ver... -lpng
checking png.h usability... yes
checking png.h presence... yes
checking for png.h... yes
checking for libpng version >= 1.2.5... 1.2.49, ok
checking whether to use the JPEG library... yes
checking for library containing jpeg_std_error... -ljpeg
checking jpeglib.h usability... yes
checking jpeglib.h presence... yes
checking for jpeglib.h... yes
checking for libjpeg version >= 6b (62)... 80, ok
checking whether to use the TIFF library... yes
checking for library containing TIFFGetVersion... -ltiff
checking tiffio.h usability... yes
checking tiffio.h presence... yes
checking for tiffio.h... yes
checking for libtiff version >= 3.6.1... 4.0.2, ok
checking whether to use the OpenEXR library... yes
checking for pkg-config... no
checking for OpenEXR's pkg-config... not found
configure: WARNING: all program features using the OpenEXR library are
disabled
checking for X... libraries /usr/lib, headers /usr/include
checking whether -R must be followed by a space... neither works
checking for dnet_ntoa in -ldnet... no
checking for dnet_ntoa in -ldnet_stub... no
checking for gethostbyname... yes
checking for connect... yes
checking for remove... yes
checking for shmat... yes
checking for IceConnectionNumber in -lICE... no
checking X11/Xlib.h usability... no
checking X11/Xlib.h presence... no
checking for X11/Xlib.h... no
Language constructs and functions
checking whether time.h and sys/time.h may both be included... yes
checking time.h usability... yes
checking time.h presence... yes
checking for time.h... yes
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking sys/resource.h usability... yes
checking sys/resource.h presence... yes
checking for sys/resource.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking for unistd.h... (cached) yes
checking for size_t... yes
checking whether struct tm is in sys/time.h or time.h... time.h
checking size of int... 4
checking size of long int... 8
checking size of size_t... 8
checking size of float... 4
checking for working memcmp... yes
checking for vsnprintf... yes
checking for getcwd... yes
checking for readlink... yes
checking for nanosleep... yes
checking for clock_gettime... yes
checking for getrusage... yes
checking for gettimeofday... yes
checking for asinh... yes
Compiling
checking whether to enable pipes for communications... yes
checking whether g++ accepts -pipe... yes
checking whether g++ accepts -Wno-multichar... yes
checking whether g++ accepts -Wno-write-strings... yes
checking whether g++ accepts -fno-enforce-eh-specs... yes
checking whether to enable I/O restrictions... yes
checking whether to enable debugging... no
checking whether to enable profiling... no
checking whether to enable stripping... yes
checking whether g++ accepts -s... yes
checking whether to enable optimizations... yes
checking whether g++ accepts -O3... yes
checking whether g++ accepts -ffast-math... yes
checking whether to enable architecture-specific optimizations... yes
checking whether g++ accepts -xHost... no
checking whether g++ accepts -march=native... yes
checking which architecture to optimize for... x86_64-unknown-linux-gnu
(using -march=native)
Makefiles
configure: creating ./config.status
config.status: creating Makefile
config.status: creating source/Makefile
config.status: creating vfe/Makefile
config.status: creating unix/Makefile
config.status: creating config.h
config.status: config.h is unchanged
config.status: executing depfiles commands
POV-Ray 3.7.0 has been configured.
Built-in features:
   I/O restrictions:          enabled
   X Window display:          disabled
   Supported image formats:   gif tga iff ppm pgm hdr png jpeg tiff
   Unsupported image formats: openexr
Compilation settings:
   Build architecture:  x86_64-unknown-linux-gnu
   Built/Optimized for: x86_64-unknown-linux-gnu (using -march=native)
   Compiler vendor:     gnu
   Compiler version:    g++ 4.7
   Compiler flags:      -pipe -Wno-multichar -Wno-write-strings
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -pthread
Type 'make check' to build the program and run a test render.
Type 'make install' to install POV-Ray on your system.
The POV-Ray components will be installed in the following directories:
   Program (executable):       /usr/local/bin
   System configuration files: /usr/local/etc/povray/3.7
   User configuration files:   /root/.povray/3.7
   Standard include files:     /usr/local/share/povray-3.7/include
   Standard INI files:         /usr/local/share/povray-3.7/ini
   Standard demo scene files:  /usr/local/share/povray-3.7/scenes
   Documentation (text, HTML): /usr/local/share/doc/povray-3.7
   Unix man page:              /usr/local/share/man
// end messages
make:
// begin messages
make  all-recursive
make[1]: Entering directory `/media/Raytracing/povray-3.7-stable'
Making all in source
make[2]: Entering directory `/media/Raytracing/povray-3.7-stable/source'
g++ -DHAVE_CONFIG_H -I. -I..  -I.. -I../source/backend -I../source/base
-I../source/frontend -I../unix -I../vfe -I../vfe/unix -pthread
-I/usr/include  -pipe -Wno-multichar -Wno-write-strings
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -pthread -MT
povray.o -MD -MP -MF .deps/povray.Tpo -c -o povray.o `test -f
'backend/povray.cpp' || echo './'`backend/povray.cpp
mv -f .deps/povray.Tpo .deps/povray.Po
rm -f libpovray.a
ar cru libpovray.a precomp.o pov_mem.o optout.o lightgrp.o colour.o
spectral.o colutils.o polysolv.o splines.o chi2.o quatern.o mathutil.o
hcmplx.o matrices.o povray.o renderbackend.o benchmark.o
messagefactory.o fncode.o fnpovfpu.o fnintern.o normal.o pigment.o
texture.o interior.o media.o ray.o tracetask.o radiositytask.o
tracepixel.o trace.o rendertask.o boundingtask.o bcyl.o bsphere.o bbox.o
view.o threaddata.o scene.o atmosph.o objects.o camera.o
photonshootingtask.o rad_data.o point.o subsurface.o photonsortingtask.o
photonshootingstrategy.o photonstrategytask.o photons.o radiosity.o
photonestimationtask.o reswords.o parsestr.o function.o express.o
fnsyntax.o parse.o tokenize.o parstxtr.o pattern.o warps.o csg.o
isosurf.o quadrics.o discs.o mesh.o lathe.o torus.o polygon.o hfield.o
fpmetric.o poly.o sphsweep.o truetype.o super.o triangle.o prism.o
blob.o boxes.o cones.o ovus.o bezier.o sor.o spheres.o fractal.o
planes.o jitter.o msgutil.o statistics.o task.o randomsequences.o
imageutil.o octree.o taskqueue.o fileutil.o bsptree.o renderfrontend.o
console.o shelloutprocessing.o imagemessagehandler.o
processrenderoptions.o filemessagehandler.o display.o
parsermessagehandler.o animationprocessing.o rendermessagehandler.o
imageprocessing.o defaultplatformbase.o stringutilities.o timer.o
pov_err.o iff.o tiff.o jpeg.o encoding.o ppm.o openexr.o targa.o png.o
bmp.o image.o colourspace.o hdr.o pgm.o gif.o gifdecod.o povmscpp.o
moov.o animation.o textstream.o timrom.o crystal.o cyrvetic.o povlogo.o
textstreambuffer.o processoptions.o path.o fileinputoutput.o povms.o
ranlib libpovray.a
make[2]: Leaving directory `/media/Raytracing/povray-3.7-stable/source'
Making all in vfe
make[2]: Entering directory `/media/Raytracing/povray-3.7-stable/vfe'
make[2]: Für das Ziel »all« ist nichts zu tun.
