POV-Ray : Newsgroups : povray.unix : Compiling 3.7 on openSUSE 13.1 Server Time
31 Mar 2026 09:06:07 EDT (-0400)
  Compiling 3.7 on openSUSE 13.1 (Message 1 to 8 of 8)
Subject: Compiling 3.7 on openSUSE 13.1
Date: 27 Nov 2013 08:13:30
Message: <5295effa$1@news.povray.org>
When 3.7 was released I compiled it (without the docs) successfully on
openSUSE 12.3.
I updated my system to openSUSE 13.1 and now configure fails:
> checking for boostlib >= 1.37... yes
> checking whether the Boost::Thread library is available... yes
> checking for exit in -lboost_thread-mt... yes
> checking whether the boost thread library is usable... no
> configure: error: in `/home/john/povray-3.7':
> configure: error: cannot link with the boost thread library
> See `config.log' for more details
BTW I've definitely got boost devel installed
Any ideas?
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Subject: Re: Compiling 3.7 on openSUSE 13.1
Date: 27 Nov 2013 08:25:43
Message: <5295f2d7@news.povray.org>
> openSUSE 12.3.
> Any ideas?
> John
did you do an /update/ to 13.1 or a fresh install? if update, maybe
something is fishy! what does /usr/lib look like ... there are a bunch
of symlinks. the links are libboost_*.so and the files have version
branding ... libboost_*so.x.xx.x ...
Date: 27 Nov 2013 08:49:03
Message: <5295f84f$1@news.povray.org>
Aha!
> lrwxrwxrwx 1 root root      25 Nov 20 17:20 libboost_atomic-mt.so ->
libboost_atomic.so.1.53.0
> lrwxrwxrwx 1 root root      25 Nov 20 17:20 libboost_atomic.so ->
> lrwxrwxrwx 1 root root      26 Nov 20 17:20 libboost_context-mt.so ->
libboost_context.so.1.53.0
> lrwxrwxrwx 1 root root      26 Nov 20 17:20 libboost_context.so ->
libboost_atomic.so.1.53.0 and libboost_context.so.1.53.0 are both missing.
It was an /update/ so something's gone wrong there. Now to hunt for the
missing libs.
John
Protect the Earth
Date: 27 Nov 2013 09:13:07
Message: <5295fdf3$1@news.povray.org>
> Aha!
> missing libs.
> John
... and I still get the same error :-(
FWIW the following are installed:
libboost_chrono.so.1.53.0
libboost_date_time.so.1.53.0
libboost_filesystem.so.1.53.0
libboost_graph_parallel.so.1.53.0
libboost_graph.so.1.53.0
libboost_iostreams.so.1.53.0
libboost_locale.so.1.53.0
libboost_math_c99f.so.1.53.0
libboost_math_c99l.so.1.53.0
libboost_math_c99.so.1.53.0
libboost_math_tr1f.so.1.53.0
libboost_math_tr1l.so.1.53.0
libboost_math_tr1.so.1.53.0
libboost_mpi_python.so.1.53.0
libboost_mpi.so.1.53.0
libboost_prg_exec_monitor.so.1.53.0
libboost_program_options.so.1.53.0
libboost_python.so.1.53.0
libboost_random.so.1.53.0
libboost_regex.so.1.53.0
libboost_serialization.so.1.53.0
libboost_signals.so.1.53.0
libboost_system.so.1.53.0
libboost_thread.so.1.53.0
libboost_timer.so.1.53.0
libboost_unit_test_framework.so.1.53.0
libboost_wave.so.1.53.0
libboost_wserialization.so.1.53.0
Anything missing that strikes you immediately.
John
Protect the Earth
Date: 27 Nov 2013 10:32:28
Message: <5296108c@news.povray.org>
I'm wondering if uninstalling, looking to see if it cleaned up proper,
then re-installing might be a useful exercise ... well unless you've
already tired that approach.
Here's what I have in /usr/lib:
libboost_date_time-mt.so
libboost_filesystem-mt.so
libboost_graph-mt.so
libboost_graph_parallel-mt.so
libboost_graph.so
libboost_iostreams-mt.so
libboost_math_c99f-mt.so
libboost_math_c99l-mt.so
libboost_math_c99-mt.so
libboost_math_tr1f-mt.so
libboost_math_tr1l-mt.so
libboost_math_tr1-mt.so
libboost_mpi-mt.so
libboost_mpi_python-mt.so
libboost_mpi.so
libboost_prg_exec_monitor-mt.so
libboost_program_options-mt.so
libboost_python-mt.so
libboost_python.so
libboost_random-mt.so
libboost_random.so
libboost_regex-mt.so
libboost_regex.so
libboost_serialization-mt.so
libboost_signals-mt.so
libboost_signals.so
libboost_system-mt.so
libboost_system.so
libboost_thread-mt.so
libboost_thread.so
libboost_unit_test_framework-mt.so
libboost_wave-mt.so
libboost_wave.so
libboost_wserialization-mt.so
the difference seems to be my libboost_*-mt.so files (didn't count them)
... when I go into yast and search for boost then look at the filelist
for the installed packages I do /not/ see the "mt" files, so your
mileage may vary comparing to my list
Date: 27 Nov 2013 11:01:28
Message: <52961758$1@news.povray.org>
> openSUSE 12.3.
> Any ideas?
> John
add : LIBS="-lboost_system -lboost_thread"
in the ./configure  command
That's an issue with boost > 1.49
Just because nobody complains does not mean all parachutes are perfect.
Date: 27 Nov 2013 11:22:37
Message: <52961c4d$1@news.povray.org>
Bingo! I must have missed the threads that raised that issue.
Thanks to all for their help
John
Protect the Earth
Date: 27 Nov 2013 11:53:19
Message: <5296237f$1@news.povray.org>
more likely /forgot/ in my case ;-)
