POV-Ray : Newsgroups : povray.unix : Pulling 3.7 source from GitHub Server Time
22 Mar 2026 22:54:51 EDT (-0400)
  Pulling 3.7 source from GitHub (Message 1 to 6 of 6)
Subject: Pulling 3.7 source from GitHub
Date: 8 Nov 2013 15:01:13
Message: <527d4309$1@news.povray.org>
I thought I'd pass this along, since I didn't want to pull the /entire/
repository ...
git prep:
mkdir povray
cd povray/
git init
git config core.sparsecheckout true
echo source/ >> .git/info/sparse-checkout
echo unix/ >> .git/info/sparse-checkout
echo vfe/ >> .git/info/sparse-checkout
echo distribution/ >> .git/info/sparse-checkout
git remote add -f origin https://github.com/POV-Ray/povray
git pull origin master
build prep:
cd povray/unix
./prebuild.sh
cd ../
./configure COMPILED_BY="jho### [at] povrayorg"
make
sudo make install
... one problem I /just/ discovered is that the unix documentation that
goes in ~povray/doc/html is missing ... looking into that!
Jim
Subject: Re: Pulling 3.7 source from GitHub
Date: 8 Nov 2013 15:35:37
Message: <527d4b19$1@news.povray.org>
> repository ...
> git prep:
> mkdir povray
> cd povray/
> git init
Personally, I just pulled the whole thing; I wanted a copy for Kati's
Windoze installation.
> build prep:
> cd povray/unix
> ../prebuild.sh
> cd ../
> ../configure COMPILED_BY="jho### [at] povrayorg"
> make
> sudo make install
> .... one problem I /just/ discovered is that the unix documentation that
> Jim
Noticed that ;-)
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Date: 8 Nov 2013 15:44:39
Message: <527d4d37@news.povray.org>
>> repository ...
>> git prep:
>> mkdir povray
>> cd povray/
>> git init
>> build prep:
>> cd povray/unix
>> ../prebuild.sh
>> cd ../
>> make
>> sudo make install
>> Jim
> Noticed that ;-)
> John
... also the prebuild.sh step is a departure from the way it was done in
the past, just offered this up as tmp work-around until the issue can be
addressed
Date: 8 Nov 2013 16:13:02
Message: <527d53de$1@news.povray.org>
On 08/11/13 20:44, James Holsenback wrote:
> .... also the prebuild.sh step is a departure from the way it was done
> in the past, just offered this up as tmp work-around until the issue can
> be addressed
Indeed. Basically I noticed the lack of a configure script so went
looking in the unix directory. Read prebuild.sh and guessed that that
was what I should run.
John
Protect the Earth
Date: 8 Nov 2013 17:10:34
Message: <527d615a@news.povray.org>
> repository ...
> git prep:
> mkdir povray
> cd povray/
> git init
add:
echo doc/ >> .git/info/sparse-checkout
> build prep:
> cd povray/unix
> ./prebuild.sh
> cd ../
> make
> sudo make install
added files in doc/html ... currently the sync between povray and github
is manual, so be patient if they don't show up right away
Date: 21 Nov 2013 17:11:26
Message: <528e850e$1@news.povray.org>
I've added several items to the checkout list see the updated list here:
http://jholsenback.wordpress.com/2013/11/17/pulling-pov-ray-3-7-source-from-github/
namely the 1st four items added to sparse-checkout ... for some reason
the libraries directory is also being picked up. Don't know why /yet/
... since it's not needed for nix source build I just deleted it.