make[2]: Leaving directory `/media/Raytracing/povray-3.7-stable/vfe'
Making all in unix
make[2]: Entering directory `/media/Raytracing/povray-3.7-stable/unix'
g++  -pipe -Wno-multichar -Wno-write-strings -fno-enforce-eh-specs -s
-O3 -ffast-math -march=native -pthread  -L/usr/lib -o povray disp_sdl.o
disp_text.o ../vfe/libvfe.a ../source/libpovray.a -ltiff -ljpeg -lpng
-lz -lrt -lm   -pthread
../vfe/libvfe.a(unixconsole.o): In function
`boost::detail::thread_data<void (*)()>::~thread_data()':
unixconsole.cpp:(.text._ZN5boost6detail11thread_dataIPFvvEED2Ev[_ZN5boost6detail11thread_dataIPFvvEED5Ev]+0x8):
undefined reference to
`boost::detail::thread_data_base::~thread_data_base()'
unixconsole.cpp:(.text._ZN5boost6detail11thread_dataIPFvvEED0Ev[_ZN5boost6detail11thread_dataIPFvvEED0Ev]+0xc):
`boost::detail::thread_data_base::thread_data_base()':
unixconsole.cpp:(.text._ZN5boost6detail16thread_data_baseC2Ev[_ZN5boost6detail16thread_data_baseC5Ev]+0x22):
undefined reference to `vtable for boost::detail::thread_data_base'
../vfe/libvfe.a(unixconsole.o): In function `boost::thread::thread<void
(*)()>(void (*)(), boost::disable_if<boost::is_convertible<void (*&)(),
boost::detail::thread_move_t<void (*)()> >, boost::thread::dummy*>::type)':
unixconsole.cpp:(.text._ZN5boost6threadC2IPFvvEEET_NS_10disable_ifINS_14is_convertibleIRS4_NS_6detail13thread_move_tIS4_EEEEPNS0_5dummyEE4typeE[_ZN5boost6threadC5IPFvvEEET_NS_10disable_ifINS_14is_convertibleIRS4_NS_6detail13thread_move_tIS4_EEEEPNS0_5dummyEE4typeE]+0x3c):
undefined reference to `boost::thread::start_thread()'
../vfe/libvfe.a(unixconsole.o): In function `main':
unixconsole.cpp:(.text.startup+0x33e): undefined reference to
`boost::thread::~thread()'
unixconsole.cpp:(.text.startup+0x758): undefined reference to
unixconsole.cpp:(.text.startup+0xaea): undefined reference to
../vfe/libvfe.a(unixconsole.o):(.rodata._ZTIN5boost6detail11thread_dataIPFvvEEE[_ZTIN5boost6detail11thread_dataIPFvvEEE]+0x10):
undefined reference to `typeinfo for boost::detail::thread_data_base'
../vfe/libvfe.a(vfesession.o): In function
`vfe::vfeSession::Shutdown(bool)':
vfesession.cpp:(.text+0x4f9): undefined reference to `boost::thread::join()'
vfesession.cpp:(.text+0x50d): undefined reference to
`vfe::vfeSession::WorkerThread()':
vfesession.cpp:(.text+0xe74): undefined reference to
`boost::this_thread::yield()'
`vfe::vfeSession::Initialize(vfe::vfeDestInfo*, vfe::vfeAuthInfo*)':
vfesession.cpp:(.text+0x23e6): undefined reference to
vfesession.cpp:(.text+0x23ff): undefined reference to
`boost::detail::thread_data<vfe::vfeSession::vfeSessionWorker>::~thread_data()':
vfesession.cpp:(.text._ZN5boost6detail11thread_dataIN3vfe10vfeSession16vfeSessionWorkerEED2Ev[_ZN5boost6detail11thread_dataIN3vfe10vfeSession16vfeSessionWorkerEED5Ev]+0x8):
vfesession.cpp:(.text._ZN5boost6detail11thread_dataIN3vfe10vfeSession16vfeSessionWorkerEED0Ev[_ZN5boost6detail11thread_dataIN3vfe10vfeSession16vfeSessionWorkerEED0Ev]+0xc):
`boost::detail::interruption_checker::interruption_checker(pthread_mutex_t*,
pthread_cond_t*)':
vfesession.cpp:(.text._ZN5boost6detail20interruption_checkerC2EP15pthread_mutex_tP14pthread_cond_t[_ZN5boost6detail20interruption_checkerC5EP15pthread_mutex_tP14pthread_cond_t]+0x14):
undefined reference to `boost::detail::get_current_thread_data()'
../vfe/libvfe.a(vfesession.o): In function `void
boost::condition_variable_any::wait<boost::unique_lock<boost::mutex>
 >(boost::unique_lock<boost::mutex>&)':
vfesession.cpp:(.text._ZN5boost22condition_variable_any4waitINS_11unique_lockINS_5mutexEEEEEvRT_[_ZN5boost22condition_variable_any4waitINS_11unique_lockINS_5mutexEEEEEvRT_]+0x77):
undefined reference to `boost::this_thread::interruption_point()'
`boost::thread::thread<vfe::vfeSession::vfeSessionWorker>(vfe::vfeSession::vfeSessionWorker,
boost::disable_if<boost::is_convertible<vfe::vfeSession::vfeSessionWorker&,
boost::detail::thread_move_t<vfe::vfeSession::vfeSessionWorker> >,
vfesession.cpp:(.text._ZN5boost6threadC2IN3vfe10vfeSession16vfeSessionWorkerEEET_NS_10disable_ifINS_14is_convertibleIRS5_NS_6detail13thread_move_tIS5_EEEEPNS0_5dummyEE4typeE[_ZN5boost6threadC5IN3vfe10vfeSession16vfeSessionWorkerEEET_NS_10disable_ifINS_14is_convertibleIRS5_NS_6detail13thread_move_tIS5_EEEEPNS0_5dummyEE4typeE]+0x3c):
../vfe/libvfe.a(vfesession.o): In function `bool
boost::condition_variable_any::timed_wait<boost::unique_lock<boost::mutex>
 >(boost::unique_lock<boost::mutex>&, boost::posix_time::ptime const&)':
vfesession.cpp:(.text._ZN5boost22condition_variable_any10timed_waitINS_11unique_lockINS_5mutexEEEEEbRT_RKNS_10posix_time5ptimeE[_ZN5boost22condition_variable_any10timed_waitINS_11unique_lockINS_5mutexEEEEEbRT_RKNS_10posix_time5ptimeE]+0xfc):
../vfe/libvfe.a(vfesession.o):(.rodata._ZTIN5boost6detail11thread_dataIN3vfe10vfeSession16vfeSessionWorkerEEE[_ZTIN5boost6detail11thread_dataIN3vfe10vfeSession16vfeSessionWorkerEEE]+0x10):
../source/libpovray.a(povray.o): In function `povray_terminate()':
povray.cpp:(.text+0x841): undefined reference to
povray.cpp:(.text+0x868): undefined reference to `boost::thread::join()'
povray.cpp:(.text+0x87c): undefined reference to `boost::thread::~thread()'
../source/libpovray.a(povray.o): In function `(anonymous
namespace)::MainThreadFunction(boost::function0<void> const&)':
povray.cpp:(.text+0x967): undefined reference to
`povray_init(boost::function0<void> const&, void**)':
povray.cpp:(.text+0xb61): undefined reference to
`boost::detail::thread_data<boost::_bi::bind_t<void, void
(*)(boost::function0<void> const&),
boost::_bi::list1<boost::_bi::value<boost::function0<void> > > >
 >::~thread_data()':
povray.cpp:(.text._ZN5boost6detail11thread_dataINS_3_bi6bind_tIvPFvRKNS_9function0IvEEENS2_5list1INS2_5valueIS5_EEEEEEED2Ev[_ZN5boost6detail11thread_dataINS_3_bi6bind_tIvPFvRKNS_9function0IvEEENS2_5list1INS2_5valueIS5_EEEEEEED5Ev]+0x31):
povray.cpp:(.text._ZN5boost6detail11thread_dataINS_3_bi6bind_tIvPFvRKNS_9function0IvEEENS2_5list1INS2_5valueIS5_EEEEEEED2Ev[_ZN5boost6detail11thread_dataINS_3_bi6bind_tIvPFvRKNS_9function0IvEEENS2_5list1INS2_5valueIS5_EEEEEEED5Ev]+0x26):
 >::thread_data(boost::_bi::bind_t<void, void (*)(boost::function0<void>
const&), boost::_bi::list1<boost::_bi::value<boost::function0<void> > > >)':
povray.cpp:(.text._ZN5boost6detail11thread_dataINS_3_bi6bind_tIvPFvRKNS_9function0IvEEENS2_5list1INS2_5valueIS5_EEEEEEEC2ESE_[_ZN5boost6detail11thread_dataINS_3_bi6bind_tIvPFvRKNS_9function0IvEEENS2_5list1INS2_5valueIS5_EEEEEEEC5ESE_]+0x4c):
`boost::thread::thread<boost::_bi::bind_t<void, void
 >(boost::_bi::bind_t<void, void (*)(boost::function0<void> const&),
boost::_bi::list1<boost::_bi::value<boost::function0<void> > > >,
boost::disable_if<boost::is_convertible<boost::_bi::bind_t<void, void
boost::_bi::list1<boost::_bi::value<boost::function0<void> > > >&,
boost::detail::thread_move_t<boost::_bi::bind_t<void, void
boost::_bi::list1<boost::_bi::value<boost::function0<void> > > > > >,
povray.cpp:(.text._ZN5boost6threadC2INS_3_bi6bind_tIvPFvRKNS_9function0IvEEENS2_5list1INS2_5valueIS5_EEEEEEEET_NS_10disable_ifINS_14is_convertibleIRSF_NS_6detail13thread_move_tISF_EEEEPNS0_5dummyEE4typeE[_ZN5boost6threadC5INS_3_bi6bind_tIvPFvRKNS_9function0IvEEENS2_5list1INS2_5valueIS5_EEEEEEEET_NS_10disable_ifINS_14is_convertibleIRSF_NS_6detail13thread_move_tISF_EEEEPNS0_5dummyEE4typeE]+0x48):
../source/libpovray.a(povray.o):(.rodata._ZTIN5boost6detail11thread_dataINS_3_bi6bind_tIvPFvRKNS_9function0IvEEENS2_5list1INS2_5valueIS5_EEEEEEEE[_ZTIN5boost6detail11thread_dataINS_3_bi6bind_tIvPFvRKNS_9function0IvEEENS2_5list1INS2_5valueIS5_EEEEEEEE]+0x10):
../source/libpovray.a(view.o): In function
`pov::View::RenderControlThread()':
view.cpp:(.text+0xa1): undefined reference to `boost::this_thread::yield()'
../source/libpovray.a(view.o): In function `pov::View::~View()':
view.cpp:(.text+0x1e02): undefined reference to `boost::thread::join()'
view.cpp:(.text+0x1e16): undefined reference to `boost::thread::~thread()'
boost::_mfi::mf0<void, pov::View>,
boost::_bi::list1<boost::_bi::value<pov::View*> > > >::~thread_data()':
view.cpp:(.text._ZN5boost6detail11thread_dataINS_3_bi6bind_tIvNS_4_mfi3mf0IvN3pov4ViewEEENS2_5list1INS2_5valueIPS7_EEEEEEED2Ev[_ZN5boost6detail11thread_dataINS_3_bi6bind_tIvNS_4_mfi3mf0IvN3pov4ViewEEENS2_5list1INS2_5valueIPS7_EEEEEEED5Ev]+0x8):
view.cpp:(.text._ZN5boost6detail11thread_dataINS_3_bi6bind_tIvNS_4_mfi3mf0IvN3pov4ViewEEENS2_5list1INS2_5valueIPS7_EEEEEEED0Ev[_ZN5boost6detail11thread_dataINS_3_bi6bind_tIvNS_4_mfi3mf0IvN3pov4ViewEEENS2_5list1INS2_5valueIPS7_EEEEEEED0Ev]+0xc):
`boost::thread::thread<boost::_bi::bind_t<void, boost::_mfi::mf0<void,
pov::View>, boost::_bi::list1<boost::_bi::value<pov::View*> > >
 >(boost::_bi::bind_t<void, boost::_mfi::mf0<void, pov::View>,
boost::_bi::list1<boost::_bi::value<pov::View*> > >,
boost::_bi::list1<boost::_bi::value<pov::View*> > >&,
boost::_bi::list1<boost::_bi::value<pov::View*> > > > >,
view.cpp:(.text._ZN5boost6threadC2INS_3_bi6bind_tIvNS_4_mfi3mf0IvN3pov4ViewEEENS2_5list1INS2_5valueIPS7_EEEEEEEET_NS_10disable_ifINS_14is_convertibleIRSF_NS_6detail13thread_move_tISF_EEEEPNS0_5dummyEE4typeE[_ZN5boost6threadC5INS_3_bi6bind_tIvNS_4_mfi3mf0IvN3pov4ViewEEENS2_5list1INS2_5valueIPS7_EEEEEEEET_NS_10disable_ifINS_14is_convertibleIRSF_NS_6detail13thread_move_tISF_EEEEPNS0_5dummyEE4typeE]+0x3d):
../source/libpovray.a(view.o):(.rodata._ZTIN5boost6detail11thread_dataINS_3_bi6bind_tIvNS_4_mfi3mf0IvN3pov4ViewEEENS2_5list1INS2_5valueIPS7_EEEEEEEE[_ZTIN5boost6detail11thread_dataINS_3_bi6bind_tIvNS_4_mfi3mf0IvN3pov4ViewEEENS2_5list1INS2_5valueIPS7_EEEEEEEE]+0x10):
../source/libpovray.a(scene.o): In function
`pov::Scene::ParserControlThread()':
scene.cpp:(.text+0x81): undefined reference to `boost::this_thread::yield()'
../source/libpovray.a(scene.o): In function `pov::Scene::~Scene()':
scene.cpp:(.text+0xa60): undefined reference to `boost::thread::join()'
scene.cpp:(.text+0xa74): undefined reference to `boost::thread::~thread()'
boost::_mfi::mf0<void, pov::Scene>,
boost::_bi::list1<boost::_bi::value<pov::Scene*> > > >::~thread_data()':
scene.cpp:(.text._ZN5boost6detail11thread_dataINS_3_bi6bind_tIvNS_4_mfi3mf0IvN3pov5SceneEEENS2_5list1INS2_5valueIPS7_EEEEEEED2Ev[_ZN5boost6detail11thread_dataINS_3_bi6bind_tIvNS_4_mfi3mf0IvN3pov5SceneEEENS2_5list1INS2_5valueIPS7_EEEEEEED5Ev]+0x8):
scene.cpp:(.text._ZN5boost6detail11thread_dataINS_3_bi6bind_tIvNS_4_mfi3mf0IvN3pov5SceneEEENS2_5list1INS2_5valueIPS7_EEEEEEED0Ev[_ZN5boost6detail11thread_dataINS_3_bi6bind_tIvNS_4_mfi3mf0IvN3pov5SceneEEENS2_5list1INS2_5valueIPS7_EEEEEEED0Ev]+0xc):
pov::Scene>, boost::_bi::list1<boost::_bi::value<pov::Scene*> > >
 >(boost::_bi::bind_t<void, boost::_mfi::mf0<void, pov::Scene>,
boost::_bi::list1<boost::_bi::value<pov::Scene*> > >,
boost::_bi::list1<boost::_bi::value<pov::Scene*> > >&,
boost::_bi::list1<boost::_bi::value<pov::Scene*> > > > >,
scene.cpp:(.text._ZN5boost6threadC2INS_3_bi6bind_tIvNS_4_mfi3mf0IvN3pov5SceneEEENS2_5list1INS2_5valueIPS7_EEEEEEEET_NS_10disable_ifINS_14is_convertibleIRSF_NS_6detail13thread_move_tISF_EEEEPNS0_5dummyEE4typeE[_ZN5boost6threadC5INS_3_bi6bind_tIvNS_4_mfi3mf0IvN3pov5SceneEEENS2_5list1INS2_5valueIPS7_EEEEEEEET_NS_10disable_ifINS_14is_convertibleIRSF_NS_6detail13thread_move_tISF_EEEEPNS0_5dummyEE4typeE]+0x3d):
../source/libpovray.a(scene.o):(.rodata._ZTIN5boost6detail11thread_dataINS_3_bi6bind_tIvNS_4_mfi3mf0IvN3pov5SceneEEENS2_5list1INS2_5valueIPS7_EEEEEEEE[_ZTIN5boost6detail11thread_dataINS_3_bi6bind_tIvNS_4_mfi3mf0IvN3pov5SceneEEENS2_5list1INS2_5valueIPS7_EEEEEEEE]+0x10):
../source/libpovray.a(photonstrategytask.o): In function
`pov::PhotonStrategyTask::SearchThroughObjectsCreateUnits(std::vector<pov::ObjectBase*,
std::allocator<pov::ObjectBase*> >&, pov::LightSource*)':
photonstrategytask.cpp:(.text+0x369): undefined reference to
`pov::PhotonStrategyTask::Run()':
photonstrategytask.cpp:(.text+0x4f9): undefined reference to
../source/libpovray.a(photonestimationtask.o): In function
`pov::PhotonEstimationTask::SearchThroughObjectsEstimatePhotons(std::vector<pov::ObjectBase*,
photonestimationtask.cpp:(.text+0x369): undefined reference to
../source/libpovray.a(task.o): In function `pov::Task::Stop()':
task.cpp:(.text+0xb7): undefined reference to `boost::thread::join()'
task.cpp:(.text+0xc8): undefined reference to `boost::thread::~thread()'
../source/libpovray.a(task.o): In function `pov::Task::~Task()':
task.cpp:(.text+0x1de): undefined reference to `boost::thread::join()'
task.cpp:(.text+0x1ef): undefined reference to `boost::thread::~thread()'
task.cpp:(.text+0x33e): undefined reference to `boost::thread::join()'
task.cpp:(.text+0x34f): undefined reference to `boost::thread::~thread()'
boost::_mfi::mf1<void, pov::Task, boost::function0<void> const&>,
boost::_bi::list2<boost::_bi::value<pov::Task*>,
boost::_bi::value<boost::function0<void> > > > >::~thread_data()':
task.cpp:(.text._ZN5boost6detail11thread_dataINS_3_bi6bind_tIvNS_4_mfi3mf1IvN3pov4TaskERKNS_9function0IvEEEENS2_5list2INS2_5valueIPS7_EENSE_IS9_EEEEEEED2Ev[_ZN5boost6detail11thread_dataINS_3_bi6bind_tIvNS_4_mfi3mf1IvN3pov4TaskERKNS_9function0IvEEEENS2_5list2INS2_5valueIPS7_EENSE_IS9_EEEEEEED5Ev]+0x31):
task.cpp:(.text._ZN5boost6detail11thread_dataINS_3_bi6bind_tIvNS_4_mfi3mf1IvN3pov4TaskERKNS_9function0IvEEEENS2_5list2INS2_5valueIPS7_EENSE_IS9_EEEEEEED2Ev[_ZN5boost6detail11thread_dataINS_3_bi6bind_tIvNS_4_mfi3mf1IvN3pov4TaskERKNS_9function0IvEEEENS2_5list2INS2_5valueIPS7_EENSE_IS9_EEEEEEED5Ev]+0x26):
boost::_bi::value<boost::function0<void> > > > >*
boost::detail::heap_new_impl<boost::detail::thread_data<boost::_bi::bind_t<void,
boost::_bi::value<boost::function0<void> > > > >,
boost::_bi::bind_t<void, boost::_mfi::mf1<void, pov::Task,
 >&>(boost::_bi::bind_t<void, boost::_mfi::mf1<void, pov::Task,
boost::_bi::value<boost::function0<void> > > >&)':
task.cpp:(.text._ZN5boost6detail13heap_new_implINS0_11thread_dataINS_3_bi6bind_tIvNS_4_mfi3mf1IvN3pov4TaskERKNS_9function0IvEEEENS3_5list2INS3_5valueIPS8_EENSF_ISA_EEEEEEEERSK_EEPT_T0_[_ZN5boost6detail13heap_new_implINS0_11thread_dataINS_3_bi6bind_tIvNS_4_mfi3mf1IvN3pov4TaskERKNS_9function0IvEEEENS3_5list2INS3_5valueIPS8_EENSF_ISA_EEEEEEEERSK_EEPT_T0_]+0x6a):
`boost::thread::thread<boost::_bi::bind_t<void, boost::_mfi::mf1<void,
task.cpp:(.text._ZN5boost6threadC2INS_3_bi6bind_tIvNS_4_mfi3mf1IvN3pov4TaskERKNS_9function0IvEEEENS2_5list2INS2_5valueIPS7_EENSE_IS9_EEEEEEEET_NS_10disable_ifINS_14is_convertibleIRSK_NS_6detail13thread_move_tISK_EEEEPNS0_5dummyEE4typeE[_ZN5boost6threadC5INS_3_bi6bind_tIvNS_4_mfi3mf1IvN3pov4TaskERKNS_9function0IvEEEENS2_5list2INS2_5valueIPS7_EENSE_IS9_EEEEEEEET_NS_10disable_ifINS_14is_convertibleIRSK_NS_6detail13thread_move_tISK_EEEEPNS0_5dummyEE4typeE]+0x32):
../source/libpovray.a(task.o):(.rodata._ZTIN5boost6detail11thread_dataINS_3_bi6bind_tIvNS_4_mfi3mf1IvN3pov4TaskERKNS_9function0IvEEEENS2_5list2INS2_5valueIPS7_EENSE_IS9_EEEEEEEE[_ZTIN5boost6detail11thread_dataINS_3_bi6bind_tIvNS_4_mfi3mf1IvN3pov4TaskERKNS_9function0IvEEEENS2_5list2INS2_5valueIPS7_EENSE_IS9_EEEEEEEE]+0x10):
../source/libpovray.a(taskqueue.o): In function `void
boost::condition_variable_any::wait<boost::unique_lock<boost::recursive_mutex>
 >(boost::unique_lock<boost::recursive_mutex>&)':
taskqueue.cpp:(.text._ZN5boost22condition_variable_any4waitINS_11unique_lockINS_15recursive_mutexEEEEEvRT_[_ZN5boost22condition_variable_any4waitINS_11unique_lockINS_15recursive_mutexEEEEEvRT_]+0x5c):
../source/libpovray.a(tracetask.o): In function
`pov::TraceTask::SupersampleOnePixel(double, double,
pov_base::GenericColour<float>&)':
tracetask.cpp:(.text+0xce1): undefined reference to
`pov::TraceTask::SimpleSamplingM0()':
tracetask.cpp:(.text+0x2241): undefined reference to
`pov::TraceTask::SimpleSamplingM0P()':
tracetask.cpp:(.text+0x2769): undefined reference to
`pov::TraceTask::AdaptiveSupersamplingM2()':
tracetask.cpp:(.text+0x2e99): undefined reference to
tracetask.cpp:(.text+0x31e9): undefined reference to
../source/libpovray.a(tracetask.o):tracetask.cpp:(.text+0x3649): more
undefined references to `boost::this_thread::yield()' follow
collect2: error: ld returned 1 exit status
make[2]: *** [povray] Fehler 1
make[2]: Leaving directory `/media/Raytracing/povray-3.7-stable/unix'
make[1]: *** [all-recursive] Fehler 1
make[1]: Leaving directory `/media/Raytracing/povray-3.7-stable'
make: *** [all] Fehler 2
// end messages
note: German "Fehler" translates as "error"
So, obviously "make" yielded several errors...
Yadgar
Date: 26 Jul 2015 08:40:58
Message: <55b4d55a@news.povray.org>
Hash: SHA256
Le 26/07/2015 14:22, "Jörg \"Yadgar\" Bleimann" a écrit :
configure, for your system, would enjoy :
 $ ./configure COMPILED_BY="as you did" LIBS="-lboost_system
- -lboost_thread"
> `/media/Raytracing/povray-3.7-stable/unix' g++  -pipe
> -Wno-multichar -Wno-write-strings -fno-enforce-eh-specs -s -O3
> disp_sdl.o disp_text.o ../vfe/libvfe.a ../source/libpovray.a -ltiff
> -ljpeg -lpng -lz -lrt -lm   -pthread
> `boost::thread::thread<void (*)()>(void (*)(),
Version: GnuPG v2
iJwEAQEIAAYFAlW01VkACgkQhKAm8mTpkW2v0gP/WV8pNm/rgcXL0O9ErMSq/3jj
Y+HJyTJsdj02Elo8hOSJ1d1gvMQ4uc7Bd6rnF0umiWc842rM2dZiauVP5N1qG7jz
vUKEQ2xyOoo8l+wDr4b2XEimeItFrvmQbhdlCb7bjiI++yC6ADzFedFpJF6CN0sM
iZvz/2RT7GyuPovTCaQ=
=FCqg
Date: 26 Jul 2015 11:09:47
Message: <55b4f83b$1@news.povray.org>
> - -lboost_thread"
Even worse:
Environment
Programs
checking whether the C compiler works... no
configure: error: in `/media/Raytracing/povray-3.7-stable':
configure: error: C compiler cannot create executables
See `config.log' for more details
configure: WARNING: cache variable ac_cv_env_LIBS_value contains a newline
Yadgar
Date: 26 Jul 2015 12:32:45
Message: <55b50bad$1@news.povray.org>
>> - -lboost_thread"
> Yadgar
Unsure if your issue, but I believe there is an extra dash above between
the two library specs. Perhaps try:
LIBS="-lboost_system -lboost_thread"
if you have not already.
Bill P.
Date: 26 Jul 2015 14:00:01
Message: <web.55b51f8830d76883373e22480@news.povray.org>
> > - -lboost_thread"
> Even worse:
> Environment
> Programs
> Yadgar
i hate linux and i know nothing about it, but i needed to 'do stuff' with
linux povray so i had to compile it on four different machines (two identical,
well, mostly) recently.  your problems look disgustingly familiar to me.  the
following is more advice than directions but maybe it will give you an idea
for a new course.
  this is for xubuntu 14.04
it looks like you did, or did not need, the automake --add-missing step.
i found the directions to add libboost to be inadequate; for me using synaptic
to add libboost1.55-all-dev fixed whatever it was that was ailing; it might
have been, i am pretty sure i remember this, well i think i remember this, or
maybe i dreamed it, gcc did not have sufficient c++ junk/whatever.  the last
time i compiled, four days ago, i just added it fairly early in the hair-
-pulling process and compilation was almost painless.  the 'make' step was snafu
but when i retried it, it worked.  go figure.
my configure line finally ended up being
../configure COMPILED_BY="whatever..." --with-boost-thread=boost_thread
i got there by carefully comparing various recommendations and then typing like
a monkey, randomly.
linux is a p.o.s.  i am trying to get that distributed dealy, httpov, to work,
well nominally trying, right now trying not to think about it, it is proving
to be a steeper hill than compilation.
  i hate linux.  it is 17% faster than winxp64 and 25% faster than winxp32 on
my three lesser machines (not as much faster on the best one) but i still
hate it.  user hostile!
Date: 27 Jul 2015 14:56:14
Message: <55b67ece$1@news.povray.org>
>>> - -lboost_thread"
>> Yadgar
that's the incantation ... try
then do:
make clean
make
Date: 27 Jul 2015 15:13:13
Message: <55b682c9$1@news.povray.org>
>>>> - -lboost_thread"
>>> Yadgar
> then do:
> make clean
> make
one more thing i wanted to follow up on but forgot ... from your
configure report I noticed that you don't have exr support or X Window
display
probably ok if you don't plan on using hdr or exr images. the one that
almost is a must have is X Window support. if you want these look for
the follow in your package manager:
openexr-devel - Library to Handle EXR Pictures (16-bit floating-point
format)
libSDL-devel - SDL Library Developer Files
of course you'll have to re-run configure, make clean, make ...
Date: 27 Jul 2015 19:03:45
Message: <55b6b8d1$1@news.povray.org>
Hi(gh)!
> Bill P.
Doesn't work either:
// begin messages
  Jörg "Yadgar" Bleimann <yaz### [at] gmxde>
Environment
Programs
// end messages
Yadgar
Now playing: My Life (Simple Minds)
Date: 27 Jul 2015 19:06:51
Message: <55b6b98b$1@news.povray.org>
Hi(gh)!
Oh, yes, and attached here is the config.log...
Yadgar
Download 'us-ascii' (10 KB)
Date: 27 Jul 2015 19:13:08
Message: <55b6bb04@news.povray.org>
Hi(gh)!
> format)
Not available with my current repository list...
X support really would be a fine amenity - with my recent installations
of POV-Ray 3.6 (and also 3.7) I wondered while POV-Ray displays no
correct rendering window (but rather a discoloration of other windows
present on the screen), while with an installation of 3.6 some three
years ago, the window was displayed correctly!
But I would like to postpone the installation of these packages until I
got 3.7 to work at all...
Yadgar
Date: 27 Jul 2015 23:42:47
Message: <55b6fa37@news.povray.org>
> a monkey, randomly.
Also does not work... here are the messages:
Environment
Programs
// end messages
config.log is attached!
Yadgar
Date: 28 Jul 2015 02:11:28
Message: <55b71d10@news.povray.org>
Le 28/07/2015 05:42, "Jörg \"Yadgar\" Bleimann" a écrit :
> configure:4732: gcc    conftest.c -lboost_system -lboost_thread >&5
> /usr/bin/ld: cannot find -lboost_system
> /usr/bin/ld: cannot find -lboost_thread
> configure:4736: $? = 1
of course the package libboost-all-dev was installed, wasn't it ?
And it installed libboost-system-dev and libboost-thread-dev ?
Date: 28 Jul 2015 07:10:12
Message: <55b76314@news.povray.org>
Hi(gh)!
No, it wasn't! So I did afterwards...
No, but rather libboost-system1-dev and libboost-thread1-dev, the latter
in two versions!
Now, on entering
./configure COMPILED_BY="Jörg \"Yadgar\" Bleimann <yaz### [at] gmxde>"
--with-boost-thread=boost_thread LIBS="-lboost_system -lboost_thread"
I get:
// begin messages
Environment
Programs
Libraries
checking whether pthreads work without any flags... yes
checking for exit in -lboost_thread... yes
disabled
Compiling
Makefiles
Built-in features:
// end messages
Looks like all worked fine!
Onward with make:
// begin messages
make  all-recursive
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT pov_mem.o -MD
-MP -MF .deps/pov_mem.Tpo -c -o pov_mem.o pov_mem.cpp
mv -f .deps/pov_mem.Tpo .deps/pov_mem.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT optout.o -MD
-MP -MF .deps/optout.Tpo -c -o optout.o optout.cpp
mv -f .deps/optout.Tpo .deps/optout.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT lightgrp.o
-MD -MP -MF .deps/lightgrp.Tpo -c -o lightgrp.o lightgrp.cpp
mv -f .deps/lightgrp.Tpo .deps/lightgrp.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT colour.o -MD
-MP -MF .deps/colour.Tpo -c -o colour.o `test -f
'backend/colour/colour.cpp' || echo './'`backend/colour/colour.cpp
mv -f .deps/colour.Tpo .deps/colour.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT spectral.o
-MD -MP -MF .deps/spectral.Tpo -c -o spectral.o `test -f
'backend/colour/spectral.cpp' || echo './'`backend/colour/spectral.cpp
mv -f .deps/spectral.Tpo .deps/spectral.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT colutils.o
-MD -MP -MF .deps/colutils.Tpo -c -o colutils.o `test -f
'backend/colour/colutils.cpp' || echo './'`backend/colour/colutils.cpp
mv -f .deps/colutils.Tpo .deps/colutils.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT polysolv.o
-MD -MP -MF .deps/polysolv.Tpo -c -o polysolv.o `test -f
'backend/math/polysolv.cpp' || echo './'`backend/math/polysolv.cpp
mv -f .deps/polysolv.Tpo .deps/polysolv.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT splines.o -MD
-MP -MF .deps/splines.Tpo -c -o splines.o `test -f
'backend/math/splines.cpp' || echo './'`backend/math/splines.cpp
mv -f .deps/splines.Tpo .deps/splines.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT chi2.o -MD
-MP -MF .deps/chi2.Tpo -c -o chi2.o `test -f 'backend/math/chi2.cpp' ||
echo './'`backend/math/chi2.cpp
mv -f .deps/chi2.Tpo .deps/chi2.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT quatern.o -MD
-MP -MF .deps/quatern.Tpo -c -o quatern.o `test -f
'backend/math/quatern.cpp' || echo './'`backend/math/quatern.cpp
mv -f .deps/quatern.Tpo .deps/quatern.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT mathutil.o
-MD -MP -MF .deps/mathutil.Tpo -c -o mathutil.o `test -f
'backend/math/mathutil.cpp' || echo './'`backend/math/mathutil.cpp
mv -f .deps/mathutil.Tpo .deps/mathutil.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT hcmplx.o -MD
-MP -MF .deps/hcmplx.Tpo -c -o hcmplx.o `test -f
'backend/math/hcmplx.cpp' || echo './'`backend/math/hcmplx.cpp
mv -f .deps/hcmplx.Tpo .deps/hcmplx.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT matrices.o
-MD -MP -MF .deps/matrices.Tpo -c -o matrices.o `test -f
'backend/math/matrices.cpp' || echo './'`backend/math/matrices.cpp
mv -f .deps/matrices.Tpo .deps/matrices.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT povray.o -MD
-MP -MF .deps/povray.Tpo -c -o povray.o `test -f 'backend/povray.cpp' ||
backend/povray.cpp: In function ‘void
{anonymous}::BuildInitInfo(POVMSObjectPtr)’:
backend/povray.cpp:265:57: error: expected ‘)’ before ‘Yadgar’
make[2]: *** [povray.o] Fehler 1
// end messages
Whoops! Another glitch in the call ;-) Seems it is because of incorrect
masking of " in configure, so I try configure using 'Yadgar' instead of
"Yadgar"... and then make:
// begin messages
make  all-recursive
renderbackend.o -MD -MP -MF .deps/renderbackend.Tpo -c -o
renderbackend.o `test -f 'backend/control/renderbackend.cpp' || echo
'./'`backend/control/renderbackend.cpp
mv -f .deps/renderbackend.Tpo .deps/renderbackend.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT benchmark.o
-MD -MP -MF .deps/benchmark.Tpo -c -o benchmark.o `test -f
'backend/control/benchmark.cpp' || echo './'`backend/control/benchmark.cpp
mv -f .deps/benchmark.Tpo .deps/benchmark.Po
messagefactory.o -MD -MP -MF .deps/messagefactory.Tpo -c -o
messagefactory.o `test -f 'backend/control/messagefactory.cpp' || echo
'./'`backend/control/messagefactory.cpp
mv -f .deps/messagefactory.Tpo .deps/messagefactory.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT fncode.o -MD
-MP -MF .deps/fncode.Tpo -c -o fncode.o `test -f 'backend/vm/fncode.cpp'
|| echo './'`backend/vm/fncode.cpp
mv -f .deps/fncode.Tpo .deps/fncode.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT fnpovfpu.o
-MD -MP -MF .deps/fnpovfpu.Tpo -c -o fnpovfpu.o `test -f
'backend/vm/fnpovfpu.cpp' || echo './'`backend/vm/fnpovfpu.cpp
mv -f .deps/fnpovfpu.Tpo .deps/fnpovfpu.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT fnintern.o
-MD -MP -MF .deps/fnintern.Tpo -c -o fnintern.o `test -f
'backend/vm/fnintern.cpp' || echo './'`backend/vm/fnintern.cpp
mv -f .deps/fnintern.Tpo .deps/fnintern.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT normal.o -MD
-MP -MF .deps/normal.Tpo -c -o normal.o `test -f
'backend/texture/normal.cpp' || echo './'`backend/texture/normal.cpp
mv -f .deps/normal.Tpo .deps/normal.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT pigment.o -MD
-MP -MF .deps/pigment.Tpo -c -o pigment.o `test -f
'backend/texture/pigment.cpp' || echo './'`backend/texture/pigment.cpp
mv -f .deps/pigment.Tpo .deps/pigment.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT texture.o -MD
-MP -MF .deps/texture.Tpo -c -o texture.o `test -f
'backend/texture/texture.cpp' || echo './'`backend/texture/texture.cpp
mv -f .deps/texture.Tpo .deps/texture.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT interior.o
-MD -MP -MF .deps/interior.Tpo -c -o interior.o `test -f
'backend/interior/interior.cpp' || echo './'`backend/interior/interior.cpp
mv -f .deps/interior.Tpo .deps/interior.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT media.o -MD
-MP -MF .deps/media.Tpo -c -o media.o `test -f
'backend/interior/media.cpp' || echo './'`backend/interior/media.cpp
mv -f .deps/media.Tpo .deps/media.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT ray.o -MD -MP
-MF .deps/ray.Tpo -c -o ray.o `test -f 'backend/render/ray.cpp' || echo
'./'`backend/render/ray.cpp
mv -f .deps/ray.Tpo .deps/ray.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT tracetask.o
-MD -MP -MF .deps/tracetask.Tpo -c -o tracetask.o `test -f
'backend/render/tracetask.cpp' || echo './'`backend/render/tracetask.cpp
mv -f .deps/tracetask.Tpo .deps/tracetask.Po
radiositytask.o -MD -MP -MF .deps/radiositytask.Tpo -c -o
radiositytask.o `test -f 'backend/render/radiositytask.cpp' || echo
'./'`backend/render/radiositytask.cpp
mv -f .deps/radiositytask.Tpo .deps/radiositytask.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT tracepixel.o
-MD -MP -MF .deps/tracepixel.Tpo -c -o tracepixel.o `test -f
'backend/render/tracepixel.cpp' || echo './'`backend/render/tracepixel.cpp
mv -f .deps/tracepixel.Tpo .deps/tracepixel.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT trace.o -MD
-MP -MF .deps/trace.Tpo -c -o trace.o `test -f
'backend/render/trace.cpp' || echo './'`backend/render/trace.cpp
mv -f .deps/trace.Tpo .deps/trace.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT rendertask.o
-MD -MP -MF .deps/rendertask.Tpo -c -o rendertask.o `test -f
'backend/render/rendertask.cpp' || echo './'`backend/render/rendertask.cpp
mv -f .deps/rendertask.Tpo .deps/rendertask.Po
boundingtask.o -MD -MP -MF .deps/boundingtask.Tpo -c -o boundingtask.o
`test -f 'backend/bounding/boundingtask.cpp' || echo
'./'`backend/bounding/boundingtask.cpp
mv -f .deps/boundingtask.Tpo .deps/boundingtask.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT bcyl.o -MD
-MP -MF .deps/bcyl.Tpo -c -o bcyl.o `test -f 'backend/bounding/bcyl.cpp'
|| echo './'`backend/bounding/bcyl.cpp
mv -f .deps/bcyl.Tpo .deps/bcyl.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT bsphere.o -MD
-MP -MF .deps/bsphere.Tpo -c -o bsphere.o `test -f
'backend/bounding/bsphere.cpp' || echo './'`backend/bounding/bsphere.cpp
mv -f .deps/bsphere.Tpo .deps/bsphere.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT bbox.o -MD
-MP -MF .deps/bbox.Tpo -c -o bbox.o `test -f 'backend/bounding/bbox.cpp'
|| echo './'`backend/bounding/bbox.cpp
mv -f .deps/bbox.Tpo .deps/bbox.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT view.o -MD
-MP -MF .deps/view.Tpo -c -o view.o `test -f 'backend/scene/view.cpp' ||
echo './'`backend/scene/view.cpp
mv -f .deps/view.Tpo .deps/view.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT threaddata.o
-MD -MP -MF .deps/threaddata.Tpo -c -o threaddata.o `test -f
'backend/scene/threaddata.cpp' || echo './'`backend/scene/threaddata.cpp
mv -f .deps/threaddata.Tpo .deps/threaddata.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT scene.o -MD
-MP -MF .deps/scene.Tpo -c -o scene.o `test -f 'backend/scene/scene.cpp'
|| echo './'`backend/scene/scene.cpp
mv -f .deps/scene.Tpo .deps/scene.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT atmosph.o -MD
-MP -MF .deps/atmosph.Tpo -c -o atmosph.o `test -f
'backend/scene/atmosph.cpp' || echo './'`backend/scene/atmosph.cpp
mv -f .deps/atmosph.Tpo .deps/atmosph.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT objects.o -MD
-MP -MF .deps/objects.Tpo -c -o objects.o `test -f
'backend/scene/objects.cpp' || echo './'`backend/scene/objects.cpp
mv -f .deps/objects.Tpo .deps/objects.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT camera.o -MD
-MP -MF .deps/camera.Tpo -c -o camera.o `test -f
'backend/scene/camera.cpp' || echo './'`backend/scene/camera.cpp
mv -f .deps/camera.Tpo .deps/camera.Po
photonshootingtask.o -MD -MP -MF .deps/photonshootingtask.Tpo -c -o
photonshootingtask.o `test -f 'backend/lighting/photonshootingtask.cpp'
|| echo './'`backend/lighting/photonshootingtask.cpp
mv -f .deps/photonshootingtask.Tpo .deps/photonshootingtask.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT rad_data.o
-MD -MP -MF .deps/rad_data.Tpo -c -o rad_data.o `test -f
'backend/lighting/rad_data.cpp' || echo './'`backend/lighting/rad_data.cpp
mv -f .deps/rad_data.Tpo .deps/rad_data.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT point.o -MD
-MP -MF .deps/point.Tpo -c -o point.o `test -f
'backend/lighting/point.cpp' || echo './'`backend/lighting/point.cpp
mv -f .deps/point.Tpo .deps/point.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT subsurface.o
-MD -MP -MF .deps/subsurface.Tpo -c -o subsurface.o `test -f
'backend/lighting/subsurface.cpp' || echo
'./'`backend/lighting/subsurface.cpp
mv -f .deps/subsurface.Tpo .deps/subsurface.Po
photonsortingtask.o -MD -MP -MF .deps/photonsortingtask.Tpo -c -o
photonsortingtask.o `test -f 'backend/lighting/photonsortingtask.cpp' ||
echo './'`backend/lighting/photonsortingtask.cpp
mv -f .deps/photonsortingtask.Tpo .deps/photonsortingtask.Po
photonshootingstrategy.o -MD -MP -MF .deps/photonshootingstrategy.Tpo -c
-o photonshootingstrategy.o `test -f
'backend/lighting/photonshootingstrategy.cpp' || echo
'./'`backend/lighting/photonshootingstrategy.cpp
mv -f .deps/photonshootingstrategy.Tpo .deps/photonshootingstrategy.Po
photonstrategytask.o -MD -MP -MF .deps/photonstrategytask.Tpo -c -o
photonstrategytask.o `test -f 'backend/lighting/photonstrategytask.cpp'
|| echo './'`backend/lighting/photonstrategytask.cpp
mv -f .deps/photonstrategytask.Tpo .deps/photonstrategytask.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT photons.o -MD
-MP -MF .deps/photons.Tpo -c -o photons.o `test -f
'backend/lighting/photons.cpp' || echo './'`backend/lighting/photons.cpp
mv -f .deps/photons.Tpo .deps/photons.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT radiosity.o
-MD -MP -MF .deps/radiosity.Tpo -c -o radiosity.o `test -f
'backend/lighting/radiosity.cpp' || echo './'`backend/lighting/radiosity.cpp
mv -f .deps/radiosity.Tpo .deps/radiosity.Po
photonestimationtask.o -MD -MP -MF .deps/photonestimationtask.Tpo -c -o
photonestimationtask.o `test -f
'backend/lighting/photonestimationtask.cpp' || echo
'./'`backend/lighting/photonestimationtask.cpp
mv -f .deps/photonestimationtask.Tpo .deps/photonestimationtask.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT reswords.o
-MD -MP -MF .deps/reswords.Tpo -c -o reswords.o `test -f
'backend/parser/reswords.cpp' || echo './'`backend/parser/reswords.cpp
mv -f .deps/reswords.Tpo .deps/reswords.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT parsestr.o
-MD -MP -MF .deps/parsestr.Tpo -c -o parsestr.o `test -f
'backend/parser/parsestr.cpp' || echo './'`backend/parser/parsestr.cpp
mv -f .deps/parsestr.Tpo .deps/parsestr.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT function.o
-MD -MP -MF .deps/function.Tpo -c -o function.o `test -f
'backend/parser/function.cpp' || echo './'`backend/parser/function.cpp
mv -f .deps/function.Tpo .deps/function.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT express.o -MD
-MP -MF .deps/express.Tpo -c -o express.o `test -f
'backend/parser/express.cpp' || echo './'`backend/parser/express.cpp
mv -f .deps/express.Tpo .deps/express.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT fnsyntax.o
-MD -MP -MF .deps/fnsyntax.Tpo -c -o fnsyntax.o `test -f
'backend/parser/fnsyntax.cpp' || echo './'`backend/parser/fnsyntax.cpp
mv -f .deps/fnsyntax.Tpo .deps/fnsyntax.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT parse.o -MD
-MP -MF .deps/parse.Tpo -c -o parse.o `test -f
'backend/parser/parse.cpp' || echo './'`backend/parser/parse.cpp
mv -f .deps/parse.Tpo .deps/parse.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT tokenize.o
-MD -MP -MF .deps/tokenize.Tpo -c -o tokenize.o `test -f
'backend/parser/tokenize.cpp' || echo './'`backend/parser/tokenize.cpp
mv -f .deps/tokenize.Tpo .deps/tokenize.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT parstxtr.o
-MD -MP -MF .deps/parstxtr.Tpo -c -o parstxtr.o `test -f
'backend/parser/parstxtr.cpp' || echo './'`backend/parser/parstxtr.cpp
mv -f .deps/parstxtr.Tpo .deps/parstxtr.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT pattern.o -MD
-MP -MF .deps/pattern.Tpo -c -o pattern.o `test -f
'backend/pattern/pattern.cpp' || echo './'`backend/pattern/pattern.cpp
mv -f .deps/pattern.Tpo .deps/pattern.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT warps.o -MD
-MP -MF .deps/warps.Tpo -c -o warps.o `test -f
'backend/pattern/warps.cpp' || echo './'`backend/pattern/warps.cpp
mv -f .deps/warps.Tpo .deps/warps.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT csg.o -MD -MP
-MF .deps/csg.Tpo -c -o csg.o `test -f 'backend/shape/csg.cpp' || echo
'./'`backend/shape/csg.cpp
mv -f .deps/csg.Tpo .deps/csg.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT isosurf.o -MD
-MP -MF .deps/isosurf.Tpo -c -o isosurf.o `test -f
'backend/shape/isosurf.cpp' || echo './'`backend/shape/isosurf.cpp
mv -f .deps/isosurf.Tpo .deps/isosurf.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT quadrics.o
-MD -MP -MF .deps/quadrics.Tpo -c -o quadrics.o `test -f
'backend/shape/quadrics.cpp' || echo './'`backend/shape/quadrics.cpp
mv -f .deps/quadrics.Tpo .deps/quadrics.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT discs.o -MD
-MP -MF .deps/discs.Tpo -c -o discs.o `test -f 'backend/shape/discs.cpp'
|| echo './'`backend/shape/discs.cpp
mv -f .deps/discs.Tpo .deps/discs.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT mesh.o -MD
-MP -MF .deps/mesh.Tpo -c -o mesh.o `test -f 'backend/shape/mesh.cpp' ||
echo './'`backend/shape/mesh.cpp
mv -f .deps/mesh.Tpo .deps/mesh.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT lathe.o -MD
-MP -MF .deps/lathe.Tpo -c -o lathe.o `test -f 'backend/shape/lathe.cpp'
|| echo './'`backend/shape/lathe.cpp
mv -f .deps/lathe.Tpo .deps/lathe.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT torus.o -MD
-MP -MF .deps/torus.Tpo -c -o torus.o `test -f 'backend/shape/torus.cpp'
|| echo './'`backend/shape/torus.cpp
mv -f .deps/torus.Tpo .deps/torus.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT polygon.o -MD
-MP -MF .deps/polygon.Tpo -c -o polygon.o `test -f
'backend/shape/polygon.cpp' || echo './'`backend/shape/polygon.cpp
mv -f .deps/polygon.Tpo .deps/polygon.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT hfield.o -MD
-MP -MF .deps/hfield.Tpo -c -o hfield.o `test -f
'backend/shape/hfield.cpp' || echo './'`backend/shape/hfield.cpp
mv -f .deps/hfield.Tpo .deps/hfield.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT fpmetric.o
-MD -MP -MF .deps/fpmetric.Tpo -c -o fpmetric.o `test -f
'backend/shape/fpmetric.cpp' || echo './'`backend/shape/fpmetric.cpp
mv -f .deps/fpmetric.Tpo .deps/fpmetric.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT poly.o -MD
-MP -MF .deps/poly.Tpo -c -o poly.o `test -f 'backend/shape/poly.cpp' ||
echo './'`backend/shape/poly.cpp
mv -f .deps/poly.Tpo .deps/poly.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT sphsweep.o
-MD -MP -MF .deps/sphsweep.Tpo -c -o sphsweep.o `test -f
'backend/shape/sphsweep.cpp' || echo './'`backend/shape/sphsweep.cpp
mv -f .deps/sphsweep.Tpo .deps/sphsweep.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT truetype.o
-MD -MP -MF .deps/truetype.Tpo -c -o truetype.o `test -f
'backend/shape/truetype.cpp' || echo './'`backend/shape/truetype.cpp
mv -f .deps/truetype.Tpo .deps/truetype.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT super.o -MD
-MP -MF .deps/super.Tpo -c -o super.o `test -f 'backend/shape/super.cpp'
|| echo './'`backend/shape/super.cpp
mv -f .deps/super.Tpo .deps/super.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT triangle.o
-MD -MP -MF .deps/triangle.Tpo -c -o triangle.o `test -f
'backend/shape/triangle.cpp' || echo './'`backend/shape/triangle.cpp
mv -f .deps/triangle.Tpo .deps/triangle.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT prism.o -MD
-MP -MF .deps/prism.Tpo -c -o prism.o `test -f 'backend/shape/prism.cpp'
|| echo './'`backend/shape/prism.cpp
mv -f .deps/prism.Tpo .deps/prism.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT blob.o -MD
-MP -MF .deps/blob.Tpo -c -o blob.o `test -f 'backend/shape/blob.cpp' ||
echo './'`backend/shape/blob.cpp
mv -f .deps/blob.Tpo .deps/blob.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT boxes.o -MD
-MP -MF .deps/boxes.Tpo -c -o boxes.o `test -f 'backend/shape/boxes.cpp'
|| echo './'`backend/shape/boxes.cpp
mv -f .deps/boxes.Tpo .deps/boxes.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT cones.o -MD
-MP -MF .deps/cones.Tpo -c -o cones.o `test -f 'backend/shape/cones.cpp'
|| echo './'`backend/shape/cones.cpp
mv -f .deps/cones.Tpo .deps/cones.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT ovus.o -MD
-MP -MF .deps/ovus.Tpo -c -o ovus.o `test -f 'backend/shape/ovus.cpp' ||
echo './'`backend/shape/ovus.cpp
mv -f .deps/ovus.Tpo .deps/ovus.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT bezier.o -MD
-MP -MF .deps/bezier.Tpo -c -o bezier.o `test -f
'backend/shape/bezier.cpp' || echo './'`backend/shape/bezier.cpp
mv -f .deps/bezier.Tpo .deps/bezier.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT sor.o -MD -MP
-MF .deps/sor.Tpo -c -o sor.o `test -f 'backend/shape/sor.cpp' || echo
'./'`backend/shape/sor.cpp
mv -f .deps/sor.Tpo .deps/sor.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT spheres.o -MD
-MP -MF .deps/spheres.Tpo -c -o spheres.o `test -f
'backend/shape/spheres.cpp' || echo './'`backend/shape/spheres.cpp
mv -f .deps/spheres.Tpo .deps/spheres.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT fractal.o -MD
-MP -MF .deps/fractal.Tpo -c -o fractal.o `test -f
'backend/shape/fractal.cpp' || echo './'`backend/shape/fractal.cpp
mv -f .deps/fractal.Tpo .deps/fractal.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT planes.o -MD
-MP -MF .deps/planes.Tpo -c -o planes.o `test -f
'backend/shape/planes.cpp' || echo './'`backend/shape/planes.cpp
mv -f .deps/planes.Tpo .deps/planes.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT jitter.o -MD
-MP -MF .deps/jitter.Tpo -c -o jitter.o `test -f
'backend/support/jitter.cpp' || echo './'`backend/support/jitter.cpp
mv -f .deps/jitter.Tpo .deps/jitter.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT msgutil.o -MD
-MP -MF .deps/msgutil.Tpo -c -o msgutil.o `test -f
'backend/support/msgutil.cpp' || echo './'`backend/support/msgutil.cpp
mv -f .deps/msgutil.Tpo .deps/msgutil.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT statistics.o
-MD -MP -MF .deps/statistics.Tpo -c -o statistics.o `test -f
'backend/support/statistics.cpp' || echo './'`backend/support/statistics.cpp
mv -f .deps/statistics.Tpo .deps/statistics.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT task.o -MD
-MP -MF .deps/task.Tpo -c -o task.o `test -f 'backend/support/task.cpp'
|| echo './'`backend/support/task.cpp
mv -f .deps/task.Tpo .deps/task.Po
randomsequences.o -MD -MP -MF .deps/randomsequences.Tpo -c -o
randomsequences.o `test -f 'backend/support/randomsequences.cpp' || echo
'./'`backend/support/randomsequences.cpp
mv -f .deps/randomsequences.Tpo .deps/randomsequences.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT imageutil.o
-MD -MP -MF .deps/imageutil.Tpo -c -o imageutil.o `test -f
'backend/support/imageutil.cpp' || echo './'`backend/support/imageutil.cpp
mv -f .deps/imageutil.Tpo .deps/imageutil.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT octree.o -MD
-MP -MF .deps/octree.Tpo -c -o octree.o `test -f
'backend/support/octree.cpp' || echo './'`backend/support/octree.cpp
mv -f .deps/octree.Tpo .deps/octree.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT taskqueue.o
-MD -MP -MF .deps/taskqueue.Tpo -c -o taskqueue.o `test -f
'backend/support/taskqueue.cpp' || echo './'`backend/support/taskqueue.cpp
mv -f .deps/taskqueue.Tpo .deps/taskqueue.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT fileutil.o
-MD -MP -MF .deps/fileutil.Tpo -c -o fileutil.o `test -f
'backend/support/fileutil.cpp' || echo './'`backend/support/fileutil.cpp
mv -f .deps/fileutil.Tpo .deps/fileutil.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT bsptree.o -MD
-MP -MF .deps/bsptree.Tpo -c -o bsptree.o `test -f
'backend/support/bsptree.cpp' || echo './'`backend/support/bsptree.cpp
mv -f .deps/bsptree.Tpo .deps/bsptree.Po
renderfrontend.o -MD -MP -MF .deps/renderfrontend.Tpo -c -o
renderfrontend.o `test -f 'frontend/renderfrontend.cpp' || echo
'./'`frontend/renderfrontend.cpp
frontend/renderfrontend.cpp: In member function ‘void
pov_frontend::RenderFrontendBase::NewBackup(POVMS_Object&,
pov_frontend::ViewData&, const pov_base::Path&)’:
frontend/renderfrontend.cpp:617:50: warning: converting ‘false’ to
pointer type ‘const void*’ [-Wconversion-null]
pov_frontend::RenderFrontendBase::ContinueBackup(POVMS_Object&,
pov_frontend::ViewData&, pov_frontend::RenderFrontendBase::ViewId, int&,
std::vector<int>&, const pov_base::Path&)’:
frontend/renderfrontend.cpp:670:47: warning: converting ‘false’ to
mv -f .deps/renderfrontend.Tpo .deps/renderfrontend.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT console.o -MD
-MP -MF .deps/console.Tpo -c -o console.o `test -f
'frontend/console.cpp' || echo './'`frontend/console.cpp
mv -f .deps/console.Tpo .deps/console.Po
shelloutprocessing.o -MD -MP -MF .deps/shelloutprocessing.Tpo -c -o
shelloutprocessing.o `test -f 'frontend/shelloutprocessing.cpp' || echo
'./'`frontend/shelloutprocessing.cpp
mv -f .deps/shelloutprocessing.Tpo .deps/shelloutprocessing.Po
imagemessagehandler.o -MD -MP -MF .deps/imagemessagehandler.Tpo -c -o
imagemessagehandler.o `test -f 'frontend/imagemessagehandler.cpp' ||
echo './'`frontend/imagemessagehandler.cpp
mv -f .deps/imagemessagehandler.Tpo .deps/imagemessagehandler.Po
processrenderoptions.o -MD -MP -MF .deps/processrenderoptions.Tpo -c -o
processrenderoptions.o `test -f 'frontend/processrenderoptions.cpp' ||
echo './'`frontend/processrenderoptions.cpp
mv -f .deps/processrenderoptions.Tpo .deps/processrenderoptions.Po
filemessagehandler.o -MD -MP -MF .deps/filemessagehandler.Tpo -c -o
filemessagehandler.o `test -f 'frontend/filemessagehandler.cpp' || echo
'./'`frontend/filemessagehandler.cpp
mv -f .deps/filemessagehandler.Tpo .deps/filemessagehandler.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT display.o -MD
-MP -MF .deps/display.Tpo -c -o display.o `test -f
'frontend/display.cpp' || echo './'`frontend/display.cpp
mv -f .deps/display.Tpo .deps/display.Po
parsermessagehandler.o -MD -MP -MF .deps/parsermessagehandler.Tpo -c -o
parsermessagehandler.o `test -f 'frontend/parsermessagehandler.cpp' ||
echo './'`frontend/parsermessagehandler.cpp
mv -f .deps/parsermessagehandler.Tpo .deps/parsermessagehandler.Po
animationprocessing.o -MD -MP -MF .deps/animationprocessing.Tpo -c -o
animationprocessing.o `test -f 'frontend/animationprocessing.cpp' ||
echo './'`frontend/animationprocessing.cpp
mv -f .deps/animationprocessing.Tpo .deps/animationprocessing.Po
rendermessagehandler.o -MD -MP -MF .deps/rendermessagehandler.Tpo -c -o
rendermessagehandler.o `test -f 'frontend/rendermessagehandler.cpp' ||
echo './'`frontend/rendermessagehandler.cpp
mv -f .deps/rendermessagehandler.Tpo .deps/rendermessagehandler.Po
imageprocessing.o -MD -MP -MF .deps/imageprocessing.Tpo -c -o
imageprocessing.o `test -f 'frontend/imageprocessing.cpp' || echo
'./'`frontend/imageprocessing.cpp
mv -f .deps/imageprocessing.Tpo .deps/imageprocessing.Po
defaultplatformbase.o -MD -MP -MF .deps/defaultplatformbase.Tpo -c -o
defaultplatformbase.o `test -f 'frontend/defaultplatformbase.cpp' ||
echo './'`frontend/defaultplatformbase.cpp
mv -f .deps/defaultplatformbase.Tpo .deps/defaultplatformbase.Po
stringutilities.o -MD -MP -MF .deps/stringutilities.Tpo -c -o
stringutilities.o `test -f 'base/stringutilities.cpp' || echo
'./'`base/stringutilities.cpp
mv -f .deps/stringutilities.Tpo .deps/stringutilities.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT timer.o -MD
-MP -MF .deps/timer.Tpo -c -o timer.o `test -f 'base/timer.cpp' || echo
'./'`base/timer.cpp
mv -f .deps/timer.Tpo .deps/timer.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT pov_err.o -MD
-MP -MF .deps/pov_err.Tpo -c -o pov_err.o `test -f 'base/pov_err.cpp' ||
echo './'`base/pov_err.cpp
mv -f .deps/pov_err.Tpo .deps/pov_err.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT iff.o -MD -MP
-MF .deps/iff.Tpo -c -o iff.o `test -f 'base/image/iff.cpp' || echo
'./'`base/image/iff.cpp
mv -f .deps/iff.Tpo .deps/iff.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT tiff.o -MD
-MP -MF .deps/tiff.Tpo -c -o tiff.o `test -f 'base/image/tiff.cpp' ||
echo './'`base/image/tiff.cpp
mv -f .deps/tiff.Tpo .deps/tiff.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT jpeg.o -MD
-MP -MF .deps/jpeg.Tpo -c -o jpeg.o `test -f 'base/image/jpeg.cpp' ||
echo './'`base/image/jpeg.cpp
mv -f .deps/jpeg.Tpo .deps/jpeg.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT encoding.o
-MD -MP -MF .deps/encoding.Tpo -c -o encoding.o `test -f
'base/image/encoding.cpp' || echo './'`base/image/encoding.cpp
mv -f .deps/encoding.Tpo .deps/encoding.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT ppm.o -MD -MP
-MF .deps/ppm.Tpo -c -o ppm.o `test -f 'base/image/ppm.cpp' || echo
'./'`base/image/ppm.cpp
mv -f .deps/ppm.Tpo .deps/ppm.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT openexr.o -MD
-MP -MF .deps/openexr.Tpo -c -o openexr.o `test -f
'base/image/openexr.cpp' || echo './'`base/image/openexr.cpp
mv -f .deps/openexr.Tpo .deps/openexr.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT targa.o -MD
-MP -MF .deps/targa.Tpo -c -o targa.o `test -f 'base/image/targa.cpp' ||
echo './'`base/image/targa.cpp
mv -f .deps/targa.Tpo .deps/targa.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT png.o -MD -MP
-MF .deps/png.Tpo -c -o png.o `test -f 'base/image/png.cpp' || echo
'./'`base/image/png.cpp
mv -f .deps/png.Tpo .deps/png.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT bmp.o -MD -MP
-MF .deps/bmp.Tpo -c -o bmp.o `test -f 'base/image/bmp.cpp' || echo
'./'`base/image/bmp.cpp
mv -f .deps/bmp.Tpo .deps/bmp.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT image.o -MD
-MP -MF .deps/image.Tpo -c -o image.o `test -f 'base/image/image.cpp' ||
echo './'`base/image/image.cpp
mv -f .deps/image.Tpo .deps/image.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT colourspace.o
-MD -MP -MF .deps/colourspace.Tpo -c -o colourspace.o `test -f
'base/image/colourspace.cpp' || echo './'`base/image/colourspace.cpp
mv -f .deps/colourspace.Tpo .deps/colourspace.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT hdr.o -MD -MP
-MF .deps/hdr.Tpo -c -o hdr.o `test -f 'base/image/hdr.cpp' || echo
'./'`base/image/hdr.cpp
base/image/hdr.cpp: In function ‘void
pov_base::HDR::ReadOldLine(unsigned char*, int, pov_base::IStream*)’:
base/image/hdr.cpp:147:15: warning: converting ‘false’ to pointer type
base/image/hdr.cpp: In function ‘pov_base::Image*
pov_base::HDR::Read(pov_base::IStream*, const
pov_base::Image::ReadOptions&)’:
base/image/hdr.cpp:202:44: warning: converting ‘false’ to pointer type
base/image/hdr.cpp:236:28: warning: converting ‘false’ to pointer type
base/image/hdr.cpp:251:28: warning: converting ‘false’ to pointer type
base/image/hdr.cpp:271:30: warning: converting ‘false’ to pointer type
base/image/hdr.cpp:279:33: warning: converting ‘false’ to pointer type
base/image/hdr.cpp:289:34: warning: converting ‘false’ to pointer type
pov_base::HDR::Write(pov_base::OStream*, const pov_base::Image*, const
pov_base::Image::WriteOptions&)’:
base/image/hdr.cpp:341:44: warning: converting ‘false’ to pointer type
base/image/hdr.cpp:386:50: warning: converting ‘false’ to pointer type
base/image/hdr.cpp:404:51: warning: converting ‘false’ to pointer type
base/image/hdr.cpp:413:48: warning: converting ‘false’ to pointer type
mv -f .deps/hdr.Tpo .deps/hdr.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT pgm.o -MD -MP
-MF .deps/pgm.Tpo -c -o pgm.o `test -f 'base/image/pgm.cpp' || echo
'./'`base/image/pgm.cpp
mv -f .deps/pgm.Tpo .deps/pgm.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT gif.o -MD -MP
-MF .deps/gif.Tpo -c -o gif.o `test -f 'base/image/gif.cpp' || echo
'./'`base/image/gif.cpp
mv -f .deps/gif.Tpo .deps/gif.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT gifdecod.o
-MD -MP -MF .deps/gifdecod.Tpo -c -o gifdecod.o `test -f
'base/image/gifdecod.cpp' || echo './'`base/image/gifdecod.cpp
mv -f .deps/gifdecod.Tpo .deps/gifdecod.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT povmscpp.o
-MD -MP -MF .deps/povmscpp.Tpo -c -o povmscpp.o `test -f
'base/povmscpp.cpp' || echo './'`base/povmscpp.cpp
mv -f .deps/povmscpp.Tpo .deps/povmscpp.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT moov.o -MD
-MP -MF .deps/moov.Tpo -c -o moov.o `test -f 'base/animation/moov.cpp'
|| echo './'`base/animation/moov.cpp
mv -f .deps/moov.Tpo .deps/moov.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT animation.o
-MD -MP -MF .deps/animation.Tpo -c -o animation.o `test -f
'base/animation/animation.cpp' || echo './'`base/animation/animation.cpp
mv -f .deps/animation.Tpo .deps/animation.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT textstream.o
-MD -MP -MF .deps/textstream.Tpo -c -o textstream.o `test -f
'base/textstream.cpp' || echo './'`base/textstream.cpp
mv -f .deps/textstream.Tpo .deps/textstream.Po
textstreambuffer.o -MD -MP -MF .deps/textstreambuffer.Tpo -c -o
textstreambuffer.o `test -f 'base/textstreambuffer.cpp' || echo
'./'`base/textstreambuffer.cpp
mv -f .deps/textstreambuffer.Tpo .deps/textstreambuffer.Po
processoptions.o -MD -MP -MF .deps/processoptions.Tpo -c -o
processoptions.o `test -f 'base/processoptions.cpp' || echo
'./'`base/processoptions.cpp
mv -f .deps/processoptions.Tpo .deps/processoptions.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT path.o -MD
-MP -MF .deps/path.Tpo -c -o path.o `test -f 'base/path.cpp' || echo
'./'`base/path.cpp
mv -f .deps/path.Tpo .deps/path.Po
fileinputoutput.o -MD -MP -MF .deps/fileinputoutput.Tpo -c -o
fileinputoutput.o `test -f 'base/fileinputoutput.cpp' || echo
'./'`base/fileinputoutput.cpp
mv -f .deps/fileinputoutput.Tpo .deps/fileinputoutput.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT povms.o -MD
-MP -MF .deps/povms.Tpo -c -o povms.o `test -f 'base/povms.cpp' || echo
'./'`base/povms.cpp
base/povms.cpp:245:3: warning: anonymous type with no linkage used to
declare variable ‘<anonymous struct> POVMSStreamOrderTables’ with
linkage [enabled by default]
mv -f .deps/povms.Tpo .deps/povms.Po
rm -f libpovray.a
ranlib libpovray.a
Making all in vfe
g++ -DHAVE_CONFIG_H -DPOVLIBDIR=\"/usr/local/share/povray-3.7\"
-DPOVCONFDIR=\"/usr/local/etc/povray/3.7\"
-DPOVCONFDIR_BACKWARD=\"/usr/local/etc\" -I. -I..  -I../vfe/unix
-I../unix -I../source -I../source/base -I../source/backend -pthread
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT vfecontrol.o
-MD -MP -MF .deps/vfecontrol.Tpo -c -o vfecontrol.o vfecontrol.cpp
mv -f .deps/vfecontrol.Tpo .deps/vfecontrol.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT vfedisplay.o
-MD -MP -MF .deps/vfedisplay.Tpo -c -o vfedisplay.o vfedisplay.cpp
mv -f .deps/vfedisplay.Tpo .deps/vfedisplay.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT vfe.o -MD -MP
-MF .deps/vfe.Tpo -c -o vfe.o vfe.cpp
mv -f .deps/vfe.Tpo .deps/vfe.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT vfepovms.o
-MD -MP -MF .deps/vfepovms.Tpo -c -o vfepovms.o vfepovms.cpp
mv -f .deps/vfepovms.Tpo .deps/vfepovms.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT vfesession.o
-MD -MP -MF .deps/vfesession.Tpo -c -o vfesession.o vfesession.cpp
mv -f .deps/vfesession.Tpo .deps/vfesession.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT vfeplatform.o
-MD -MP -MF .deps/vfeplatform.Tpo -c -o vfeplatform.o `test -f
'unix/vfeplatform.cpp' || echo './'`unix/vfeplatform.cpp
mv -f .deps/vfeplatform.Tpo .deps/vfeplatform.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT unixconsole.o
-MD -MP -MF .deps/unixconsole.Tpo -c -o unixconsole.o `test -f
'unix/unixconsole.cpp' || echo './'`unix/unixconsole.cpp
mv -f .deps/unixconsole.Tpo .deps/unixconsole.Po
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -MT unixoptions.o
-MD -MP -MF .deps/unixoptions.Tpo -c -o unixoptions.o `test -f
'unix/unixoptions.cpp' || echo './'`unix/unixoptions.cpp
mv -f .deps/unixoptions.Tpo .deps/unixoptions.Po
platformbase.o -MD -MP -MF .deps/platformbase.Tpo -c -o platformbase.o
`test -f 'unix/platformbase.cpp' || echo './'`unix/platformbase.cpp
mv -f .deps/platformbase.Tpo .deps/platformbase.Po
rm -f libvfe.a
ar cru libvfe.a vfecontrol.o vfedisplay.o vfe.o vfeprecomp.o vfepovms.o
vfesession.o vfeplatform.o unixconsole.o unixoptions.o platformbase.o
ranlib libvfe.a
Making all in unix
g++ -DHAVE_CONFIG_H -I. -I..  -I.. -I../source -I../source
-I../source/backend -I../source/base -I../source/frontend -I../vfe
-I../vfe/unix -pthread -I/usr/include  -pipe -Wno-multichar
-Wno-write-strings -fno-enforce-eh-specs -s -O3 -ffast-math
-march=native -MT disp_sdl.o -MD -MP -MF .deps/disp_sdl.Tpo -c -o
disp_sdl.o disp_sdl.cpp
mv -f .deps/disp_sdl.Tpo .deps/disp_sdl.Po
-march=native -MT disp_text.o -MD -MP -MF .deps/disp_text.Tpo -c -o
disp_text.o disp_text.cpp
mv -f .deps/disp_text.Tpo .deps/disp_text.Po
-O3 -ffast-math -march=native  -L/usr/lib -o povray disp_sdl.o
-lz -lrt -lm -lboost_thread -lboost_system -lboost_thread
make[2]: Entering directory `/media/Raytracing/povray-3.7-stable'
cat ./povray.ini.in | sed
"s,__POVLIBDIR__,/usr/local/share/povray-3.7,g" > ./povray.ini
make[2]: Leaving directory `/media/Raytracing/povray-3.7-stable'
// end messages
Almost perfect - except for a few warnings!
Finally installing - make install:
// begin messages
Making install in source
make[1]: Entering directory `/media/Raytracing/povray-3.7-stable/source'
make[2]: Entering directory `/media/Raytracing/povray-3.7-stable/source'
make[2]: Für das Ziel »install-exec-am« ist nichts zu tun.
make[2]: Für das Ziel »install-data-am« ist nichts zu tun.
make[1]: Leaving directory `/media/Raytracing/povray-3.7-stable/source'
Making install in vfe
make[1]: Entering directory `/media/Raytracing/povray-3.7-stable/vfe'
make[1]: Leaving directory `/media/Raytracing/povray-3.7-stable/vfe'
Making install in unix
make[1]: Entering directory `/media/Raytracing/povray-3.7-stable/unix'
  /bin/mkdir -p '/usr/local/bin'
   /usr/bin/install -c povray '/usr/local/bin'
make[1]: Leaving directory `/media/Raytracing/povray-3.7-stable/unix'
make[1]: Entering directory `/media/Raytracing/povray-3.7-stable'
cat /dev/null > ./install.log;
Creating data directories...
Copying data files...
Creating documentation directories...
Copying documentation files...
Creating user directories...
Copying user configuration and INI files...
  /bin/mkdir -p '/usr/local/etc/povray/3.7'
  /usr/bin/install -c -m 644 povray.conf '/usr/local/etc/povray/3.7'
  /bin/mkdir -p '/usr/local/share/man/man1'
  /usr/bin/install -c -m 644 povray.1 '/usr/local/share/man/man1'
  /bin/mkdir -p '/usr/local/share/povray-3.7'
  /bin/mkdir -p '/usr/local/share/povray-3.7/scripts/'
  /usr/bin/install -c scripts/rerunpov.sh scripts/portfolio.sh
scripts/allscene.sh scripts/render_anim.sh scripts/allanim.sh
scripts/render_scene.sh scripts/runpov.sh
  /usr/bin/install -c -m 644 povray.ini '/usr/local/etc/povray/3.7'
  /bin/mkdir -p '/usr/local/share/doc/povray-3.7'
  /usr/bin/install -c -m 644 AUTHORS ChangeLog NEWS
// end messages
Also worked fine!
Now the final test:
povray
// begin messages
povray: cannot open the user configuration file
/home/yadgar/.povray/3.7/povray.conf: No such file or directory
Problem with option setting
povray
No input file provided
// end messages
According to unix/README.md, povray expects povray.conf to be stored
also in /home/yadgar/.povray/3.7 - so I will have to copy it from
/usr/local/etc/povray/3.7 !
Doing a test render:
povray +imandel.pov +omandel.png +fn
IT WORKS!!! THANK YOU ALL FOR ASSISTING ME!!! And be prepared to find
some streets named after you when one day you might come to Khyberspace
(Afghatopia 2050 mode) and stroll along Kabul's glittering boulevards...
See you in Khyberspace!
Yadgar
Now playing: Arizona Sky (China Crisis)
